overgrown
    56
About overgrown
  • Birthday 05/04/1990
Contact Methods
  • Location
    Gold Coast, QLD
overgrown's Achievements
  1. Alright, i know its not a rolla, but wiring principles would be the same regardless of car. I'm putting a SR20det into a mx73, Using redtop loom and ECU WIred it using this model But still no spark. I hooked up the blue/red wire to the relay as indicated by the Ignitor on the 1st relay. The Blue/red wire has power at the coilpack loom plug. On the coilpack loom plug there are 5 wires, Blue red, and then the 4 wires from the ignitor. These wires change from 0.05-7v when the ingition is turned on. If i rotate the CAS by hand i can hear the injectors firing off. so i would assume the CAS is good. From what i can gather using my multimeter there is no variaton in the 4 wires coming from the ignitor. and the Blue/red wire hooked upto the relay stays above 12v I have checked all my grounds, 1 from the block to engine crossmember, 2 on the loom near the injectors, 1 on the relays, and one on the coilpack loom to the firewall that also has one from the head to the firewall. No nicks in the wire that could cause this that i have found yet. I know it is probably something obvious thats doing my head in.. My possible thoughts of what could be wrong -Ignitor Gone? bought it with the loom so who knows -all 4 coilpacks are f@$ked, very unlikley considering they are getting no power -i fail at life hahah anyhelp would be appreciated yet again
  2. run rose jointed lower control arms, this allows the arm to piviot around the mounting point and doesnt put stress on bushes because there isnt any
  3. Your to good mate thanks for that :)
  4. Hey guys, In the faq there is a link to a ke70 electrical system manual, but the link doesnt work? does anyone have a copy of this, or a ke70 wiring diagram, i need it to wire my conversion. cheers matt
  5. lookin good man, longchamps set the car off. get some matchin ones for the back :y: will look even better
  6. forgot to mention your gona need to get a ae71 hydrolic clutch and pedle box setup as the cable one doesnt work.
  7. all suspension is interchangable as is the running gear yes you can get a front cut and swap everything over, cuz the x member will bolt up.
  8. YEs you can use ae86 RCAs on the xt130 struts, a j p s sell them new for 140 i think.. getting a wheel alignment wont do much unless you have alot of adjustable stuff, and still that isnt sure to work. by putting the corona struts in the car you have changed the suspension geomotry, so you need to try and make it as similar to the ke55 struts as possible. cheers matt
  9. the best option would be to upgrade to ae86 front struts, there there are so many more options for shocks/springs. all depends on how low you wana go. if not there are shocks from another car that fit the stock ke struts.. can't remember of the top of my head, its somewhere on ae86dc. keep up the good work man cheers matt
  10. .. waits for pics haha
  11. I recon your to lucky mate. i think with the amount of times youv been picked up, your doing it in stupid places with people around to watch you(cop walking his dog) etc. i recon you need to take it a bit easier and think about what you doing, running from the cops with ur lights off is a bit silly.. there is a time and place for everything..
  12. There are 3 type of SSR mesh style wheels i know of Formula Mesh - Stepped dish Reverse Mesh- flat from the mesh to the outer lip Formula Star - Which you have, and there is a possibility they are the same as revers mesh, as i am yet to see a difference in them. (could be a name given to them, because it looks like the reverse side of a rim) who cares tho, they look hot and I'm jealous ahha cheers matt
  13. looks tops man how does that front bar go with the dash? and you have the best lookin door cards i have seen on a ke ahha
  14. awsome wheels man, had a browse through your build, awsome stuff mate. also i think they are reverse mesh? as foruma mesh have stepped dish area... hot wheels regardless keep up the top work
  15. adjustable what?
