sliesh
    25
  • Location
    adelaide
sliesh's Achievements
-1
  1. The problems valve stem seals if it helps these can be done with out taking the head off. Saving money.
  2. I could only get Monroe gt gas inserts front and rear. Can't get in kyb" or auto force :( not a fan of munroe but can't do much hey.
  3. WHAT ARE YOU DOING don't SELL IT its the best car you have had EVER ill swap you my ke55 coupe?
  4. sorry to throw a spanner inthe works. 5k D dished / 4k head < head 6mm higher / 202 solids / a12 push rods / 4k rocker gear (adjustable) < ok i understand 5k flat top / 5k head / head std height / < CONFUSED what do i use. would the 6mm from the head effect this? how do i compendsate this. also please take note id like to use a 4k reground cam thanks can any one help? thanks...........
  5. lol we were both writing on here at the same time. i was just making a note that hey would have the 150mm push rods as a few people such as scott pmp020 his 5k had flat tops with the 156mm push rods' so if it was going to be modified to take note'
  6. dished pistons PM'D
  7. how did you fix the thread. i would have thought the helli coil wouldnt have been that strong' ive seen the new wurth helli coil designs (crazy stuff but its $180 for a kit 1 size. other wise re-thread the next size up the bolts taper any way don't they?
  8. $1500 bump
  9. bump
  10. bump
  11. nah mate, shes sold :jamie:
  12. great project or daily has a new battery to.
