rockinrolla
    87
About rockinrolla
  • Birthday 06/18/1972
Contact Methods
  • Website URL
    http://
  • ICQ
  • Location
    cedar grove QLD
  • Interests
    cars, wife and kids not in that order
  • Real Name
    nathan
Recent Profile Visitors
8885419 profile views
rockinrolla's Achievements
  1. Buy another set of leave springs for a ke20 pull the pack apart and cut 2" off the ends of each leaf, pull your springs out of the 20 and separate them and repack them using the other one staggering them in order of length, make sure the second leads is inverted, bolt them all back together and put them back in the car, this effectively lowers the car 2" and doubles the load carrying capacity and stiffens the shit of the rear end, also its legal where as lowering blocks aren't.
  2. Which lcas are the longest and will fit a ke20 with R31 front struts??? Trying to get the right camber.
  3. Found R31 LSD rear end, my 13x7s fit on just. Now all I need is to cut it down to size, thanks guys.
  4. Just a quick one on the 7k engines, are the 7k valves larger than the 5k? If yes what are the measurements? :wootjump: :jason: :scarymovie: :bounce: :groupwave: :drinks: :drinks: :drinks:
  5. having the first main leaf normal the second inverted and the rest normal work just fine, if you want to stiffen it up and lower without blocks add extra leaves mine has a 9 pack with VH commadore station wagon shocks, it may sound to much but the leaves depth give the effect of lowering and extra weight carrying ability and the shocks are soft enough not to put you lower spine through the top of your head, had it that way for 6 years no problems and handles great, the front is standard struts with lowered kings and bump steer correction spacers, can send photos if you like, by the way did this all at home on my own to save money all up cost me approximately $350 and half a day. hope this helps. :bounce:
  6. What is the general thoughts from everyone about the pro comp range of ignition systems??????? :lovin: :lovin: :lovin: :lovin: :wootjump: :scarymovie: :scarymovie: :scarymovie: :scarymovie: :kiwi: :kiwi: :kiwi: :kiwi:
  7. does anyone know the DOT regulations on side pipes? :scarymovie: :scarymovie: :scarymovie: :scarymovie: :scarymovie: :scarymovie: :scarymovie: :scarymovie:
  8. any pictures??? :hmm: :hmm: :hmm: :hmm: :blinks: :blinks: :blinks: :blinks:
  9. $150 and I'm pretty sure it came out of an early :hmm: :hmm: :hmm: :hmm: :hmm: tercel
  10. there is a guy in melbourne, Peter robinson automotive I think, I Got a diff through him a couple of years back, 3.7:1 its in my ke20 right now and its awsome in 5th on the highway :yes: :yes: :yes: :yes: :yes:
  11. already converted the stud pattern to 114.3 and the diff ratio is 3.7:1, would really like to keep it and convert the drum to disc. i'll give the 86 disc idea a go and let you know, the hilux diff would be awsome, when you say "I got" is that anything like "I'm selling" !!!!!
  12. Question, What disc brake rear end do I use to I keep the 4 stud rear end and the 13x7 superlites, is this achievable??? :blinks: :blinks: :blinks: :blinks: :blinks: :hmm: :hmm: :hmm: :hmm: :hmm: :hmm:
  13. [b]Name[/b]: Isaac Macleod (11 3/4 Yrs old) [b]Car[/b]:ke20 (mini cobra) [b]Motor & Driveline[/b]:5k 3k X, twin asian carbies, 3" high filters, MSD, Jocobs HP coil, bosch Idrium plugs, 10mm leads, extractors and 2" high flow exhaust, the other picture is of the all alloy V8 Dad is going to help me put in. nedd more Cubes [b]Suspension & Brakes[/b]:front, lowered h/d king springs, 3/4 inch sway barand strut brace from VH bommadore and the rear is, VH bommadore pedders shocks, repacked(by me) leaf springs from 4 leaf to 9 leaf, custom rear sway bar from ke70, ride height(barely legal), Brakes are ke30 and 50 X. 114.3 pcd [b]Wheels & Tyres[/b]:13X7 superlites with 235/50/13 rear and 215/60/13 front. [b]Interior[/b]:Half cage and race seats and harnesses, the rest is stock. [b]Body[/b]:lowered, pumped guards with flares, white with Cyan blue stripes, fake FMIC, front lip spoiler, bonnet scoop [b]Other[/b]:suround sound system and 17" DVD player, 4X4 way 6.5", 2 X 6X9 4 way, 2 tweetwers with splitters and 12" sub and amp, Xplod head unit. *Put pictures here* Thanks Teddy! :)
  14. G'day, how much for a KE20 rear spoiler posted to Brisbane QLD AUS, saw the te27 one, do you advertise on Ebay
