waterbased
    8
waterbased's Achievements
  1. really?? it means i would never brush the head so hard rite?? :lolcry: i think i have make mistake there... :) when i finish planed the head and block, i put it together without head gasket and there have a bit of allowance between them(bout 0.1-0.2mm)... i didnt know how to describe it.... but what i can see that the head may not straight enuff. looks like the head tilt a bit. but when i put head gasket between them the allowance didnt occurs. am i going to have replaned the head again or it just allrite.. :bash:
  2. thanks taz.. so much infos i gain here. i really don't know they have their own "built in" goo. :n: yup... i planed the head and block with the steel brush.
  3. please forgive me.... what do u mean by "goo"... different region used different phrase to describe something. do u mean the glue... or silicon.?? i replace the old head gasket with the new one and i used gasket "lacquer"(i used to call it lacquer coz the colour looks like that, but i don't even know it real name) and small amount of silicon.
  4. yeah... i got my lessons... never put much gasket silicon gum. previously there is a gasket leakage and coolant liquid get into the pistons. this is my first time i remove the head from the block. and 2nd lessons... i must test the valve leakage after i grind it. so now.. i'm not satisfied with her performance. my timing going worst, up and down. is there any solution for the unstable timing.?? :(
  5. before i use the bottle, the hose from the rocker cover connected to the waste pipe (just behind the bottle). but there is some problem with the piping when the machine goes to high rev which is the hose will pull off from the pipe. maybe the pipe stuck by the carbon dung. I'm not sure bout the choke cable.. is it at the wrong spot?? if so... where it should be?? :( previously i remove the aircond unit to ease me to do some body works to the interior, where i have to repair the leakage. i've look into the motor.. and there is toyotapet logo and number 54.. what does it mean??
  6. yup.. there is a letter A on the head wall. does it mean this is an A type engine? :( how bout the capacity? am i going to measure the block bore and stroke? or is there any other solution? below is one of the engine pix. i'll send another later.
  7. hye... i am from malaysia, which is located @ south east asia. i own ke20 2drs. how i want to check my engine type. is there any number or shape represent the type. since there are combination heads and block, i can't determine the actual capacity and its hard for me to make some mods. :( i hope we can share some info. thx..
  8. hye everyone... I'm newbies here.. perhaps share some infos. waterbased a.k.a hairul mocha ke20 2 drs
