Howdy!
At the moment i have my ae86 sitting on the front lawn with a standard 4ac in it with a busted head... either cracked/warped or blown head gasket, as there is steam coming out of the exhuast, it misses and when i crank it with no plugs it shoots water out the holes.. hahaha
Luckily for me, when i bought the car it came with another head that had been rebuilt, port n polished, fitted with dual valve springs and had the compression raised. It also has a custom ground cam in it too(I'm going to find out what the specs are soon). I also received manifold with two fully rebuilt weber carbs on it. I am unsure of what the carbs are though.. is there any markings on them that i can use to determine what they are?
So the plan is.. remove everything from the top down to the block. Then start putting on the new stuff. What do you guys recommend i do while i have all these items off? Any other supporting modifications that i should do(going to get extractors made up)?
Also in regards to the massive amount of vacuum lines n random rubber hoses all over the standard carb.... i really can't see that many places to plug stuff in for the new ones... anyone know what these are for? can i just ignore them?!
and it then comes down to... what do i need to do to fit these items? Obviously new head bolts... new gasket.. what else?
Thanks all!
p.s. can't wait to get it all together.. tuned then start sliding!(hopefully.. if it makes enough power.. ahhhahaha)
