original
    85
Everything posted by original
  1. so, so, so angry right now.... turns out some f@$king iron dust got in under the Circuit Opening Relay and was holding the switch open and because its magnetised, it would not move :wub: cheers kebin and medicine_man for your help. now to finish my diagrams and understand this mess :D
  2. believe it or not it was an auto sparky :wub: as per this diagram where to 10A Ignition and 15A Efi go?
  3. This is how the relays map out and how i believe they connect based on the club4ag wiring diagram, my engine bay and its colours. gotta get a multi meter with buzzer so i can check a couple more things. is this what it should look like?
  4. yes there is a circuit opening relay, diagram says there is a fuel pump relay, but its a conversion so can't be sure
  5. ok, so no prime on cranking. getting no voltage reading across the fuel pump. what else can I check?
  6. cheers, ill add that to the list of things todo tomorrow
  7. just eliminating a few things while trying to get my car started. Does the standard gze ecu prime the fuel pump when the key is in the "on" position? or is that an after market thing? Cheers,
  8. KE35 4AGZE Time: 14.780sec R/T: 0.320 2/12/09 Is there a leader board somewhere? or do we have to go through all the pages to work it out?
  9. Right... Its about time I updated this. 2 of December saw another outing to Eastern Creek after fixing all the previous broken stuff. Got 6 runs in this time and nothing broke :blinks: Time: 14.819sec R/T: 0.697 Time: 14.875sec R/T: 0.609 Time: 15.914sec R/T: 0.294 Time: 15.959sec R/T: 0.351 Time: 15.026sec R/T: 0.528 Time: 14.780sec R/T: 0.320 Couple of weekends later a mission to Bathurst was undertaken to visit FBC (Beau) to fit these puppies Cheers Beau Please check out my wishlist/todo to help out! now to fix stuff till next time...
  10. Could someone tell me what would cause my intercooler piping to be lined with this? Doesnt smell oily No milky sludge under the oil cap Oil is topped up Water is topped up has been getting rather warm lately burns 2 sec of oil on ignition (valve stem seals?) breather and catch tank to fix perhaps?
  11. Bout time I got the rolla out again for a spin, will be at the WSID this wednesday (2 december) if anyone else is keen. keen to make this a regular event if anyone else is too
  12. if the 35 is still running after wednesday, I might meet you all at Palmy.
  13. Model of Holden commodore the diff was taken from
  14. hmm... shortened diff so I'm going to have to get my axles shortened too. There is no alternative to shortening axles or screwing bearings?
  15. Cheers guys, thanks for the quick replies. I'll look into it. If there is anyone in northern Sydney who wants to give me a hand that would be great
  16. So my drums are screwed and I figured I'd do the conversion while I'm in there fixing the old. So my question is has anyone done this and is anyone keen to give me a hand to do it. It's my daily so I'd be keen to do it asap. Also if anyone is near a wreckers who has seen the required parts and is keen to grab them and post them that would be great.
  17. Are these just the standard item or pulled from another vehicle? the W55 end is the single lock pin type
  18. sorry the correct term should have been cranks, was in a hurry. main link to the ecu at the main fuse had come loose when I was inspecting the headlight relay, which fooled me into thinking the ecu was dead Now to fix my lights :jamie:
  19. Nevermind, fixed. feel stupid now :dance:
  20. Right, just need another brain to confirm that Ive cooked my ECU. Yesterday I was trying to fix my head light when I blew some fuses, but think I blew more than that. For a bit I had limp home mode, but then everything died, no engine light, no fuel prime, nothing. All other electrics, lights, stereo, heater etc are all still fine. Pulled the ECU out and it just revs as if it was still plugged. Anyone got one I could borrow and perhaps buy if it fixes it? Cheers
  21. Hey, so my handbrake cable has gone loose and I can't tighten it anymore. Can anyone with a ke3x and vl borgwarner diff recommend a cable to go with it?
  22. does anyone have pics of standard and what they changed to? ie. stock ke35 and then NC pajero with intake in the pic for comparrison sake.
  23. what are your coils from? 1/2zzfe?
