KE70+AE92
    110
About KE70+AE92
  • Birthday 11/12/1991
  • Location
    Penrith
  • Interests
    Corolla
    Subarus
    Xbox
    Ecu tuning
  • Real Name
    Nathan
Recent Profile Visitors
7631435 profile views
KE70+AE92's Achievements
2
  1. Hey all In the process of rebuilding my Smallport 4age, I cracked two Pistons, but I just purchased some 4agze low comp Pistons to replace them. Anyways I was wondering if anyone had a Workshop manual for a small port 4age, I've found one for a older big port 4age but would prefer to get one for my motor. Thanks
  2. Buy a house, worry about cars later, I wish I done that earlier
  3. Is the fuel pump working? Have you checked fuel pressure? My sx seca had a similar problem, fuel pump had no power and it would idle but wouldn't rev at all
  4. Sounds like thermostats stuck open or missing completely
  5. Hey guys Just a quick question with a ae82 exhaust fit on a ae92 I've got given a full exhaust off a ae82 seca and I just wanna make sure before I pull of my hole exhaust that it will fit, btw I have a ae92 seca Thanks
  6. Those ones all say there for a 20v Are the connectors different between a 16v and 20v?
  7. hey all Just had a look online but couldn't find anything, would anyone know where to get 4age ecu female connectors, I've got a aftermarket ecu for my ae92 but I don't want to cut the harness so if I could make a adapter loom, it would be heaps better. Thanks all!!
  8. And the fun begins!! That sucks so much man!! How far are you away from home?
  9. To me it just feels like there's no power down low Like a slug going up a hill when at low revs, I've never driving a 4age before so I don't no what to expect. I will hopefully be fixing the thermostat on Saturday have a new one ready to go in. I've only been putting 98 in it atm, i'm going to give it a full service this weekend and reset the Ecu so hopefully it might fix this
  10. I will take a photo of the repair manaul tomorrow and show you what it says. Yeah I did but the engine light just continuously flashed in about 1 second intervals, which the book says is no faults Yeah the engine was warm on the gauge the thermos were on. but I no there is a problem with my thermostats cause it takes ages to heat up and when on cold night and high speed the temperature drops a lot.
  11. It should be 16 with the diagnostic plug not shorted and should be 10 degrees with the diagnostic plug shorted, that's straight out of my max ellery repair manual Mine is 10 degrees with both The engine light just flashes contiuously a bit quicker then a second apart
  12. hey I bought a series 2 sx Seca about 2 months ago and I'm just going through and giving it a tune up. I wanted to check the timing, so I checked the repair manual and it says timing should be 16 degrees, so I hooked up the timing light and found it was at 10 degrees. then I shorted the two pins on the diagnostic plug, that should drop the timing to base timing, rechecking the timing it was still at 10 degrees. The car is going into a diagnostic mode cause the engine light flashes when I short the pins. Has anyone had a similar fault or knows why it would be doing this? Thanks guys
  13. Motor is nearly complete, just waiting for my new clutch to arrive then I will be able to put the engine back in. The motor has been fitted out with the larger injectors, the balance shaft was removed, and my turbo sump was fitted and I put a new water pump on it. Also I painted a few things while they were off. Ive fibreglass wrapped the headers aswell, they came up really good!!! Plus I painted the engine bay, there's so much black lol, it's gonna get hot! I bought a s13 strut brace, it was way to long so I shortened it it fits really good now! Lastly I got my tunable memcal for the ecu, ive installed it all, now I can plug the ecu straight into a laptop and tune on the fly. Hopefully friday the motor goes back in!!!
  14. It was definitly the radiator, the engine popped both its head gaskets!!, It was running a 1 gen subaru Liberty raditator, but i Think it was way too thin, I'm going to run a full alloy commodore radiator plus I never had a proper coolent temp gauge to read the temperature so that is a must have for the new setup.
  15. Hey guys haven't updated in a while. Ive done quiet a bit since last update! I just got a new motor as the last one I cooked it on the burnout pad lol!! The turbo setup is nearly done, once I put the new motor in it will just be a matter of tuning it. The best thing about using this motor is the minimal stuff you have to do to run boost through them, I'm loving the standard 8.5:1 comp ratio lol! I've added some larger 42lb injectors, 3 bar map sensor and a reprogrammable memcal so I can run the standard ecu. I done a bit to the front end too, i spot welded up the seams on the top of the strut towers, now that I pulled the old motor out I can do inside the engine bay aswell. Then I'll just give everything a coat of paint and it should look pretty slick! I fitted some rear bolt on flares aswell, i was too lazy to weld on so flares plus I got the flares pretty cheap. With the interior I've removed the whole dash and removed the foam padding on the back of the firewall. While the dash was out I painted it matt black, it came up really good!! Plus I added a push button starter, battery isolator. I'm also modifying the original cluster, I love the standard look, so I'm trying to interrogate a electronic speedometer into the cluster so I don't have to run a cable but also makes it easier to get the speedo to be accurate. Also I like red so i fitted so red led back lights and changed the dirty green cluster lens and fitted a clear one. Now the cluster is more visible. I'm so excited I get this thing running and on the track. Thanks
