SLO-030
Senior Member
    4683
    16
Everything posted by SLO-030
  1. I think I'm gonna drop a manual diff into it at some point. with the lower ratio auto diff she's all revs and not so much go :bash:
  2. I forgot to mention that the friday that the rolla came off defect Luc came round with his shockers and leaf springs. SO the ol girl has got Gabriel shocks in the rear and some newer lowered leaves. rides so much better. i can believe that i put up with flips and shagged shocks for so long. gotta pay Luc for the shocks and line up another set of leaves. Next on the list is new brake pads and shoes and rear drums possibly. and new gabriels in the front then i can put the new lowered springs in the front. should handle like a factory fresh rolla. hopefully. Took it for a hills run last night and i have the JDMs back on due to clearing the defect. The sound of screaching tyres around corners sounded so good for some reason. :bash: Also, ive noticed while driving, when you put your foot down it seems to lag a little bit till the revs build up a bit then goes pretty good. Considering its just a stocko 4k with a 3k head it goes soo muich harder than the old one. I'm gonna need to put a resi in the exhaust soon and fix up the hole where the pipe meets the extractors as Luc cut it too short when he was using the system. i think that could help a little bit as it seems to lack a bit in the bottom end torque which could explain for the laginess explained above.
  3. OKAY!!!!
  4. Google the Part number. Heres what came up for: 89661-316D0 http://www.toymods.net/forums/archive/index.php/t-43434.html
  5. IVe seen it personally and the bracket will make no difference as the original radiator support covers the same area. So unless jason cuts the radiator support having the radiator mount like that or not it wouldnt really make a difference. Id personally keep the radiator partially covered because there is such a thing as running an engine too cold. which is why I'm gonna get a thermo switch for my thermo as it hardly gets off the cold mark on the temp gauge.
  6. They're kings that i got reset at work. The pedders man said to just wire the f@$kers in to stop them coming out.
  7. And how long did it last? Not like overboosting will kill it right away tho.
  8. I heard that the 4k flywheel is lighter than the 3k one. Not sure on it tho.
  9. Post up the route. I'm keen to have a look.
  10. Oh yea brew, it was like a V12 yo. blew 1m flames out the exhausts. wast heaps sick ayyyy. HAHAHA, i have the recipie. Your mum owed me :bash: Yea, considering that head.
  11. DEEEEEVVVOOO don't worry, she'll be up and running soon :P
  12. Ugh, where do i start. The ke30 auto crossmember is in a different spot to the manual one. so welede a plat under the gearbox mount and to the crossmember. Snapped a bolt in the inspection plate on the back of the head so i packed it with gasket cement but it dint work when it was filled with coolant. So more gasket cement. still leaked. Some other gasket goo. still leaked. so pored some seal up in the radiator and it fixed it while it was running but the leak came back when it cooled. Just gonna top it up before i goto work and come home. Friction plate was on backwards :P Got told the protruding side when towads the flywheel :P pretty easy to unhook the box and fix it all up.
  13. SLO-030
    My Ke20
    Where is the Location that you took those pics. might have to go for a drive once i get he front panel fixed. But for Very very quick pic they turned out rather well IMO
  14. I second both of the above.
  15. Details? Vinyl cutting yea?
  16. Put in a 4k/5spd :P
  17. Sounds like its all ready to go just about. :P Come upto jasons if you get it fixed today. We shall be there finishing off the conversion.
  18. a RWD AE80? :P I say, hes wrong :P
  19. SLO-030
    Spotted
    What did it fetch and who owns the ol girl now? 4AGE :P :P
  20. SLO-030
    My Ke20
    That Pic is calender worthy Two thumbs up.
  21. Jason provided some of the drinks and i provided some more. Jasons mum made some wicked sausage scrolls. two thumbs up. Sheena did provide me with a lift back to my joint in the MX5 to get some Loctite master gasket.
  22. NOOOOOOOOOOO. AE8* were the first Fwd generation with the EXCEPTION of the AE86. AE86 was the LAST Rwd rolla
  23. SLO-030
    My Ke20
    You work on Port Rd, yes? EDIT: Read other thread, question answered :P Lookin' good in the flesh, anymore plans on this beast?
  24. I got one whats it worth to ya?
