132 -
Everything posted by hosedogg
Here's the link to the pic he took with those measurements on it http://m235.photobucket.com/albumview/albu...easure.jpg.html
just wired up a thermo switch for the thermo fan, and also fixed up the starter motor. going to be lowering it shortly for the cruise tomorrow. :P
In that case I don't want a 0.48 rear lol. I like to have a bit of lag so I can actually drive around off boost. Will wait till the turbo on it dies before getting another one though. First plan is to rego it. Then intercool it and set up the fuel system. Cam. Dyno tune. Leave it like that for a while then efi. Then engine wise that'll be it till Nikki gets her full license then drop in a 5k :P
Think bezender said the dizzy was already locked up didn't he? Either way whichever way works better :yes: as planning to efi it :hmm: yeah def wanna put a nice cam in there. Would a good cam for the 4ktc be the same as a good one for a 5kte?
Well really i think I'd rather a 0.64. Which I'm guessing this turbo on there now is? Wanna do it once and do it right with the turbo. Has to be enough to flow for the eventual 5kte :yes: also what would you recommend doing with the ignition system si?
Well in that case si I might not turn it above 15psi on this turbo. And may have to invest in Garrett t28 of some sort see if I can get any with a 0.48 rear for the little 1.3 banger :yes: and your tech thread on the how to set up a fuel system will help me alot with this car :hmm: one other thing. For the wiring to the fuel pumps. Should I run them through a relay and fuse? Or just a fuse? And don't worry we'll be getting it running right for sure >| and hopefully shouldn't take to long either Matt
lol, so just pull the wastgate line of the turbo then :yes: free boost it? haha. i'm wanting to push like 20psi through the little banger, then go eat some commodores :hmm: also here are the pics i have so far.
coming to canberra this weekend to pick up the purple 36 :yes: i'll pm you for details on said cruise, want to try and take the purple 36 on the cruise :hmm:
Lol thanks mate :yes: gonna be pretty sweet having two ke36 wagons :hmm: will most likely using a intercooler of an xr6t. Carter fuel pump that's coming with the car we'll be using as a lift pump to a surge tank then using a vlt fuel pump out of my vl as it needs upgrading anyways lol. Then take it to websters and see how much boost we can push through the 4ktc >|
Hey everyone. Have recently just left a deposit on bezenders ke36. And will be picking it up within a few weeks :yes: thought I'd chuck this up now as I'm bored ATM lol. Anyways will update as things go along. Plans are gettig running a1 and intercool I and later on efi. After Nikki gets her full license we'll upgrade it to a 5kte :hmm: but ATM we gotta get an approval for her to drive a turbo car as it is. And that will stick to the engine number and car that it is now. Pics will go up later as on my phone now. Matt
Lol that's funny :blinks:. My last ke36 cost me $1,500. So I'm happy with getting this one for $500. Also have just left a deposit on bezenders ke36 4ktc wagon :lolcry: which will be for the mrs. Picking that up not this weekend but next also if someone could point out reason's to stay with the bp motor i probably will. but if it can't handle 20psi and 250rwkw without going forged then i'll most likey go 4agte
Ok bit of an update now. Picking the car up from Canberra this weekend :blinks: more then likely have the mrs driving it back down to here on a permit. Also mind has been changed on the engine. Going with a 4agze and turboing that. Yeah it won't be different. But after alot of research and especially reading this page http://www.toyotanation.com/forum/showthread.php?p=3065346 I found out why everyone goes with the 4agze :lolcry: makes more power on less psi then a bp motor will and also makes about the same torque from .2L smaller motor :D. And yes I do realise that guy has a 20v head. But I now have alot of reasons to go 4agze. Anyone wanna buy my bp motors? Lol
Want To See A Ke20 In Forza? Vote!
hosedogg replied to Josho's topic in Rollaclub Social (Off-Topic)
Thanks man. Shame the 20 didn't get in :happy: that would of been awesome -
because i'd rather have a cat then have an efi car without one, my vl stank standing behind it and i could barely breath it was that bad, hollowed out cat. going to be using a 100 cell 3.5" metal cat on both the vl and the wagz. and rather have the better chance of passing, instead of paying $1,000 or more to do the test, then fail then have to spend money to get it to hopefully pass then have to spend another $1,000 or more to take the test again. if i win the lotto in wont phase me, but i got zero chance of that cause i don't buy tickets lol.
does anyone know much about getting this engineered in vic with the bp motor in and turbo on? spoke to an engineer and he said the only concern is the emissions testing. once that's passed it's easy, but taking that test scares me :P he said in vic it only needs to meet the requirements of the car though and not of the engine, so that should make it easier, seeming as it will have a cat convertor on it.
did anyone vote? cause i would love for a ke20 to be in forza :P -
this question can be said for anything, like everyone has said, everyone has different opinions and different thoughts. take my 67 xr falcon for example, it's green with a white roof from factory, i've had a shitload of people tell me that they don't like the colour and i should at least colour code the roof. my thoughts? i love it and there thoughts go jump cause it's not there car, i'll be putting the sunroof back onto it, which is also white, and fitting white venetians, and 110% will be putting white walls onto it. to me that would look shit hot. will also more then likely end up with white walls on 16" c5's on my ke36, and white or red walls on my vlt. if someone thinks it ruins my car, good for them, because to me it'll look way better. i hate big bling bling chrome wheels that look like giant dinner plates, but thousands of people have them and love them. their car, their choice, my car, my choice. enough said :P
you get those injectors in and the car back on the dyno yet mate?
yeah also cheaper lol, i just reckon they'll hold me in better :P i'll ask me mate if he feels like going up to canberra for it. his looking for a first car, might be able to talk him into getting a kexx if he comes :) also have spoken to my cousin and keeping gutters on the car now, just going to fix them up.
Well if you have a look at the Daytona seats where you actually sit in the seat the sides are huge so got alot more support there. They are also narrower then most reclineable ones. Which is a bonus for me cause I'm only little lol. Also the daytona's are 7kg each. And the lightest obx recliner is 12.5kg each. Plus got no need to worry about someone putting the backrest somewhere else on me :)
also just been told on fordlaser forum's that forged piston's and rod's stock head and stock cams with 19psi through a gt3071r should see me 250rwkw :) and i'm going to be using a gt3076r and upgraded cams with forged pistons and rods on 20psi, so i should be seeing over 250rwkw :P
i been told autobarn sell's obx seats, yet to call up and confirm that though. but modyourcar sells them here: http://www.modyourcar.com.au/pair-of-obx-d...rts-seats-p2261 and thats good to hear :) is he a member on here? would like to see some pics of them fitted
what's everyone's thought's on fixed back bucket seats? thinking of getting obx daytona seats for the corolla, look very supportive, and only weigh 7kg each :) also at 72 degrees sounds like a fairly good angle, tomorrow i'll set my vl seat to 72 degrees and see what the angle feels like. i've never sat in a fixed back before, so got no idea what it would be like having them in my car. anyways here's a link. http://hgeconsulting.com.au/raceworx/obx.htm
plus a go go gadget neck so i can see what my hands are doing :wink: but in all seriousness, i should have the engine out on the first weekend that the car is down here :( as i really want to make sure that it is done before i get my license back, as just adding up costs on the vl, and i don't think it'll be able to be ready before i get my license back, so might focus on the wagz instead :yes:
i would if the car wasn't 4 hours away lol, can't quite reach that far :)
