78CorollaKE30
    6
78CorollaKE30's Achievements
  1. Does anyone have a diagram (or picture) of the correct way to connect the vacuum lines on a 1978 KE30? I took the carb off to rebuild it (and yes I labled the hoses and carb before I removed it) but I'm not sure if they were ever connected correctly. Also, is there anything I can use to make a gasket where the carb meets the manifold? My rebuild kit didn't come with one Thanks
  2. Yes, all lights work.
  3. After it has sat for a few hours or overnight it usually turns over, but I need to start it (turn the key) and pump the gas about 3 times before it runs on its own. It stalls the first 2 attempts to start. The 3rd time it stays running. Other than that, it just randomly doesn't start.
  4. I have a couple issues with my 1978 KE30 corolla (1.2, manual trans) that I hope you can help me with. 1. It drives great, but when I put the car in neutral when coming to a stop it stalls. However, it will restart if I put it back in gear as long as I am still coasting more than 10/mph. Also, if I pull the choke out before I start braking it will not stall. 2. Sometimes the car will not start. When I turn the key it does nothing...no click, no attempted start, nothing at all. However, if I shift through the gears or wait a few hours it will then turn over. Any thoughts? All the lights work, the blower works etc. so it is not the battery and the starter was just replaced. Any help is greatly appreciated.
  5. I have a couple issues with my 1978 KE30 corolla (1.2, manual trans) that I hope you can help me with. 1. It drives great, but when I put the car in neutral when coming to a stop it stalls. However, it will restart if I put it back in gear as long as I am still coasting more than 10/mph. Also, if I pull the choke out before I start braking it will not stall. 2. Sometimes the car will not start. When I turn the key it does nothing...no click, no attempted start, nothing at all. However, if I shift through the gears or wait a few hours it will then turn over. Any thoughts? All the lights work, the blower works etc. so it is not the battery and the starter was just replaced. Any help is greatly appreciated.
