AE80Rollaguy
    347
Everything posted by AE80Rollaguy
  1. |Ill sus it out and take some good pics of all the mounts for you mate Its the factory over flow bottle but re located it so i could use a bigger battery
  2. efi will fix that
  3. Hope this helps if not let me know and i will take a more detailed pic
  4. lol i get 2 weeks out of my dizzy :rolls:
  5. hey mate, most defs in the long run the turbo would suit the motor better, Ebay have some turbo manifolds to suint the 4a motor so that should get you out of that part (unsure of flange mounting) low mount manifold http://cgi.ebay.com.au/Kelway-4AGE-4AGZE-A...=item4aa0c8f432 high mount http://cgi.ebay.com.au/HIGH-FLOW-TURBO-MAN...=item563bf00c99
  6. i have had two ae90/ae93's, i had one dyno tested for 94hp atw, and my current one was dyno test with 125hp atw has NST pulley upgrade, Jazma headers, high flow s/s cat, rising rate fuel reg, stock injectors stock pump ABV mod done, and stock ECU so with all the other extra that the OP has on his car i thought he would be making a bit more than me? like people are saying get a good tuner to tune the ecu and the results could change..
  7. That would be good mate!, any chance of getting them on sat arvo or sunday? as I'm working all day tomorrow and will be doing the timing belt and sump gasket after work/ sat morn
  8. Yeah good point probs is i need the seal before i take the old one out as i need a running car
  9. aww thanks mate, would know the seal dimentoins off hand would u ?
  10. Hey guys, well as its says my distributor inner shaft seal is leaking, i have no i dea of where i could take this to get them replaced, i have bibbed on ebay for a seal set for about $30USD so I'm unsure if that is a rip off or not.... Much help would be nice Cheers
  11. A pulley "kit" will provide you with the water pump and tentioner pulley to leave stock rpm of those items I fitted the NST pulley kit and see 14psi with stock top mount and stock fuel system
  12. So me putting fuel in my car and using to it for a drive with my mates is a waste??
  13. nawwwww poor didums, well to me i thought doing a 200k cruise was better then going from maccas car park to another carpark to look at a home made flag was a point less trip.. end of rant
  14. +1 for me not showing as i am doing a sunshine coast cruise instead :>
  15. So is this still on? if i got nothing better todo i might come out for a play
  16. Couldnt see that one coming hahah!!! but its true
  17. Where abouts do you live?
  18. i have had the same problem , jap import wreckers at 18 mile rocks will have 1 (take yours to id) or if u want i can get it rebuilt for you, just swing me a pm cheers tory
  19. mine is starting to go, so i did the hunt around at work to find our starter motor book says that a 4afe starter will fit, any one confirm?
  20. Most probs will rock up in the ae93sx
  21. hahaaha maybe
  22. id come but seems I'm not welcome so i shall go else where
  23. Update attendee list
  24. Its really no big loss dude, didnt know people were juged on by what internet site they vist, but hey good luck
