ballzy
Members-
22 -
Everything posted by ballzy
hey i have been trying to fit a csx dash to my panelvan just wondering if anyone had the pin diagram for both ae71 and panelvan would be much apprecatied
hey guys i was doing reserch and came across this http://amauto.com.au/gallery.html some more picture of this car and a start up video
thank you my mate might be wreaking one and i was wondering what parts i could get of him for my ae71 it is the one with the 21r in it
hey just wondering what gearbox and diff a xt130 corona with a 21r can you guys and girls help me please
thank you heaps for the help
hey guys and girls i have been wondering what is the biggest diffrence between a ta22 and an ae71 t 50 gear box are the bellhousing anything alike?? what would you need to put a ta22 ta23 t50 behind a 4a??
i don't beleive it is fuel issue due to being able to see the miss using the timing light tried adjusting fuel mixture didnt change still missed found the rotor has a bit of play and may have a leak in vaccum advance did the 4ac in ae71 come out with points or eletric
need help car wont operrate underload i bought a ae71 on friday i drove it around a bit that night and very intermedatly came a miss fire i didnt bother to much and just left it next day drove it in the morning fine still had a intermedatly miss i went put some 100 octane fuel in it still had a miss i thought it could be spark played around found a blocked fuel filter replace corrion in spark plugs, dizze cap and points replaced all replaced leads and still missed got the points professionly done and still miss got back to a mates house went to start when it was hot and didnt fire blow out fuel line it would start but under load would miss fire left it till this morning started when cold but when warmed up started to miss hooked up a timing light and checked spark ran fine at idle when reved it would miss and spark didnt go through does anyone have any advise
i don't actual have the ratios i did the tappets when cold and I'm sure i put it in right the spring to the motor so the spring heats up and release
hey guys i just got my head of my 3k motor ported and mechined the valves liped and new valve stem seals i just put it all back together and it is running like shit i have done the tappet gap and new oil and i still can hear them really bad the timing isnt goin my way either i set the point and did the timing and it is sounding like I'm running on 3 cylinders it is rough as all hell it has heaps of compression? i just don't understand what is wrong and the temperture is geting in the red but it has new thermo stat? can i please have some advice
but does it matter about not being a full chassis vehicle most commercial vehicle are full chassis and isn't that why you can put such a larger motor in them??
yeah he wont be but he offered take it to a panelbeater and get new paint were the damage is so something good came out of it
hey guys got some newish rims they measure 15 inch by 6.5 made by impul found at the wreckers $80 for the set and dad took my car for a drive and it broke down in double lines glad it was only the points but my dad bent the drives door hinges and the door wouldn't open without damaging the front gaurd did a little home panel beating and got it to work i just need some advice should i do work to the 4k and get some power out of it or should i do a 4age conversion if 4age 16v or 20v ???????????? please give me some advice i just would like some opions on which way i should go thank you ballzy
hey nice work coming along nicely what are those donor gaurds??
hey guys up date my vacum hose switch didnt work so i just connected it straight to the carby sad and stupid teenager i just found out my licence will be suspended for 3 months :P so hopefully ill get some heavy work done to my car over that time I'm at the stage just trying to get her running smoothly
hey gues about 2 months ago i bought a corolla ke55 coupe been a bit lazy but i finally got some pictures had some dramas here they are the resistor to the coil was stuffing up > fixed i didnt have high beams the combination switch was screwed got another one and the parks wouldnt come on with it so riped the both apart and made 1 out of 2 not the high beams wont go off > working progress no rear tyres left > fixed the horn would come on by it self when you turned > car fixed it blown head gasket > on order alternator over charging > getting fixed at work key barrel stuffed > fixed got a new one plan for my ke 55 coupe rust removal 4 age 20v with trupets work equip 03 wheels with a hole lot of dish and custom made flares retrimed interior in black small stereo tuff suspesion and big brakes progress on getting my dream headunit in with dvd player amp and 2 speakers sigma 14" wheels on the rear woot more speed got front black wheels in garage no tyre left on them cheese cutter fronts
hey guys my new ke 55 coupe and my point gap is out so can anyone help me out with some number thanks ballzy
