296 -
14
Everything posted by chestikoph1
It's not a TE72, is it?
Shit...!!! that sucks. What did he actually pin you for? Where did you get done? (echo...)
I was cleaning out some files on the old computer, and i came across these...!!! Their the first photos of my car before it was sent over. Hard to remember that it actually looked like that!!!!
Small update Getting lower control modded with some rose joints welded onto the ends. Also some more thread cut onto the castor rods. Should be able to get heaps more negative camber and more castor on there after this. Pics soon........
bloody double post.......
I am with you there Spencer, but there's always a hand full of wankers that ruin cruises/events for the many that are doing the right thing. It's just the way it is, we all get judged by the actions of the few. Just met up for a JDM cruise here in Perth and here just had to be a few dicks doing skids and speeding around the meeting points. I ended up bailing early to avoid any hassles. Any way sorry for the rant.....
Thanks Spencer, yeah i might do if it's not raining. pm me where your meeting and when.
Finally fitted some new seats, really wanted some period recaros but hard to find in good condition. I wanted ones that didn't look to modern and were as low as possible. (with a helmet on, my head was hard up against the roof) These are from a mr2 and are pretty close, nice and comfy, hold you in tight and have adjustable side bolsters too. Before After
So who's definitely coming to this? And who's competing in the superkhana ?( morning or arvo session) Looks like it's going to be warm.
Best option would be to run a surge tank, don't think the your fuel tank is baffled enough not too, you will get fuel starvation going around corners otherwise. You will need a lift pump and a high pressure pump. I am not experienced with 4ke's but looks like you already have a fuel pressure regulator on your fuel rail, but since your going super charged you may need an adjustable one.
Hi Nathan Speaking from personal experience i recommend the skyline r31 diff, i am running one behind a sr20det. It can handle the power pretty easily, 4 pinion, and 28 spline axles are sufficient, good ratios choices 3:7, 3:9, 4:1. You have got the option of factory LSD, their not the greatest but can be built up to be nice and tight, or you can get KAAZ 1.5/ 2 way LSD centers or mini spool or full spool. They also come with disk brakes. You will need to get the casing and axles cut down, get the correct pitch wheel studs ( or run nissan wheel nuts ) and shorten your tail shaft to suit. Also need custom handbrake cables made up. Diff complete second hand should cost between $150-$250 Shortening and assembly, around $1500+ KAAZ centers around $1000 ( best option ) Factory LSD center new around $500 second hand around $100-$150 ( but will need re-build ) Spool's $100 New gear sets $500, second hand $150 Hand brake cables around $200 Recommend getting the calipers rebuilt ( the hand brake system is usually seized on them ) Rebuild kits are cheap and you should be able to do that your self, and a new set of rotors is cheap enough. Well there you go mate, thats a fair bit of info for you on the r31 option. Good luck.......
Have entered in this, i got a few things i need to sort out to get it running well. Hopefully catch up on the day.
One thing you don't want on scrimp on is fuel pumps, especially if you have forced induction. Sometimes fuel pump failure can = lean out, and then BOOM
Speaking of double yolkers. I got a triple yolker the other day...!!! Has anyone had that before? No half formed chick in it or anything. Tasted good too.
Out of a Century limousine. Same power as a 2j but 30Nm more torque.
Check this out, saw this at a local Toyota meet. Imagine shoe horning one of these into a KE 1GZ-FE 5Ltr V12 DOHC- VVTi 206kw @ 5200rpm 481Nm @ 4000rpm
Toyotas In The Park - Toyota Car Show, Sunday September 11Th, 2011, Es
chestikoph1 replied to TECCWA's topic in WA / Perth
Heres some pics, please excuse the quality, i was forced to just point and shoot. Dragging a 3 year old around and taking photos is not ideal...!! Heaps more to come..... (Yes, Yes, there will be more of the white Ke20 :wink:) -
Great event, heaps of cars. Could have been a bit more organized in the way the cars were placed, but other than that, it was a good show. Managed to get a few pics, even with the young fella in tow. I will try to put a few up tonight. -
It looks great,especially the wheels. the chrome trims break it up bit
I am gonna head down, don't have a hand brake though. At least the car is clean..... Who's going from south of the river?
