parrot
    3016
    79
parrot last won the day on July 19 2024
parrot had the most liked content!
2 Followers
About parrot
  • Birthday 04/09/1965
Contact Methods
  • Website URL
    http://
  • ICQ
  • Location
    Melbourne
  • Real Name
    Pete
Recent Profile Visitors
25470538 profile views
parrot's Achievements
Collaborator
Collaborator (7/14)
  • Reacting Well Rare
  • Conversation Starter Rare
  • Very Popular Rare
  • Dedicated Rare
  • First Post Rare
Recent Badges
166
  1. I've had a look at the parts book and it is clear that the actuating mechanism inside the steering box differs between the models. And as the 'worm' on the steering shaft is integral, you can't put the KE2x steering shaft into the KE1x steering box.
  2. Thanks Stu. I think the thing is whether the KE15 steering box will bolt to the KE25 column, and whether I should bother. I managed to pick up the brackets and so forth for a KE1x collapsible column from japan (presumably someone else had earlier bought the column) so mounting the column under the dash should be easy.
  3. Have had an enjoyable hour searching the forum and seeing all the old names whilst researching what is involved in putting a KE2x column into a KE15. Should I fit the entire KE2x column/steering box, or fit the KE2x column to the KE15 steering box, if that is even possible? Comparing side by side it is clear I would need to use the KE15 pitman arm. The bolt pattern to the rail is extremely close although the KE2x box uses M10's rather than M8's. No I'm not interested in converting it to R & P. Hoping Tommys Ke 11 is still here as he featured in the most informative threads without saying how he did it. As was kickn5K. Must be a Stuart thing.
  4. Not mine, may be what you are looking for https://www.facebook.com/share/p/1Bv6vin7ad/?mibextid=wwXIfr
  5. It won't be available from Toyota. As mentioned, find a specialist who can refurbish the mechanism and replace the webbing. We have them in Australia so no doubt you will find someone over there.
  6. That recore cost is ridiculous and you are getting ripped. Go somewhere else
  7. How much did they charge to dip the apron? I’m avoiding stripping the cowl cover on the KE15 after returning from sometime away OS.
  8. Would be a fascinating trip, but a bit close to Lebanon for my liking. There’s a couple of Cyprus sellers on eBay with a regular treasure trove of NOS parts. I often wonder if they have some sort of access and are secreting things out.
  9. You are strolling down some scrappy flea market in Portugal looking for Italian pottery for the wife who you have left in Australia (salves the guilt), see a distributor on a tarp and within a millisecond, know it’s for a 3K without even bending down. €8. I don’t actually have any guilt, but I am missing the dogs.
  10. There’s nothing specific about an SL that can’t be bolted in, and no one has taken the time to work out if there is a body number factor. I very much doubt that. So no reason why SL parts can’t be sourced and bolted/screwed into a less specced model.
  11. This is a spare one I have. Nothing else fits and will require complete fabrication. I’ve also got TE27 and it is totally different
  12. Can you show us what the clips look like and where they go?
  13. Do you really need coilovers?
  14. The first thing I would be doing is checking the float level in the carb (carb rebuild raises a flag). Edit, saw you have electric ignition.
  15. Only 16 yrs later! I wonder if he still has the car? I don't know if there is a more expensive small Jap car getting around than an RX3 currently, and I'd hate to think how much an RX3 rear end is worth.
