Some more work done on the AE86.
Got all my mintex 1144 brake pads in. Rears went straight in, but the fronts were a bit of a pain. Would not go in although they looked the same. Finally noticed the scalloping on the trailing edge of the pad was slightly shorter on the mintex pads. Bit of a hit with the bench grinder and in they went.
Jumped in the drivers seat for a bit of an imaginary fang the other day, brushing the clutch pedal as I did. Seized solid. Hmmm. Picked up a master and slave real cheap on US ebay, but when it got here, the flange for the LHD master is different.... Oh well. Pulled the old one off to rebuild with the new parts. Long soak in WD40 and finally managed to blow the old piston out. Interestingly, there was only a small amount of rust around the firewall end of the bore. Cleaned up beautifully, reassemble with the new bits after a repaint of the master cylinder and it's as good as new. Repainted a bit of the firewall where some clutch fluid had bubbled the paint, fun trying to get the paint can in around brake master and inlet manifold but managed to keep paint off everything else. Should have done that when all that stuff was out of the car, but am glad it is done. It's the little things like this that take up so much time.
Engine turns over freely after popping a bit of oil on top of the pistons. Hadn't run for about 4 years, so was slightly worried, but no resistance at all. May be alright there.
Finally put the passenger side guard back on today, now almost looks like a car. Only panel left to put back is the driver side guard, although it is a white one as the old one had some rust in it, so will need to get around to spraying it. May look on AE86DC for an original red one as can't really be fagged spraying it.
So what is left? Other than the guard, put the inside sunroof panel in which will likely mean pulling the sunroof out, bleed the hydraulics, check the dizzy positioning, get the car off the axle stands and tighten the various bushes. Then the big one. Connect the battery and see if it catches fire.
The other thing I need to do is address the front inserts. Springs aren't captive at the moment and thinking about some SW20 KYB AGX front inserts with the T3 tube spacer. Aus to US dollar is pretty damn good so might be the way to go.
