SLO-030
Senior Member
    4683
    16
Everything posted by SLO-030
  1. Tap it into the wire going from the barrel to the fuse board.
  2. This is the SC pipe routing i shall be basing my piping and carb placement on my 4KZ. Thanks to kickin5k for the pic :y:
  3. Done :P
  4. I got my 2 last night :y: also on a darker note; WARNING!! don't Leave calender in a hot car. Had one of mine sitting in the footwell of my 30. went to go get it to show off at work, and the heat had melted the ink. glueing the pages together = pages ripping and getting damaged as you open the calender. just thought id let everyone know to minimize other calender losses :P
  5. Not sure about the ke55's but the ke70 had it for sure. EGR stands for Exhaust Gas Recirculation and uses already burnt gasses to apparantly improve ecconomy, not that K engines needed it. Oh and both KE1x and ke2x didnt have brake boosters. Ke3x onwards did. Manifolds are easy to drill and tap to accomodate a vacuum port for a booster line EGR "plumbing" outlined in red. The "hotbox" or "stove top circled in green :P
  6. EXACTLY what I'm looking for, VL pump has a 3/8 feed on it too :y: PM'd :P
  7. some 3k's wont have the oulets nor "plumbing" for the EGR. so they WILL bolt up. just depends what engine each manifold is from. I know of 3 different exhaust manifolds, there may be more? 1 i had on my ke25. single outlet, 2 bolt flange ( not the best option in my opinion) the 1 i have on my ke30 2 small outlets. Bolts to a twin pipe that merges into 1. kinda like 4-2-1 style extractors. And the one i have off the 2 ke70 4k's i have had. single outlet. bigger that the one i had on my ke25. I myself would run with the 3-2-1 manifolds.
  8. the siren power is for the internal battery the siren has as its a battery back up siren, so it goes straight to a un switched 12+volt supply (mine goes directly to the positive battery terminal) . This meaning that if someone decides to disconnect the battery as a way to over ride the alarm the sire has its own power to jeep it going till you disarm it. the one i have will apparantly go for 8 hrs :y:
  9. Using electric lift and fuel pump and FPR
  10. SLO-030
    Spotted
    that would be RLA 069 from on here, if my memory serves me correctly
  11. Bianca, thats what i was tryin to say on msn. Ryan just worded it better :y:
  12. RX8 can't see you wanting to lower yourself back to pistons anytime soon :y:
  13. Green machine :y:
  14. I have a spare seat in the 30 if u wanna make it but can't drive.
  15. I haven used the HD one yet but i can't see it being heaps harder than a std duty clutch. and its not liek a button clutch that doesnt have any slip in it.
  16. oooooooooh. i see :(
  17. I got told it had ke30 calipers on there when i had it. straight from the guy that owned it.
  18. Carbs Finally here :( Muchos gracias Tom (philbey) Stromberg 175 CD-2 Just waiting on a surge tank to pop up and thats my fuel system sorted. Yeeeewwwww Came with a plate (pictured) that apparantly suits a K&N filter and also has a mount for the Accelerator cable. All for the price fo a kesev starter motor :wink: Like i said before many many thanks Tom
  19. if all else fails. get a Exedy HD clutch like i did. pics of said clutch in my thread :(
  20. Jason, Bob Jane owns Adelaide International :(
  21. nothing like a bit of carrot in ya lettuce
  22. fair enough. I have a PBR MC so i think thats a good indication i have an AMI built 30. Sorry for the off topicness Luc :(
  23. Yea crusie sounds good. might just meet up with you guys at the bay, see what happens. Bianca: WATCH OUT!!!!! theres a KE70 blocking the view of your 55 :(
