ae92supercharged4u
    20
ae92supercharged4u's Achievements
  1. thanks dude will c da mechanic this week.
  2. Hey Guys, I just changed my oil again gave the engine a good flush before it. now the thing happening now is: When I put my foot down there is no smoke coming at all. Once the boost kicks in and I take my foot of the pedal it just blows smoke in one big cloud. Now could the problem still be my piston or is it the SC? The SC just got changed and before with my old SC the Rolla did not blow smoke at all. Could it be the SC is about to die as I got a Squeeking noise coming from the SC when it hit high boost. Which was fixed after tighten the belt but noise came back after a short while. I would greatly appreciate your guys input on whether the problem is with my Piston Rings or SC?
  3. I got a gze and I was happy with it since I found out it will be a bit tricky to find the Supercharger itself. Anyway after speaking to a few guys I will definetely chuck a nice t28 in it. So turbo a gze is the best option IMHO and personally I will do it in the next on my shedule after rebuilding the engine. If u gonna do all it yourself you could get away with it under $1500.
  4. I got GTX 20-50 I will give the stop smoke a go as well. thanks for that. :y:
  5. Hey Guys, Changed oil yesterday and its still smoking a little bit but it heaps better now the smoke could hopefully still be some leftovers from the other oil in the system. thanks for all the help guys, :y:
  6. I will get some oil today and change it. thanks guys, I hope thats the only problem as of yesterday the smoke when I put the foot down is like a diesel now hehehe I guess the cars behind me must've loved it :D If not I most likely got to rebuild the engine then eh? I was thinking to turbo it anyway,should I rebuild and get the turbo done? Or should just find a new engine and drop it straight in? Also what Turbo engine would be the ideal replacement for the 4agze that would drop straight into the ae92? thanks guys for the help :yes:
  7. what oil u recommend? I havent done anything to it justy got it about it a month ago I don't know what oil was in it before? But is it worth it to rebuild or just get a new engine?
  8. One more thing Should I be worried about the wiring,do I need anything extra etc?
  9. I'm gonna do everything myself with a mate. So now i just gotta source the stuff and time off work. How long you reckon it would take if all the parts are together U think a weekend will be enough? thanks Heaps Mate, u been great help,much appreciated.
  10. I definetely want to go turbo. All I need to know is whether to get a Turbo and Manifold and dump pipe would be enough as I heard the stock ECU handles up tp 30psi? I got the FMIC already so that hopefully will save me the cost on the Cooling Pipes. Plus now I think i got to get new piston rings as well. You think I would push it to get it done under 1k?
  11. So I should just replace the SC with a turbo,manifold,ECUand get the wiring done would that be it? Or is there something else I should get? thanks for putting me in the right direction.
  12. Would the 4agte be a straight fit? Should I just get the Motor or frontcut?
  13. 10/40 I think I got arround 100k on the motor now.
  14. I'm using Castrol magnatec should I change to a different kind? What would you suggest? Also this smoke issue is happening since I chnaged the SC before it did not blow smoke as much as now?
