Hey guys, Alec here.
I've just finished my 4k rebuild and got the motor in my car. Had some dramas regarding idle but got that fixed (carby running too lean). Now i've encountered a whole new problem. So basically my timing is screwy and i have an idea what to do, but not sure how.
Soooooooo here we gooo...
Pretty much, i went to do the timing, got the timing light ready and everything, turned the car on, idles first go, excellent.
I painted everything so to get the timing mark on the crank, i wound the motor over by hand with a screwdriver in the No1 sparkplug hole to find TDC. This also coincided with the dissy pointing at the first lead. okie dokie, all good.
Then when i shine the light on the crank pulley the white mark i marked is nowhere near where it should be. I was under the impression that 8 BTDC is ideal. Mine would be on like 48 or something, way off the scale.
Then i thougt, IDIOT! i had the vac advance on, so i disconected and the car did not want to run, but the mark was closer. I'm stumped :bash:
Could the cam be a tooth out? because fuel system is fine, ignition system is fine, i have no idea!
If the cam is a tooth out, how do i know which way, i understand how to fix it as i've just built the motor, but i'm still learning.
So if because the white mark is to the left of where it should be, do i rotate the cam clockwise one tooth? to get the mark closer to where it should be?
Any help would be appreciated, i'm stuck!
Alec
