parrot
    3017
    79
Everything posted by parrot
  1. Hopefully not to much drone
  2. Currently on eBay https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F323483320718 You may find he will accept an offer of $95.
  3. Rear guards usually require refabricating inside the guard.
  4. I should add, after a speed event we would swap the spring back so the second Venturi only opened as per factory, or you lose flexibility for around town driving.
  5. I assume that’s the old “swap the spring from one side of the diaphragm to the other” trick. I’d forgotten all about that. We used to do that back in the 80’s club racing days. But soon it was a slippery slope to twin side drafts Ah the memories!
  6. Yes definitely agree with the oil in the plug hole. I left that out
  7. I would take the plugs out and turn it over in bursts of about 5 seconds about 7 or 8 times. Then put the plugs back in. Should have oil pressure by then and fuel to the carb. Double check no fuel leaks then fire it up
  8. You have to question why Toyota ever went with that design in the first place. I can’t recall ever having seen another 2 piece manifold gasket.
  9. Shouldn’t be too hard. Lots of later corolla’s had cable release. I would visit a wreckers and take something complete from the earliest toyota I could find with it. For example, ae86 coupes have them, and I’m sure our AE82 seca had one. Your hardest task may be getting the cable length right.
  10. That’s an amazing story, and congrats on getting it this far without being shot in the process. The install certainly looks looks pretty neat
  11. That's awesome. You shouldn't have told people about the pineapple tins. You could have started a business and retired on the proceeds! Great to hear it is running so well. As a boy, dad and I used to do an annual Melbourne - Labrador - Melbourne trip and his KE20 just ate up the kilometres along the old back route through Dubbo, Goondawindi etc. Good times
  12. Shack...... that is the awesomest shack I have ever seen. We are currently in the process of arranging a second renovation after I got a bit shitty and insisted I needed a new (bigger) shed, and showed the piece of rotten bearer I cut out and replaced so i could open the back doors of the existing 100yr old timber shed. Plus my sons cricket bat repair business has gone ballistic, so everything in there is permanently covered in sawdust. Bits of bat, grips, and assorted wood working tools are strewn everywhere. So he gets his own attached workshop. But no, a draftsperson isn't good enough. So now we are going through the consultative process with a "green' architect, and it has grown to potentially adding a story to the house etc etc etc. Grand designs has a lot to answer for....... Check back in a couple of years and with luck it will be out to tender.
  13. The bearing shops have amazing lists cross referenced to a blinding array of genuine and aftermarket part numbers. And often much cheaper than you would expect.
  14. I can't imagine why you would want to do that? Is it because you are looking for a cheap way to get the car going after cracking a twin cam head? if so, depending on what car you are putting it in, you will need to work around different sensors, engine computers, fuelling etc I think you need to give a bit more info
  15. It’s tempting. A rare weekend without any kids sport
  16. I’ve gone through the library but can’t find any references to dates of manufacture in the various parts books etc. I believe mine is a Feb 1969 car. I can’t remember why, as it’s been a while. But my body number is KE15176xxx (number obscured obviously) so I would assume yours was built after mine making it a 1969 model. Is there any particular reason you ask?
  17. I wondered if Jeremy had used up all the bandwidth
  18. A 4A type RWD T50 is 1.7 litres as Rob said. A 2T type RWD T50 is 1.5 litres. Where are you filling it from, the fill plug in the side of the box, or through the gearstick hole in the extension housing. If the latter, you generally have to be pretty patient and let oil drain away before adding more.
  19. Last time I went to the effort to do that, someone started selling the files on eBay.
  20. I recently copied it for one of the other guys, but not keen on doing that again. It’s 100 pages and a very large file, too big to email. The various manuals available on eBay cover it pretty well if you are really keen. Gearboxes aren’t for the faint hearted
  21. I’ve never understood the attraction of massive horsepower in a totally unsuited chassis with such a short wheelbase. Why wouldn’t you choose a more suitable chassis to start with, rather than engineer the thing within an inch of its life. don't get me wrong, I admire the execution and thought that goes into it. I really must get to Leyburn one day.
  22. Your engines in back to front! I’ve heard of uprighting but that’s ridiculous.
  23. That car knew something I didn't, and is laughing at me now......
