calaissix
    21
About calaissix
  • Birthday 06/20/1973
Contact Methods
  • Website URL
    http://
  • ICQ
  • Location
    newcastle
calaissix's Achievements
  1. D is a negative connection
  2. is the clutch disengaging correctly?
  3. when it wont start ,use a jump it at the starter
  4. has to car got a vacuum booster on the brakes and how fast is it idleing?check the ignition switch
  5. sounds like it maybe the dashpot ,bit hard to say without looking at it,as for the return spring question ,make sure the linkage that joins the carbs opens and closes the carbs correctly,full throttle and back to the stop(idle speed)screws on both carbys,if your not sure seek help from a mechanic,as a mechanic ive seen people play with things they don't understand and cost themselves more money,just ask them to have a quick look and quote you and get a few quotes.find an older mechanic as many younger mechanics will struggle with twin carbs.hope this helps
  6. if the radiator is stuffed then the overheating is what probably blow the head gasket.get it check by a pro,its a small investment.get the cooling system pressure tested when its back together to make sure your not loosing coolant
  7. sounds like a jap import engine ,maybe front wheel drive.leave it blocked .some imports needed a little modification to work.
  8. don't bother,it will upset the flow of the carby,if you want greater flow buy a larger carb.
  9. I'm in newy and got a corona so I'm on the outside looking in too.
  10. check what you can legally increase the engine size by before you decide on anything,if its illegal you are liable,if someone gets hurt it could cost you big time
  11. if you have the tools you can do it yourself if your keen,but it is hard without the tools,the rest is just practise.best of luck ive just about finished that part of mt rt142 that looked a lot like that,but i have to do the whole car .if you fix one dent then you got to do them all.
  12. ask a bumper reconditioner,they usually sell heaps of that kind of stuff
  13. couldnt advise you but the suspension specialist does it for a living so he should know,ask another suspension place.they are the specialists
  14. catch the bus or buy a motor bike,cars don't run for free! its got power everything and ac and they need power to run ,still produces about 100kw can't get something for nothing
  15. is it internal regulator or external,if its external it may be in the regulator ,which means changing the alternator probably will have no effect!
