I have a set of 15"s for my ke20, they are simmons.
15x7 don't know the exact offset, were also on a mazda r100 and rx4
The front ones do not fit because the lip around the dustcap on the hub does not fit inside the back of the simmon. I can get them 3/4 onto the studs.
It is out by 1-2mm, I found this I found these http://www.autospeed.com/cms/A_2242/article.html
Has anyone dealt with this before? Any solutions? Is it possible to machine down the lip on my hub to match the wheel or is that not advised?
Any other easy hubs I can fit that may fit these?
Also, if these wheels are hubcentric and are meant to be supported by the hub and not by lug nuts which other wheels are, isn't it bad to put these rims on the back which features drum brakes?
Because then there is no support for the wheel and you are practically putting all the rear end weight on the studs.. Or am I wrong?
Any help appreciated.
