slippry
    20
Everything posted by slippry
  1. i run a baffled efi tank, what is stock fuel pressure then?
  2. ive upgraded my fuel pump to a vl turbo pump, so what would be a good fuel pressure to fun it at? i had fuel lean issues, that why i needed to upgrade
  3. i think ill switch back to standard jdm injectors, what will be a good fuel pressure to run it at?
  4. hi i have a 4age in a ae86, i changed my injectors the other day from 182cc grey injectors to 250cc green injectors, it runs alot richer now, how can i lean it out more? when i had it dynoed it made 69.7 rwkw, but was very lean after 6000 rpm have advanced the timing to 16 deg, have put new fuel lines and hard lines in too original injectors cleaned 182cc, dark grey, 2.0ohm, 23250-16010 (AE86 4AGE) new injectors cleaned 250cc, green, 13.8ohm, 23250-16110 (7mge) running a fuel pressure regulator and vl turbo fuel pump 070
  5. the nortehrn side of town has better twisties good runs etc can link through to down south via the long way around to mt lofty then to clarendon
  6. would they let me enter my ae86? or it has to be minimum 30 yo old? \
  7. just use a ae86 strut brace but don't get the flat type cusco they wont fit 99% of ae86 parts will fit a ke70 and rear one use a cusco rear strut brace
  8. medium street -2 camber +4.5 castor 1mm toe out per side
  9. yeah seems like low oil pressure only when idling for 10 secs or more, when the engine was done the timing chain and tensioner wernt done how do i change the timing chain? its only a single row chain
  10. i think my oil pump is on its way out or the oil pick up? its making a ratteling noise at the front of the engine near the timing case it could be one of many things timing chain/tensioner oil pump oil pickup it drives fine and makes usual power, just when at lights the oil light flickers i just did a oil change and still doing same thing the motor is a 4k out of a early ke70 its had new rings and gaskit kit through whole motor what to do??? anyone selling a worked 4k? in adelaide
  11. any plans on suspension? make it bit lower and stiffer?
  12. nice weds southern ways where did you pick them up from? size and offset?
  13. ssr mk3's good luck finding some rare as import some from japan its your only option
  14. this hachi roku is so period correct yo looks porn
  15. looking bad atm bit scared to show humanity now the rust in rear guards is being sorted i have bolt on flares and will get d max frp +20mm guards still waitting on springs for my coilovers then have to bult it up and all car is complete minus body work
  16. yeah its got kouki motor and gear box in it yes its a ae85 but is getting kouki make over will look like it was intended to be will look like it in my sig
  17. 3au is wak very slow a 4k goes harder yeah its offically called in the toyota book ae86 corolla levin GTV yeah its a corolla and a ae86 more mods to come the car is completly striped all sound deadning is out will just run basic interior
  18. damm this thing is clean needs some pimp rims form japan like 14x8 techno phantoms or ssr star sharks and camber at front too and some jap fender mirrors bring it up to a tru jap car
  19. yeah i have a ae86 there pretty cool well from what i gathered from reading bout this car it broke down after regency in verdun in hills it had originally 3AU motor and K50 shitbox then converted to jap spec now has 88kw jdm drive line t 50 box zenki diff tdn.gif when i got it very very good daily now started to mod it here is list engine bay 88kw bluetop jdm stock cold start and tvis working ngk irridium plugs TRD silicone leads 8.0mm hks death mushroom filter cusco front strut brace cusco brake master stopper jdm washer/overflow bottle havent put in yet stock headers tdn.gif need extractors 2.1/4 zorst 1 resinator and 1 muffler quiet as sourced new zorst pick up tommorow 2 1/4 with hotdog and hks cannon front end jap coilovers just need 60mm id springs 7-8kg cusco rca's cusco camber tops ae86/ajps rose jointed lca's stock front swaybar rebushed super pro cucso castor rods jdm brakes slotted/vented rotors lucas pads braided lines (soon) trd yellow shocks cusco strut brace ps arms new steering componets havent got around to doing rack castor rod brace(soon) back end kyb xlG short stroke shocks (trd blue soon) ajps 6kg rear springs T3 panhard rod t3 4 link (soon) whiteline swaybar 19mm wheels enkei cross fever wheels 14x7 red centres wraped in G11 linea sport rims 15x6.5 bout 2 inch dish for sale wraped in GIII wheels to come wide ones 15x8 -15 unsure of style 15x8.5-15 unsure of style interior so far velo podium II racespec steering wheel and 100mm bosskit jdm kouki whiteline cluster brighter bulbs installed golfball shift knob rear tower brace exterior so far Kouki fog light grill holes replaces with mirrors looks pimp jdm zenki full face lights stock guards may flare(bolt ons)+35mm frp front guards with bolt on +25mm no kit just trd skirts trd lip on way bad panda job repainting lexus red will be kouki by the end when i finish
