tdg61
Members-
48 -
Everything posted by tdg61
Was originally going to do this in a ke20. I have a 3vzfe at home mounted to a 3vz bell housing which bolts up perfectly. Its out of a hilux v6. I think they use r150 manual boxes and should mount up too. Only problem is 3vzfe mounts starter on housing. But I'm sure with a bit of grinding and spacing you could mount one up. I know its been done before by someone on toymods. Also one of the Zoom magazine guys had a 3.5 Camry v6 in a 86 sprinter. Hope that helps a bit.
Thanks guys. Give it a few weeks and I'll post up the finished painted product.
Can someone tell me if 4agze's came with an auto. If so what box is it. Thanks
original disc and hub on the left. The one on the right is the same hub and disc turned down to locate alluminium hub face with 5 stud ford pattern. This has allowed the wheel to be relocated about an inch inboard.
rt132 struts. cutting them down about 3 inches and using ae92 inserts. Then welding on some coil-overs. Should sit low like the rear. To bring the wheel track in, I'll cut the lower control arms and make them adjustable. I hate the frog look some cars have.
Just welding on spreader bar with wheelie bar mounts. I want to get the car on the ground soon, so I'm finishing off everything on the under side.
G,day Mat. It depends how far you want to take it. In my own case I thought originally of just making a good little street car to have some fun in. But as it progressed I decided to go bigger and better. Problem with that is, I've done double the mucking around turning a street build into a full on build. So decide where its gonna end up before you get out tge angle grinder.
Re-did the rear clip. Wasn't happy with it. Now has way less flex.
Gday Dion, Sorry I haven't been on for a while. Yes I've done all the work myself. It,s coming along in leaps and bounds now. I'll post more photos soon.
You can phone or text me on 0408722473
My dad's Subaru Liberty sedan for sale. 2.2 litre auto. Regularly serviced. Been in the family since new. Comes with 3 months rego (nsw). I'm located at Nambucca Heads in Nsw. Asking $1250. Can travel to show if not too far.
Thanks Troy. Saw your car in one of the magazines. Looks fantastic. I won't be turboing the 2j. I'm using a rotrex supercharger. Should make good numbers. These units are very effecient. Doing firewall and floor at the moment. Pictures soon.
