Medicine_Man
Admin
    3564
    7
Medicine_Man last won the day on March 16 2023
Medicine_Man had the most liked content!
About Medicine_Man
  • Birthday 03/16/1983
Contact Methods
  • Location
    Brisbane, QLD
  • Real Name
    Justin
Recent Profile Visitors
15192158 profile views
Medicine_Man's Achievements
  • Week One Done Rare
  • One Month Later Rare
  • One Year In Rare
Recent Badges
24
  1. It was stipped chemically with regular household paint stripper. Probably hit it with a 60 grit orbital sander disc after the paint was removed.
  2. Nice, just a bunch of small issues. Sounding much better.
  3. Been a while scince I last updated this. Gets hard to find time between work and looking after my daughter. Got the shape back in to the rear window opening now and started filling the dents in the roof where it was vandalized. Think I might need some shrinking around the dent on the drivers side, keeps collapsing on itself when you apply a bit of pressure when filing..
  4. Could use the Camry condensor if you want to, probably has the receiver dryer built in to it.
  5. Boys at work have all the gear to make new lines if you need. Can gas it all up too. Use ae86 condensor and evaporator and 2az compressor.
  6. Best off grabbing the high beam trigger direct from the headlights and mount the relays close to the battery. Basically you just use the 85 and 86 pins to control the relay turning on via high beam. interrupt it with a switch so you can also turn it off when you don't need them (how aftermarket spotlights are legally are required to be wired)
  7. Member Name - Medicine_Man (Justin) Area - Bracken Ridge Daily Drive - 2009 Toyota Hilux Dual Cab (V6) Projects - Yellow KE70 Corolla, Blue AE86 Sprinter
  8. yeah, as long as it is 4mm 7 core you should be fine. Trailer plug should take the load fine!
  9. My old 4K in my KE70 had the tighe 104 grind, was very nice to drive!
  10. Very much enjoyed driving your car the other week, makes me miss driving my corolla. The torque is just unbelievable and makes it so easy to drive, then when you feed it some throttle it just wants to go! And yes, Next generation of rollaclub could not wait, my daughter decided to come 3 weeks early. I am sure you are in for a lot of changes just like us. If you need any tips on the baby we are already learning a lot so don't be afraid to call!
  11. You need a relay with 2 x 87 terminals, if it has 87 and 87a it is a change over relay with a normaly closed and normally open contact. you can run a single pair of driving lights off one relay with no dramas.
  12. Congrats, when is the baby due? Casey is due June 14th.
  13. As far as i am aware there are no issues with float bowl when upriting.. the intake manifolds are a copy from new zealand. sheldon on clubk.co.nz does a kit. though my engine mounts and adaptor plate were genuine items from yahoo auctions japan.
  14. Today I got to cutting the rest of the rust out and welding in the big patch from the cut from teddys old roof..
