Mick E
    116
Everything posted by Mick E
  1. have a5k in my ke-25 would like to know, what pistons might be in it.motor came out of a lite ace van has lugs or dimples under no 1 and 4 spark plugs, any help would be great thanks cheers mick
  2. thanks for your help rek020, will check out my wiring.will wait to hear from you about the offset. cheers mick
  3. work sucks thats how you pay for cars. finally got rego today cars drives well. cheers mick
  4. looks great love the colour and wheels. i have a ke-25 have a tacho dash for it, how did you wire your dash up.did the plug just fit straight up did everything work,or did you half to change some wires around. any help would be great thanks. cheers mick
  5. rke020 are they 15 inch mags,if so are they 6or 7 inch, and what back space are they. where did you get lumenition from hope you can help. great ride by the way cheers mick
  6. sounds like he left detent balls and springs out from the selector shaft cheers mick
  7. i am glad you have a heater in the shed cheers mick
  8. does anybody have a part number for, led globes for tail lights, blinkers,park lights,and dash lights thanks cheers mick
  9. just bought a bosch condenser for nippendenso dist, from bursons cost $8-03.if its any help little cap nippendeenso dist large cap bosch dist cheers mick
  10. looking for cheap coilovers for ae-82 can anybody help cheers mick
  11. join a car club learn to drive under controlled conditions. need cams l2s license and you are too go
  12. the old sidchrome is the best, had them since i done my apprenticship. proto is very good snap on looks a lot like it ,had them for 43 years red how can you warranty wear and tear. i have worn out my lawn mower do i get a replacement cheers mick
  13. update fellas paid 3k for car spent 1100 on it money goes fast when buying bits here and there. getting close to rego work gets in the way working on mechanicals at the moment body pretty good,will do body and paint myself later on.full rundown later when rego is done. cheers mick
  14. hey jono c it can if done right 10 mm adds 1 deg neg camber ask coln 72 camber tops are useless,ifyou have normal springs and not coil overs.tie rods should be ok with 2 deg neg camber. hope this helps cheers mick E
  15. type in historic racing nsw will give you cars and specs.check cams regs under historic racing group nc, this should help. cheers mick
  16. is there any way of telling what badges,go where and what type of badges were used on ke-20 and ke-25 corollas cheers mickE
  17. looking good parrot, its came along way since i seen it. great job mickE
  18. thats right coln 72 nails or splitpins just cut some flat washers in half cheers mickE
  19. parrot do what trev said cut the little bracket bend out of way slip in brake hose bend bracket back, slip on retaning clip did it on my ke-20 club car cheers mick
  20. try bursons roadsafe steering parts cheers mick
  21. on ke-25 the bloke that had it before me put a start button in car to make it harder to steal. i have taken it out but can't figure out where wires, under bonnet go to go back to key start. all seam to be in right places by wiring diagrahm in manual hope somebody can help cheers mick
  22. not sure on problem being too close together, but check margard throttle cables on internet might give you an idea on linkages cheers mick
  23. update fellas, has not changed pics wise. getting ready for roadworthy, in between work work around house and holidays. for roady needed balljoints lose in lhd lca rear shackle bushes washers bad earth horn not working rust in spare wheel well slightly bent chassis rail all now fixed hopefully get roady in couple of weeks and get rego changed oil&filter grease balljoints adjusted brakes fitted new wiper blades cheers mick
  24. thanks fellas that willbe great cheers mick
  25. i am after some coilovers for an ae-82,for khanacross and motokhana use. my brother in law only wants to spend about $1200 all up cheers mick
