08ftw
    142
Everything posted by 08ftw
  1. Needs a gold centre :happy:
  2. Some more parts arrived this week :happy:
  3. Ok cool, pretty much the same sort of prep work I was planning on doing to mine! Thanks for the tips :rolls:
  4. What are you painting all your suspension bits? & What sort of prep work do you do to them?
  5. This thing is bangin, you seem pretty good with the paint, should come and hit my suspension bits up :P
  6. moarffffinpics!
  7. Haha yea should be sweet once they are both done :P Stock cam's until I get a handle on it. I have a spare small port head, so I will most likely put a stock reco'd one on it, and work the ffff out of the other one...so I can just bolt it straight on!
  8. Ok, so the story began after I acquired another ke70 corolla after my first one was written off. This one is a late model ke70, so it has the slant front head lights, automatic, 1.3l 4k. The plan was to stick a 4age in it, coilovers, LSD, stripped interior, strut bracing and some ma61 rims. Only thing was, my mind wandered away from 4age’s, I wasn’t entirely interested in putting one in my car, I would have liked a bit more power. So after talking to a few people (little red spirit, 70xin, beerhead, samQ, hao), I decided to go down the route of a 7age, objective; mainly a sprints vehicle with hillclimb and the occasional drift. It has taken A LOT of research, lots of questions, and I am sure the guys above are absolutely sick of the pointless questions over the last 9 months. Anyway, so I bit the bullet, I went and bought a 7afe, $450 from a local wrecker, very common motor, if you are thinking about buying one, ask around, get the best price for a running engine and go from there. Next up was the head and pistons. After a lot of advice from other, more knowledgeable people I chose the 16v 4age small port head and pistons to make up the GE section of the motor. My reasoning, well it seemed like a much cheaper option, and more aftermarket parts seemed to be available when it came down to cams & such. I also picked up some 20V silver top throttle bodies instead of just using the stock 4age inlet manifold. The throttle bodies will be bolted to the head with an T3 adaptor plate supplied by spirited drive, and also a vacuum block will be used to ensure even vacuum distribution between the ITB’s. The head will receive a slight deck (just to get it square), vacuum test of the combustion chamber, valve lapping, match port and complete VRS kit. I know that using a stock head isn’t the way to build a race motor, but cams and such can be changed at a later date with out removing the engine, plus I have a spare head to work on whilst I get the hang of the car in the mean time! The bottom end will consist of 7afe crank, SPOOL 7afe H-beam forged connecting rods fitted with ARP head studs, ARP race bearings through out, and a complete balance from flywheel > pistons. Crank will be linished (casting marks removed), the block will be decked, and bores depeding on their condition will be honed or bored, hoping to get away with just a hone. All parts will finally be acid cleaned before assembly. Stock small port pistons will be used, just so the compression ratio doesn’t climb into the 13’s, as will a stock small port headgasket. I will also have a set of T3 adjustable cam gears on the front. Once the engine is assembled, it will be fitted to the car, with an adaptronic e420c ecu wired in by beerhead. Reasoning for the e420c is because I haven’t heard anything but good things about the Adaptronic ecu, I didn’t like the idea of running with the stock computer with the throttle bodies either, and just to hopefully squeeze a little more power out of this baby, oh, and I got it pretty cheap as well! Putting the power through to the wheels will be a t50, and as for a diff, well I am not entirely sure yet! Wheels will be ma61 rims with semi slicks most likely, and another set of 13x7 hotwires to run on the street. Front end has JDM coilovers with rebuilt tokico shocks so the valving has been removed, not desireable, but I will see how the go, coilover kit seems to be of the craft with an unknown spring rate (haven’t been bothered to go to a suspension shop to test them yet). Super pro bush’s all round, new LCA ball joints on stock control arms, tein camber tops, ADM brake calipers with JDM disk and reduced thickness brake pad. Anti roll bars will be left stock with nolathane bush’s for the moment, will see how that goes, if I need to bigger I will! Interior will be stripped with two bucket seats for the moment, most likely velo milano’s or something similar. Only thing left will be the centre console and dash, + the door cards. I know I have left a whole lot of shit out in this big spiel, but it’s hard to put it all in one story. If you have any questions, feel free to ask, I will try to post some pictures of parts as the come in, and as things get done on the car. Things move slowly around here, 3rd year apprentice wages make it tough to build a no-expenses spared weekend car. Anyway, this is my list of parts: 1. late model ke70, straight 2. 