tim_kz
    5
Everything posted by tim_kz
  1. There are some photos of the techno tuning mounts in this thread. I am installing them in a KE30 with a 4A motor. Tim http://www.rollaclub.com/board/index.php?a...&pid=428613
  2. I am repairing my daughter AE82. I have the passenger side drive shaft out as it seems to be loose in the transaxle. I want to check the dimensions of the inner shaft as goes into the gearbox ? The previous owner did many bodgy things to this car. Tim
  3. The bore of a 2tg will go to 89mm with a 3T crank you get to 1941cc . A 2tg block generally needs to be adjusted for clearance for the rods at the base of the clylinders. Tim
  4. Here is the T3 mounts up close just rough fitted with old 4A block. The mounts are AE71 rubbers. I need to deal with the lip on the crossmember the K series mounts sit on. Tim
  5. I have just installed a set in a KE30 looks good so far. Tim
