corollaart
    610
    7
Everything posted by corollaart
  1. 2 Hydro here as well :blush: .edit now have 2,after 5 years looking for 1. :yes:
  2. Well if you had the funds to do convertion like that i wouldnt much around with subi stuff. Id go hayabusa converstion :yes: ,these things are crazy 180hp 6speed sequential box. Certianly more bullit prove than subi time bombs and shit gearboxs. Yes i own one, subi that is :) thats my rant cheers rob
  3. Not a expert but w series box completely different to t50,yes it would bolt to engine but i doubt it would bolt to t50. Didnt km36 have a t50 gear box any way :)
  4. don't no of any easy strut converstions ,but you could convert to coil over . seach xt130 strut. Wheel spaces not my choice though :wink: Buy some wheels that fit :yes:
  5. Mate this has got to be the best example of this model ive ever seen,and thats before you started . Now i would like to see a better one any where in the country .[seriously] :yes: Bloody credit to you ,tastefully done . :wink: rob
  6. Theres one on ebay at the minute :S
  7. No it will not fit in to ke30 .just mod your original one .Just finished this on a ke55 barstard of a job :S . But if you take your time and read up on it not to bad. Do a seach heaps of info on this. I will put some pics up later of my convesion. rob
  8. Looking good there ,4age in ke70 do you run amsag or cams rallys.Didnt think they would let you run it in cams events? Unless theres a loop hole some where :) . Good starting with a nice clean shell ,but a lot work,I'm helping a mate put his new subi together lots of man hours. Keep us posted on progess. :P rob
  9. Wow 800 bucks ,it would be rubbish for that just give me his name and number and ill take care of it ;) You would be a fool to miss that even if it is r##ted.I SAY GO FOR IT. :yes:
  10. I would be replaceing the hole switch as your wire man suggested.Because one day or worse night it will fail ,not a good feeling going from head lights to pitch black . cheers rob
  11. Yes its a hydro , well its going to be .talked to toyota today and yes they still sell them new {heap left] Wish it was cable :P but thats ok not that hard to convert.I could give you a picture of it but I'm a old maniac don't no how to upload pics .Total computor web retard. thanks rob :(
  12. Ok thanks for that ,i will check out toyota tommorow cheers rob :P
  13. Yes certainly crazy looking car ,looks like the bonnet has a bit shelby in it. The side vents could suck in small children ,or a eastern grey roo. :P
  14. Hi can some one tell me if there is suppose to be a clip or spring to hold thrust bearing to clutch fork. Its a k-t set up with ta22 box . thanks
  15. Yes what he said,don't no if you could turn the the shoes around as well :) rob
  16. If its a avanti model get the rear disc brakes off it,and axles to.As they bolt up to t series diff. You will need the axle retainer plates off the avanti but not the axles. don't forget the hand brake cables.Just incase you want to up grade to t series diff one day. rob
  17. Yes slack wreakers , don't f##king start me .Having work in one twenty something years ago we use to go out of our way to help people out . These days pay what they want { no bartering} or piss off. Not only that don't come in to the yard because you might fall over and sue me. The omighty dollar has ruined most of the good old wreakers as they crush most cars now , chasing the the scrap money. Not really wreaking yards just scrap yards now .A lot as well just keep commodore and falcon and stuff any think else ,just crush it. Maybe we should start a good wreakers ,bad wreakers thread :worship:
  18. Also try recarb in canberra i think ,good guys and no there carbs .Sorry don't have a number but they sell a lot of kits on ebay as well. Mostly weber but do dellortos to.
  19. I m no expert at it but it sounds like lack of preload .According to mr gregory pinion preload as follows New bearings with seal 1.7_ 3.4 Nm Uesd bearings with seal 1.7-2.8 Nm If collapisble spacer is used for a second time a 0.76 shim must be used. don't no if thats any help or not ,good luck
  20. Yep what he said ,maybe try motor khanas first .As ive seen blokes that are so called drift pro [ WITCH YOU ARE AFTER TEN EVENTS}apparently That have all the power in the world and could not drive there finger up there exhuast :D Learn at the grassroots level ,and work you way up . Or yeah dirt sorts man from boy ::Ari rob
  21. My 2.5 cents worth 2tg are old as me ,or older ,over priced , maybe not over rated but if you find one they will want to much for it. When theres the better ,lighter , more common 4age { more common is that a word } 2tg are for the die hard rally guys. Because stupid cams would let us run 4ages. As for auto don't no. :hmm:
  22. Did you put the clutch plate in the right way?? :hmm:
  23. At last a good example of 4age with a real fuel system ,or am i just showing my age :hmm: Also looks a lot tider engine bay. With out all that cluter of fuel injection and wire bird nest cast over the motor . I like it great job ,i bet it sound good to. rob
  24. 300 ,I think old cock is having a lend of you :y: .Best shop around Id suggest.
  25. +1 for durapro never had any problems :y:
