StasIII
    242
    2
Everything posted by StasIII
  1. You can do it, its very possible but it does break boxes. I'm on my 3rd atm
  2. would love more pics off the engine/mods/ brakes etc
  3. I've smoked a few V6 commodores in my 5k ke10 , obviously head , cam , intake and exhaust mods tho, 5spd and 4.3s in the diff helps
  4. yeah once i get around to it i will . but others might have knowleagde?
  5. hey . ive recently put a 5k engine and a k50 box into my ke10, the car runs a jap diff with 4.3 rear end ratio the motor has been worked , new pistons, rings and bearings ( acl) Block and head have both been decked Cam is a AJE grind 268 Head is the standard 5k , fully ported with 3angle valve cut Compression of the motor is 9:5:1 Car runs a 4into 1 genie system with 1 7/8inch system res with hi flow muffler Carbys is a down draft webber (forgot the size ) maybe 32/36 Id like to know the rough estimate power output at the wheels for this combo? 80hp? The car really flys in a roll on from 20kph too 120kph its keen neck to neck with a nissan pulsur sr20ve(14.9 et), no problems frying 1st and 2nd in the dry
  6. Let me quess your car wont idle properly? The hose the comes out near the throttle body need to be plumbed into the inlet track after the airfow meter but before the throttle body. The hose coming out of the rocket cover should really plumb into the airbox but you can put a little filter on the rocket cover instead. Ive got one of these engines in a ke20
  7. how do i locate this " john" fellow for the 12inch flappers . i wanna purchase a set ASAP
  8. on my car atm is 16'' simmons custom offset cause of hilux diff and PBR brakes fronts are 6.25'' running a 195/40/16 rears are 7.50'' running a 205/40/16 fitting in the guards Perfect . no mods nothing.
  9. my ke10 manuel 69 model - 690kg on the rego
  10. running a s14 OEM one in my ke20
  11. Can you buy camber tops to suit the ke20 strut off the shelf?
  12. u still alive man ?
  13. got me a set of simmons wheels
  14. :P haha thanks for the invite
  15. i should come round and have a look mate ? yeah don't forget to chop the floor out or your call will never sit like mine. Atm if i didnt cut the floor it would have hit 150% percent
  16. it will be on the road when i get off my ass and finish it hahah , just having a little break atm. thanks mate about the paint!
  17. looking pretty >?
  18. too good man . looks like my x member for the turbo3inch pipe... good idea ! ... needs lowereing in the ass man :) 3.5 inchs i went . sits well
  19. engine bay finished . just needs another polish
  20. got the springs reset at the back 3.5 inchs today . starting to look the way i want it.
  21. hahaha silver is a custom mix me and my boss made up ... mixed a bit of black and low flake silver and got that . The drag link was Totally re created by a metal fabractor out of a billet piece . So its not a cut and weld job
  22. you can enginneer a SR20 in a KE20 in NSW... i would know as ive got one in the process
  23. can't wait to cruze it with hater and you mick !
  24. put a bit of bling on the front .... exciting parts
  25. ive seen your car parked in bexley/ kogarah am i correct ?
