gtnickk
    188
Everything posted by gtnickk
  1. this looks good, do you still have you ke35 brake booster
  2. bugger mate , reshell and go again
  3. looks good
  4. Diff time, Rear Brakes/Diff upgrade Shortened Nissan Skyline R31 diff 28 spline 4 pinion centre with a Mini Spool and 4.11 gears Billet axles for both sides Holden Commodore Vs rear calipers and Handbrake setup (by doing this i will have a better Handbrake) Holden Commodore Vs rear Rotors slotted and dimpled with Custom spacer for the Disc rotor to allow me to bolt the Commodore System to the Skyline diff. Comparison below bit of an upgrade Mounted in the car test fit wheel for brake clearance Done finished I'm not happy with my rear calipers so will be rebuilding these shortly but its getting close for engineering.
  5. well done mate, looks killer
  6. looks smick i like it
  7. Being just before Christmas work was slowing down so Foreign order day it was. Today i Sand Blasted my calipers, rebuilt them with new pistons and seal kit. Then i machined my new discs which i have had for years but they had surface rust on them so why not. I still had time up my sleeve so i painted my struts in gloss black 2 pac for shits and giggles. Then i had spell and re assembled everything, really happy with the New KYB AE86 inserts and the Kmac Hats, So now i just got to get a day pass from the wife and throw them in the car. The finished results.
  8. These photos show exactly what you have to do to xt130 struts fit a corolla This picture is a standard Ke55/30 strut, i was happy with my existing ride height so i used this to measure for my new strut. I then made a jig and cut it the spring perch of once i hade all my measurements in place Then i swapped to the xt130 strut as shown and cut the old perch of and re welded the corolla perch on.
  9. Hey Taz, sorry no r31 calipers, the diff i got was missing them.
  10. So meanwhile why i have been sorting all kinds of other issues such as Kids, no time and arguments with the wife i have decided to concentrate on the fuel system and brakes. While I'm waiting for other parts to arrive. Front Brakes/Front Strut upgrade. Hilux 4 pot Calipers (LN106) Xt130 Front Struts (TOYOTA KYB UNITS) King springs lowered KE55 SPRING Seat welded onto xt130 strut (Yes i made a jig for this and I'm happy to do it for people who are interested for a fee) Ae86 KYB INSERT VN 1 INCH MASTER CYLINDER ON REBUILT KE55 BOOSTER Rear Brakes/Diff upgrade Shortened Nissan Skyline R31 diff 28 spline 4 pinion centre with a Mini Spool and 4.11 gears Billet axles for both sides Holden Commodore Vs rear calipers and Handbrake setup (by doing this i will have a better Handbrake) Holden Commodore Vs rear Rotors slotted and dimpled with Custom spacer for the Disc rotor to allow me to bolt the Commodore System to the Skyline diff. Some more pics Below is my front strut uprgrade just a mock set up at this stage will have more detailed photos to come Also i how i currently have my engine sitting this is the final position and in for the last time for a while hopefully.
  11. its who you no in this game mate haha.
  12. 5k out and sold, 3tgte in with w58, note the fire wall clearance and still a heap of room up the front, for my custom alloy rad and inter-cooler.
  13. So you guessed it i got bored with a 5k and twin carbies, so time for a 3tgte, with a W58
  14. Some photos from Newcastle jap day, car is now on Historic Rego
  15. well a lot of time has past since my last proper update got bored with one carb so i put twin dellortos on and had tuned them, these carbs ran really well but I'm a sucker and got bored with them so i change to a kick arse solex set up more photos to come
  16. I had a 3k with that head casting, i found a thread somewhere indicating that it was from a 3kh which means high compression, but it think this only apply's to the block. I hope this helps. Also does it have a Welch plug at the back it could be an early Big port. I hope this helps
  17. nice car mate, looks good
  18. Thanks guys going to do a a xt130 upgrade with coil over upgrade at same time. Will do a how to in my rides thread when finished. Thanks for the help
  19. Thanks guys, looks like I'm in the market for some xt130 complete struts and arms.
  20. Hi guys Looking into doing a brake Upgrade on my Ke55, found heaps of information. The problem is i have my ride height right and want to maintain the factory Strut. Is there a bolt on option, or little modification to basically unbolt the old brakes on my car throw them over my shoulder and Bolt bigger Brakes on. I don't want to use Hopper Stoppers etc: Also I'm running 15x7 rims. So have plenty of space. I like the Idea of the Pug setup but don't want to mix and match struts. any ideas or can some one point me in the right direction to a step by step guide. Many thanks Nick
  21. That looks awesome
  22. looks good in the video you had some nice little carb/stack air filters where did you get them and do they seem to work. thanks Nick
  23. Hi guys found this on the net last Night. Thought i would share with fellow clubbers. This car is from Indonesia, running a 7k
  24. keen for a set thanks
  25. looking good mate, rims suit it
