drc_ke20
    387
Everything posted by drc_ke20
  1. well done fixing here,knock on wood no more dramas?
  2. its very nice flat on its ass!i like it but can you put the mags back on? i reckon its much hotter with those mags??
  3. very nice panno! clean,staright, simple on the outside but wild under the bonnet!!!!!!
  4. don't you need to take to the pits later and notify them of the engine change? once thats done defect is all clear coz you got a non defective engine!
  5. nice clean rolla! needs more pics pls!
  6. hyundai excel pcd is 4x114.3 so it would fit no probs. its your choice of wheels bro do what you want not what others like at the end of the day its your car!
  7. best way to find out,take your car to the auto electrician and get them to check what is the cause of this problem? if you have electrical knowledge have a go!
  8. remove door trim,close the window shut and run water along the glass while somebody is inside looking for water leaks!
  9. ring your local toyota spare parts dealer and state your vin number with the parts needed and its so easy to replace.where abouts are you? you might need the outer weather strip rubber as the water is coming from the top and dripping in the bottom?
  10. sounds like your combo switch needs replacing.expect to pay about $40 on one of this from a wrecking yard.
  11. might try this on some panels 1st? :bash:
  12. thats good to read you fix her up mate! :bash:
  13. hooray! :bash:
  14. nice replacement!is it original toyota? where did you get the handles from?Ebay?how much pls?
  15. i will double check the blocking plate?gasket could have dirt or sediment between the block and the plate??
  16. post some pics of your ride vagen! my mate got a 2 door ke30 i will post it here tonight!
  17. lol!welcome to rollaclub! :bash:
  18. check your leads too.
  19. I have managed to find a 2nd hand brake cylinder on here from a guy in QLD, so ill fit that an hopefully that will solve the issues with no brakes. I did manage to find a universal trailor brake master cylinder at Malls on the weekend bolted in perfect, but the thread was wrong for the brake line... so scrap'd that idea. If only i had my parts shed in NZ here with me id be fine :bash: quote if you end up bringing your shed over from NZ can you bring some KE25 or any old school jap cars and maybe a dozen muscle cars aswell pls! LOL! :y:
  20. any pics where its leaking from bro?i know you said it already where its maybe coming from but just want to see pls????
  21. if buying from Ebay make sure you read their feedback ratings as some from Thailand is sometimes scammers!
  22. normally stamped on the compliance plate its should be on the one that says how much cc`s,axle,trim, vin number and gearbox type
  23. give this people a try http://www.rosstuffbond.com.au/ with USD is high against AUD i would suggest you give them a go?
  24. flasher cans are normally located under the dash or drivers side kick panel.it make that tick noise when you use your indicators.its a cylindrical type shape out of plastic canister either made of shinny alloy,clear hard plastic and its got 2,3 or 4 prongs similar to a relay but relays are made into a cube form?
