diegoh
    95
Everything posted by diegoh
  1. Thanks for that info, I worried about the starter but the inlet manifold I'm paying someone else to make it out of a piece of billet as it ends up cheaper than tubing welds and flanges all up. Might even invest in a small billet charger than an eaton m90.
  2. For those wondering here is a pic of the 3vz vs mz bottom end green is where to seal and even oil feed matches up. Usually 3vz-e guys try just fit a 3vz-fe engine but I'm unconventional but all up the 3mz-e hybrid service weight of 3mzfe is 157kg minus 16kg for lighter 3vz-e heads, lighter flywheel/clutch and M90 eaton supercharger, compact inlet manifold & headers hopefully around 140kg
  3. Is anyone running a 3vz, mz or gr v6 in any front engined rwd pre 84 corollas celicas? Ive been looking at the torque of all the toy v6 engines are their weights designs etc. I will be happy with 230hp for a supercharged v6 as I'm interested in torque VZ-e 8v heads are very light, cheap new and very compact for engine space. The 3vz-e heads on a 3mzfe bottom end all head bolts line up and all water galleries more or less match up, oil feed is spot on and oil drain is easy. VZ-e e heads just need little opening up on water galleries after looking at the gaskets its all very possible. Some oil drain holes on MZ need sealing etc. Might seem a brain fart in a world of multivalve twin cams for everything but at 8.2kg lighter each than 4v heads thats 16kg all up top! that I like. M90 eatons are cheap from 3.8L buicks and single 2 inch SU is enough no pollution gear is required here on birthplace Islands of Toyota :) Is there a way to fit any 6 speed boxes for rwd or a way to fully manualize some sort of modern 5 or 6 speed rwd lexus or ft86 transmission?
  4. Have to start with any 2tc or 3tc block 85mm bores and go OS to 86mm pistons for it Rods would be either from the Y motors or something custom or modified from stock
  5. isnt it better to use the 3y crankshaft as its 86mm which would make a nice streeter for and 86mm bore 2tc = 1998cc the 4y is 91mm stroke and the 3tc is 78mm so I would prefer 86mm all day long and if you are to sleeve the 2tc might as well go all the way to 91mm and use mitsubishi astron pistons but 86 x 86 mm would be no sweat.
  6. Makes sense thank you
  7. thanks fully ported man
  8. It hasnt been match ported its got original cast mark inside so your match porting suggetion is bogus, as for high port, never heard of an exhaust high port manifold so its getting boring
  9. now we are getting loopy, a twin downdraft carb can be anything you want son have your dreams and sugar them with honey
  10. The inlet mani was not paired to the inlet, just asking about the inlet never asked anything about the exhaust as they are nothing to do with high port inlet manis and the inlet has a twin downdraft setup so two holes up top :) also there was another inlet with the twin but had way smaller inlet ports.
  11. No idea but was an original rolla engine was never touched until I took it as old fella rolled the rolla coming back from the pub onto his own driveway! He had his foot firm on the accelerator instead of brake, no wheels on the ground, put a leg out of bed etc. Exhaut is just ke30 I picked up elsewhere as custom headers always run worse than stock twin outlet.
  12. It has 32mm inlet ports and was told it's a highport inlet manifold? any ideas?
  13. I missed it or didnt happen but did you weight the engine complete? definitely lightweight engine and body, I remember a FRP/Carbon notch back weighed in at around 760kg in 1997 while in Japan.
  14. Senator Online was a pretty good option, have all the decisions/policies/legislation before they happen sent via smartphone or simiar Online device so it can be voted by the public and not the turds in Parliament.
  15. What Ive always loved about Australia is the Pioneering spirit and support for the little guy. Now its just nah better support Libs or Labour and listen to the insidious wankers in mass media that are Pro-Israel/Zionist/Banks/War/Weapons/Pharma/ Chemicals and on and on. In this country peeps use to voice out when something stunk but now just happy to pretend they know it all and bleat the common in fear of looking absurd or an alarmist. There is shit happening all over the place that needs our attention and its just not happening with the lame conservative attitudes that has spread like a disease. when its clear as day that no 2 possible leaders will not change this country for the better, when our media is completely controlled by the same group of Bankers and pro-Israeli groups, when we allow big wigs to get away with all kinds of abuse and take backs, when enough is enough.... yet nothing happens anymore just the same bleats that are massaged by mass media to make you feel like you know whats really happening. This country could be even greater than what it is, amazing riches and way of life but these scumbags are sending it to the pits. Do many know about the JSF contract little Johnny signed on before he was kicked out, or the 20 billion he donated for carbon sequestration to big mining and energy entities? Thats 100 billion right there. Imagine just donating 21 billion to each of the 7 million households in Australia for 4kw PVs and hot water systems then another 20 billion to rid 40 coal fired power plants for state of the art Solar Thermal Stations with world leading molten salt storage and even Aussie designed wave energy technology that ended up in England. That would mean no one on this country would pay a cent for electricity and would have a great chunk of money to spend. How about Vertigro Algae fuel plants that cost bugger all to set up and keep all our fossil fuel tech sustainable. Glen Kertz the guy is a Genious similar to the character portrayed by Anthony Hopkins in The World's Fastest Indian We would solve our energy issues without going to war and create gazillions of jobs that are not just based on digging holes How about voting for the Aussie guy with some of the biggest balls ever....Julian Assange Wikileaks? Assange is well spoken, intelligent and extremely altruistic for someone so young, born in 1971. When most look for better ways of making money this guy puts it all on the line for nothing but his belief that the parasites should be stopped. He is trying to make us Zombies wake up and stop paying politicians to have a good corrupted life that only support corrupt criminal entities. Aussies always used to