tolisspi
    15
tolisspi's Achievements
  1. Good car mate!
  2. You have done very good work to your car
  3. is it really that the springs of twincam can't be fit to the soch?
  4. So, i have the good bigport
  5. And the blue and black letters how many hp?
  6. i transfer the tachometer from under the wheel to near the wheel New PIAA xtreme lamps and New corner lights with indicator My new strut bar. I bought from AUS, very cheap. Thx a lot... and some other pics. Some other pics with snow!
  7. At this moment i am thinking for something better. What do you propose? 4agze?
  8. Ok, i forget the clutch disc for 350hp. So can i easy fit a 4AGZE clutch kit original TOYOTA with a light flywheel aftermarket on my 4age tvis? Is it worth? The clutch kit that i have now it has 8.000km. sorry my english is bad.
  9. I have the opportunity to have a clutch disc exedy 6puck strong for 350hp and 50kg torque (i think). The diameter is 212mm. So if i want to fit it in my 4age 16v (bluetop) i have to change also the clutch cover, bearing and the flywheel? Its worth something like that to "pass" the hp on the wheels? How many hp (%) can i pass with this mod (if its possible to counter it)? If i buy clutch disc, cover, Light Weight Flywheel, and bearing, i think to cost me 1000$AUD This moment i have TOYOTA OEM parts with clutch disc 200mm(i think) Or do you think it worth to fit a clutch kit, flywheel aftermarket (e.x. exedy or toda) with diameter 200mm, there would be a noticeable change?
  10. To do or not to do???? Paint the hood black or put sticker type carbon or nothing? What do you think? I shall put films on the windows.
  11. Hey from Greece COROLLA EE80 5door 1986 4AGE-TVIS from Greece.It was my father's car and i took it and i fit an AE92 on it.It is speedly,funny and i don't want change it for nothing. .......................INFOCAR........................... Original Car Manufacturer: Toyota Model: Corolla EE80 Year: 1986 Engine Type: 2E 12Valve Engine Size: 1300cc Horse Power: 75HP/6000 MODIFIED STUFFS Engine Type: 4A-GE TVIS (no cat) Compression Ratio: 10:1 Max. Horse Power: 124HP(91Kw)/6600rpm (7800 Revs limit) Max. Torque: 14,5Kgm/5200rpm Engine Mods Engine mounts: 2 mounts 2E engine (EE80), 1 mount 4AC engine (AE82), 1 mount 4AGE engine (AE82 Twincam) Spark Plugs: 4 TRD DENSO IRIDIUM POWER IK20 Spark Plug Cord Set: TRD 7mm Adjusting Campulleys (Cam Gears): TODA Racing Timing Belt: TODA Racing Air Filter: HKS Super Mega Flow Reloaded or K&N High Flow Cone or GREEN Cone Fuel Pump: BOSCH from Opel Calibra 2.0T Chassis Mods Suspension: KYB EXCEL G and JAMEX springs (-4cm) [stabilizer Bar:[/u] AE82 Twincam Stabilizer Bar (Front 23mm and Rear 13mm[EE80]) Tower Bar (Strut Bar): AE82 Twincam (front) Brakes Mods Brake System: AE92 Early Spec car ('87-'89) Brake Discs: EBC Turbo Groove Brake Disc Front (238x18mm) and EBC Standard Brake Disc Rear (242x9mm) Brake Pads: EBC Greenstuff Front and Rear Brake Pump: AE92 Tyres & Wheels Tyres: MICHELIN PILOT EXALTO 185/60 R14 or PIRELLI P6 195/50 R15 Wheels: 6X14" ENKEI or 6,5X15 OZ RACING GEMINI Exhaust System Manifold, Down Pipe: OEM AE82 Twincam Front/Rear Silencer, Tail Pipe: WALKER AE82 SPORT Other Stuff - TRD Radiator Cap - TRD Oil Filter Cap - TRD Fuel Cap - TRD Air Valve Cap - PIAA Bulbs H4 Xtreme White Plus for Headlights - PIAA Miniature Bulbs Xtreme White for Corner Lights Audio - PIONEER DEH-P5900MP - AudioSpeakers SONY 120x4 Interior - MOMO MILLENIUM Steering Wheel - Simoni Racing Gear Shift Knob - Custom Handbrake Knob - Simoni Racing Tachometer - SPARCO Pedals - MOMO Floor Mats - SPARCO Harness Pads - AE82 Interior Parts DYNO TEST (ATW) (w/o TODA cam gears) 103,2 HP/6900 rpm 12,2 kgm/5500 rpm TEST DRIVE Geared Speeds (Km/h) (with GPS) 1st: 50 (7800rpm) 2nd: 100 (7800rpm) 3rd: 145 (7800rpm) 4th: 195 (7800rpm) 5th: 206+ (7000rpm) Accelaration 0-100Km/h: 9sec (estimate) Some pics from my car...
