irokin
Admin
    4814
    22
Everything posted by irokin
  1. Easily. The auto is always going to be the big culprit here.
  2. False! There are a few small but critical differences. Probably the most critical is the bolt diameters, IIRC S13 is 12mm and S14/15 are 14mm or something to that effect.
  3. I'll dig out a photo later demonstrating why this is an insanely bad idea.
  4. It's not about political correctness, it's that they're kitsch and vile.
  5. And yet they wonder why they struggle to compete with online businesses. Idiots
  6. That's colossal. My Silvia in full trim and a full tank was 1180kg.
  7. <3 TED Talks
  8. It's getting quite obscene. Two years ago I bought a pair of OCZ Vertex IIs to put in a RAID 0 setup. Benchmarked them at somewhere around 500MB/sec which was stellar at the time. Now you can buy an entry level (<$100) drive that will achieve the same speed.
  9. http://www.fairwork....es/default.aspx
  10. Well yea... because:
  11. Sweet JESUS that's expensive. I'm getting $31,995 corrected. http://www.abs.gov.au/websitedbs/d3310114.nsf/home/consumer+price+index+inflation+calculator
  12. Before anyone starts harping on about how they almost cost that much again that's about $19500 in today's money... :P You can get a base model 2012 Corolla for about that much now.
  13. If you try to represent this in LaTeX you end up with this: \frac {6} {2(2+1)} which AFAIK is like: (6)/(2(2+1)) If you write it as this: \frac 6 2(2+1) LaTeX gives you this: C and its derivative languages (Java, Python, PHP etc) will work it out (with a multiplication added) to be 9. To get 1 you have to start piling on brackets to force the order of operations to change.
  14. That's cruel!
  15. That's a bit better :P Its not so bad these days because you can ignore individual signatures. I still try to keep the signature bloat down for the guest visitors though :).
  16. Slay that evil whitespace...
  17. Guys just keep in mind our 150 pixel limit for signatures. A good guideline is if you make a 1 line post and your signature finishes below the avatar block (<----) then it's probably too large. Ken's for example is 300+ pixels all up.
