ke30r
    28
  • Location
    gold coast
ke30r's Achievements
  1. thanks, no idea on hp at the wheels, but it will turn the tires in 2nd no problem at all now stomp on the gas and it will light them up :y: Also had to put an HD exedy clutch into it. that is still the stock 4k with the cam by the way they love boost :y: :y:
  2. running e85, 13 psi boost. so far so good :y:
  3. i do indeed it's called. Ke30 2 door build
  4. Dude this thing is guna be bad ass once your all done!! very interested to see how well your carb set up works out. And o yes 2 door ke30's are bad ass i should know as i own 1
  5. ke30r
    Fxgh
    nice find 2 door 30s are getting real thin on the ground these days!!
  6. my question is will a 4 door ke30 roof lining fit my 2 door??? cheers
  7. thanks man, yea pretty shore they can be mounted on there side ay, as long as there is enough oil in it so the gears are still partly submerged iv seen it done on a old vw beetle drag car and he was pumpin 20 psi through the thing!! i don't recommend doing that though, he had it so the inlet side was facing up and thats what I'm doing with mine
  8. thanks man if ya wana keep your rims under the original guards i probably wouldn’t go any more than -10 offset with 7" rims hope that helps brother!
  9. just got ma self a 5k and I'm going to rebuild it tough, do it once and do it right i say! if anyone out there that has any pointers for building a boost friendly 5k eg piston type ect let me know i want to run a reliable 15 psi from the sc 14 cheers
  10. iv got 13x7 -19 offset on the rear with 20mm spacers on my 30 and the wheels are probably 10 to 15 mm past the guards
  11. bit of an update I recently had a 2" press bent exhaust system made finished off with a dumpy muffler and I have just finished fitting a tighe cams 240 grind bump-stick sounds real nice at idle and wakes up the old 3k up very well, easy to live with too has almost stock driveability :hmm: And heres a pik of the old girl out for a cruse to the spit :) a mate told me it was on boostcruising
  12. Thanks man, i got the bolt ons from tokage heres the link http://www.tokage-racingimports.com/index....t_categoryid=57
  13. Thanks for the positive comment's guys, most people seem to really like it iv tried to keep the car in the 70s era mods wise, jap muscle :bash: just gota get the sc14 plumbed up to give it a bit more poke now!!
  14. Here's a few better shots
  15. thanks man :y: what sort of power were you making out of your 4k ??? if you don't mind me asking I'm hoping to get round 100rwhp out of mine