7afe 3. 16v small port complete engine with ecu and loom 4. Spool conrods 5. Adaptronic e420c 6. Silver top ITB's 7. 2x t50 8. 7age conversion gear (xmembers, pedal box etc.) 9. Jap coilovers (front) with tein camber tops with adm calipers 10. Stock steering arms and control arms 11. Anti roll bars 12. 6x ma61 rims including centre caps What I need: 1. All superBRO bush's, balljoints etc for suspension 2. Quad adaptor plate 3. Pistons (will come after engine builder gives the advice) 4. All bearings seals and gaskets 5. New water pump 6. Recond of alternator. 7. Tyres 8. 2x Velo fixed backs 9. Steering wheel And a whole heap of other stuff... Can't think of it all at the moment. Progress will be slow, not much has happened in the last 12 months, just lots of parts hoarding. I don't have much in the way of pictures, as there isn't too much to see! Oh, by the way it isn't a 2000hp 20b twin turbo rotary. Anywayyy here are all the photos! Part's all layed out :D 7age all ready to go....not! Yummy :) Coilovers with adm calipers! Ebay oil cooler Silver top itb's Storage & smallport with t50 etc! Pretty good investment when you are strapped for space :) Smallport with loom, ecu & t50! Sparesss mmm Spare diff & t50 Small bit of rust! How she's sat for the last couple of months...Soon to change! The bum! Pedal box installed... I've never actually seen anyone take a photo of this, so here one is! Yummy! most of this will stay, including my penthouse girl who came complimentary with the car ;) Like a boss! quickrelease boss kit Still definately needs a tidy up, but it's been degreased! Master cyl (clutch) Came up so clean! Small amount of rust, hard to see though! Will end up pretty much the same as Matt's were when he rolled his :P YUMMMOOOO! WOOP WOOP Anyone want some bricks? :) I seriously want them off my drivewaayy! So yea, that's mostly it. There is a few more goodies coming this week :) And this thing is getting a little bit more of a move on! Thanks for reading! xoxoxoxoxox
  9. You've outdone yourself once again Matt. Can't wait to be cruising with you. I would be happy if my car was 3/4 of this :laff: Haha.
  10. Forgot to add, pictures really don't justify how mother ffffing sexy this car is, haven't had a ke turn me on so much even with the qaurter panels off and half the wiring loom hanging >|
  11. That certainly is a nice fan shroud, should work really effectively... Next step is to make some shrouding to direct all the air into the radiator at the front, if you know what i mean.
  12. If you need any help I'm always a phone call away, sucks about your back, just when I'm about to throw the small port in mine!
  13. I wouldn't pay $15000 for it... Would probably pay $14990 though!
  14. Who gives a F*** what he is compensating for. As if you wouldn't own that boat if you had the money!
  15. Leave them silver mitch. They look tough as, you need some more low and some camber up in this baby. You're a roughie with your caliper paint :lol: haha.
  16. Go 14'sssss 15 is too big. Looks tidy as mitch, dunno if i will be home tommorow night? If i am i will message you dawg.
  17. Good news mitttcchhh :)!! Can't wait to get rollin northside again!
  18. IMO it would have looked alot better if you just had a black stripe. Owell good effort.
  19. Tidy, those wheels don't really suit though.
  20. Clean as my room mitch dawgg :) 5k this bitch up
  21. You probably get asked this ALL the time, but want to sell the rona wagon :y:
  22. Nice dude, looks like a qaulity build!
  23. I had the same feelings about xt130's before i put them in my old rolla, but to tell you the truth with 6 months of driving everywhere in the car, especially brisbane 5-0 hot spots, they really didn't pay any attention. Althought mine wasn't loud or anything like that, i really don't think it would have changed much as long as you keep it looking respectable. When you look at most mid 80s rwds, the are sporting about 1.5deg neg camber, when you see an e30 have a look at the camber they are running, xt130's give barely any camber compared to them :P
  24. Been a while since i've read this, gaurds look awesome man! hows the 5k going? still strong?
  25. 08ftw
    Spotted Qld
    spotted medicine man on toowong roundabout today. still looks tough as ever
