TRD ke70
    1305
    3
TRD ke70 last won the day on October 27 2017
TRD ke70 had the most liked content!
About TRD ke70
  • Birthday 12/16/1964
Contact Methods
  • Website URL
    http://www.scottrally.com
  • Location
    Gordon Park QLD
  • Real Name
    Chris
Recent Profile Visitors
15283907 profile views
TRD ke70's Achievements
23
  1. There's another event on this weekend at Pittsworth as well.
  2. Oh, you have been hard at work. Nice.
  3. it's a completely different now. has a 6 speed closer ratio, floating hubs, dry sump, etc. The miss was fixed, can't remember what was the cause.
  4. Here's a little bit of in-car from Corolla at WRC at Coffs. https://www.youtube.com/watch?v=ChE7mVr2V5k&t=902s https://www.youtube.com/watch?v=zHa8FTMZAA0 https://www.youtube.com/watch?v=NmYr2s2tpss
  5. i would put the old 2 piece tail shaft back in. The single piece is designed for a gearbox with 2 main shaft bearings. like a T50 The 2 piece is designed for a gearbox with one main shaft bearing, hence the center bearing, carry's some of the load. like a K series. BUT, there is always a but, some japan KE70's had single piece shafts and a K series box. Also it could be the company who balance the shaft doesn't run the balancer flat out as well, i would only use Hardy Spicer in Brisbane, they know what our shafts go through.
  6. Like Justin said, you can use a camry condenser, i would't use the AE86 compressor, just cause the age and it was really designed for R12 gas. If you could get a hold of the 2A compressor that would be so much better, designed to handle the head pressures of R134a. You'll need an extra fan, (not some cheap shit craig davies crap thing either), a genuine Toyota 5 blade A/C fan is the go, You need to have really good airflow over the condenser. Have a look at Toyota with a/c and most run 2 fan continuously with the a/c on. You have my number bro, call anytime.
  7. It's made by ThreeBond and is sold by Garrmax international in Brendale.
  8. Alljap in brisbane may still have some parts for those. 1860 Sandgate Rd Virginia 4014 PH.(07)3865 2221 or look them up on facebook
  9. yip, meant 12 valve,,,, duh
  10. http://toyheadauto.com/PerformancePages/2TG_Parts.html have a look....
  11. T series diff's had many different ratio's TRD made 5.6, 5.3 (i think) 4.78 (still available) http://www.palmside.co.nz/product_cid_10929.html AE86 Zenki is the same center, ratio's were 3.9, 4.1, 4.3, 4.5 hope that helps
  12. Yip same engine, comes in 4runner, hilux surf i think. 3.0L 16 valve.
  13. if i remember rightly, you push down on the diaphragm and sort of push forward to release it. The pump lever arm has a hook and the diaphragm arm has a slot.
  14. Pinion nut is loose, take the tail shaft off the diff and you'll see a big nut, you'll need to tighten this up. specs.pdf
