RND.IGO
    44
Everything posted by RND.IGO
  1. Ah true Thanks mate... so if i use the hyper pak ill be right ? I'm gunna chuck a carbs on and just see how i go....
  2. yeah i didnt build the motor... and the mob that did.. hav now retired... so i carnt chase that up... I'm still lookin at $2k plus be4 its runin.. I don't understand wats the go with the coil ????? a standered dizzy is a standered dizzy yeah ???? Can some 1 please explain ? I'm sure it should still REV hard and Belt tyres... Its not in a ROLLA its in a GEMINI... in which No matter if its Turbo'd or N/A... it will be different and people Like that... I'm sure ill Make some dollar bak on all my NEW gear... C.A.S,Haltech,MSD coils,turbo,Cooler,Fuel setup,Etc,Etc....
  3. Sorry i should hav explained my self betta... yeah it needs wiring etc few bits and pieces... and will need a tune.. I'm just not really that Crash HOT with it anymore... want a different project.. its a standered rebuild 4agze.. with cometic head gasket and head work... not sure of comp ? can that tell u anything... why carnt i just use a standered 4age Dizzy ?
  4. Hey all... Ive built a 4agte.. with all the goods... but ive lost interest.. and it still needs 2 be wired up etc.. i just want it runing so it moves and Can put it on the market... i was thinkin bout just throwin a dizzy bak in it.. and seting up a 32/36 weber or 350 holly on the standered GZE manifold ? So my question is.. what will it Run,Drive and under throttle be like ? Which carby should i use... ? any help will be much appreciated Thanks...
  5. ah k true... i hav no idea about toyota motor ay.. so ur input is my output lol... i would be stocked if it makes 200rwhp.. there are plenty of questions i would like 2 ask but don't wanna look like a dik lol.. Thanks ay
  6. hey mate... can i run both as E85 is abit far of a travel for me lol... My motor its yeah a GZE.. standered pistons,rods,crank... just done good rings,bearings and head studs.. and bought a bigport head brand new with $2300 worth of reciepts.. T4/T3 rear housing high flowed.. Big throttle etc... Can you find out the specs of your mates motor.. I'm planin on runing 25psi+
  7. And yeah.. can i not run LOW impendence injectors at all ? Y not ?
  8. ah thanks heaps man... so what range in OHM would be high ? and low
  9. hey all i hav a haltech sprint 500.. and was wondering what injectors 2 run ???? I was gunna buy Delphi rochester 1000cc... But a cheap set of RC RACING 1s hav came up.. they are 1000cc also but peak and hold... So tha questions is do i run Peak and Hold OR Saturated ? oh my motor a 4agze 16v turboed ? Cheers any help appreciated..
  10. Any where else i can get them from ???? Any idea which 1's i need ? like do they 1s for a GZE rail as they look pretty complicated
  11. Hey all... where would i find after market injector inlet and outlet bits ? Could i just go to 2 my local performance shop ? inwhich does the Brand 'Earls' ?
  12. yeah sweet as dude thanks...
  13. I'm runin 2litre surge.. bosch 044,second 1 if neccesery..bigger lines, Not sure what fuel reg.. do u hav any in mind ? ah should rev rather hard yeah 8-9000rpm ? yeah planin on 1000cc carnt go wrong lol...
  14. a mate of a mate had a celica with a 4agze turboed... and it use 2 run 35psi 24/7... i built my motor 2 his specs.. ill be rather upset if it don't get well close to 300rwhp... any help advice would be nice... thanks
  15. hey all... i was wondering if yous could tell me what injectors would be suitable for my 4agze/turbod.. i hav so far built the motor very strong.. and hav all the goods.. i wanna run excessive boost 25-35psi... i was gunna get indy 1000cc... as for i only hav purple top rx7s lol.. which will be forsale... any help please
  16. hey all... i was wondering if yous could tell me what injectors would be suitable for my 4agze/turbod.. i hav so far built the motor very strong.. and hav all the goods.. i wanna run excessive boost 25-35psi... i was gunna get indy 1000cc... as for i only hav purple top rx7s lol.. which will be forsale... any help please
  17. yeah that sounds sweet me old man just lives out side off wagga, Temora... lol..
  18. $500ish is not bad... and ur in wagga wagga ? what is tha shop called ? hav u dealed with many 4ag turbo motors ? i was hopin 4 a base map so i could atleast start it at home and make sure everything is tight and ready 2 go for a tune ?
  19. hey all i just bought i a Haltech sprint 500 Brand new from HALTECH... and I'm wondering if there is a standered a map setting for a "4agze gte ge etc" as the bloke from HALTECH told me there wasent... as having none is gunna make my first tune very Costie $$$$... So can any 1 help me out please... oh i hav a 4agTe 16v Thanks......
  20. Bump any 1 help...
  21. hey all...i need some help.. i've just built a 4agze/te.. i'm upto boltin alternator up... tho i don't hav a bracket... what bracket do i need to use...? and with water inlet.. can i use standered gze.. and not run therom stat ?
  22. Hey all... can any 1 supply me with a top mount 16v turbo manifold... Even home made... lol... i hav bought 2 manifolds off ebay now and no luck... i just recently bought a "cast iron top mount" tho is T2 in which i need T3.. so bought tha adapter in which is wrong... and i'm just over it lol... i've looked every where for manifolds and had no luck... so does an1 hav a link of such please...
  23. Hey lads would any 1 be able 2 tell me if i could make this manifold 2 run external gate.. Like tap in 2 the collecter... Heres a link... thanks for any help.. http://cgi.ebay.com.au/HIGH-FLOW-TURBO-MANIFOLD-AE86-SPRINTER-4AGE-TOYOTA-/130434899930?pt=AU_Car_Parts_Accessories&hash=item1e5e869fda
  24. hey all... Just wantin 2 know what alternator bracket i use for a RWD 4agte.. i hav used a 4AC water pump... and not carnt work out what alternator bracket... ????? Can some 1 please help me
  25. Heys lads... i'm guessin some 1 can tell me where i would find tha port 2 tap my oil line in 2 for my turbo... and if can get a picture... as there are 2 up tha front on exuast side.. but don't know which 1... Cheers...
