4a30
    8
4a30's Achievements
  1. I'm 99% shure th tps has been hooked up rite cus we wired it up twice and tried changing the tps aswell
  2. i took the part that bolts onto the botom of the throtle body off and put it bak on whith a piece of gasket paper in between it
  3. i used gasket paper to block off the stuff at the botom of the throtle body cud that be a problem??
  4. I'm in nz a we tried another tps but no change, put fuel preasure gauge on and thats fine to, some1 told me that they had the same problem but when they put a speed sensor on it fixed it any1 herd of this?????
  5. we tunned the tps using feeler gauge like the book says and seams overrated but il try again and if that doesnt work ill try another one the ecu doesnt show any fault codes thou. we replaced the leads plugs coil and dizzy nd no change.
  6. Yea we changed the dizzy cus the seal was f@$ked but still no change when we go 1/4 throtle it goes fine but wen we go full throtle it retards and runs like shit think it may be map sensor getting it cheaked tomorow thanks anyway.
  7. someone please help just put 4age in my ke30 and timmed it perfect and idols good but when we put full throtle on it boggs out and the timing retards have cheaked almost everything tps dizzy air temp and ignotor all good and no error codes show up any one got any ideas??????
  8. Hey man good idea I'm having real trouble getting the pedal box out any tips ive undun all the bolts but it wont budge thanks.