support the underdog and this guy is up against the big wigs and the majority of the brainwashed population. Its time for a change and we need to say enough of the corruption and lies. We don't want Libs or Labour they are the pits but we need a party that secures first our energy future instead of selling out to the rest of the world for peanuts. We have some of the most ingenious people in the world yet they end up overseas. We need Pioneers not Parasitic twats. The Australian and Sex party are another interesting option. I like many, spat at anyone calling themselves so stupidly thinking how ridiculous "sex" is used for attention, but when I read their policies I was astounded it wasnt just lubed dildos and prostitutes getting a leg up :) I personally don't see how taxing us little guys is the way to get out of debt for governments that spend billions on failed projects and donations to big polluters. Rudd and even Abbot will take money from our money in banks and call it a deposit Levy fee. Whats really a real disgrace also is that any child of these polies that wishes to work for their dad or family related polly is secured 65K aud tax free for the rest of their lives for only been employed for one year in parliament, 85k+ for 2 and over 100 for 3. Thats a tax free lump sum for the rest of your life how is this happening or fair? its criminal yet this is a politicians life to bleed the public and receive handouts from the big wigs for doing what they preach. Assange has my vote, the world is one big corrupt place and he would be historic sticking it to anyone that previously screwed you and I. I wished more would lay it on the line like he has instead of just play fiddle. here is the JSF doco is someone missed it which new estimates to cost over 80+ billion after they are delivered and maintained for 3 years alone.T John Howard should be tried and jailed for this nonsense which is a complete criminal abuse of our money. http://www.abc.net.au/4corners/stories/2013/02/18/3690317.htm Agent Orange in Oz everywhere? no way we are the lucky country. Its even worse with higher levels of Dioxin than in Vietnam. Its called 2,4,D and it is sprayed all over Australia and the food we put in our mouth but the majority doesnt complain or understands till they watch this mainstream piece, very powerful viewing. http://www.abc.net.au/4corners/stories/2013/07/22/3806111.htm
  16. Have you tried community radio or non mainstrearm online video sites run by real people not actors or jewbies? Try 3CR podcasts and listen for yourself whats wrong with this country, you think mountains of yellow cake at Olympic dam blowing in the wind is good for our lungs or kids growing up with current licence to expand it op 3 fold? You think coal seam gas is great for water table and farmers with benzene filled water sources? Massive Gas and Coal ports built on protected eco systems like the Great Barrier Reef?, Loggers in Tassie getting millions to give up logging only to invest our money into their business so their brother, wife or children continue on running it, Politicians children working doing SFA in politics for one year then quitting but guaranteed 65K tax free for the rest of their lives, 95k for 2 years and 125k for 3 years while the rest of us work our butts off with no such tax freedom, 20 billion handout for carbon sequestration research which is enough for 7 million homes in oz to have 2.5kw and solar hot water systems and spending the savings on shopping, local tourism and more, Chinese, Malay, Indonesian and other student buying properties sponsored by their big wig uncles from overseas to keep the bubble going up while most of our children will never be able to afford a 700,000 dollar property, spraying a banned substance in third world countries "endulsulfan" in macadamia plantations killing neighbouring farm animals and children, Corrupt Police controlling the drug industry and targetting bikie gangs when they don't play fiddle with their drug rules and the list goes on and on and available even on mainstream media like ABC four corners, foreign correspondent and other news shows. Its all there no conspiracy just too much info, too many distractions not enough time or care. How can you cover your tracks when you are surrounded by people who are happy to play along but at points always have something called the conscience creep in and have enough? They do cover their tracks well most of the time but we do live in a world where communication was bound to get better and for example if you put something damaging some companies reputation the same company has the option of removing that with a fee or membership with Youtube but no guarantee someone wont upload it again. There are no conspiracies or patterns just alot of blue collar and higher criminal activity in all parts of the world that good deeds are overshadowed much easier as its much easier to destroy, steal or lie than to build, give and tell the truth when it comes to gain. Twinky, no one wants a handout in my family, Ive come here from a much worse world than you can even imagine no liberties or freedom compared to here so try not to single yourself out as an appreciative do gooder as you are far from it by being ignorant. The big wigs are raping this country dry, its one of the richest countries in the world for resources and it could be so much better if we didnt have the current leaders playing fiddle to big industry. Its easy to be an ignoramus happy with your 2.5 cars, a fridge full of milk and a mortage or paid house and overweight spoilt kids and Coles/woolies/KFC/ Maccas ready for your convenience but do you think thats a healthy existence? If thats so you are worse than a tin foil hat you are just the perfect Zombie for those in charge. I get my milk and other foods from the producer no middlemen or big wig overcharging me and my family we make an effort to support the little guys not just give in to the Conglomerates blindly thining this kind of life will last for ever. Giving in to everything the Big wigs say will end this for our children and grand children but who cares hey while you can watch Seth, Josh, Hamish and other Jewby insidious TV personality entertain, scare or do the thinking for you. Try 3CR podcasts and open your mind to real people otherwise just be part of the countless Zombies drinking permeate in their milk only to be made aware of permeate when theres a big stink brough up by a supposedly tin foil hat who actually has a brain and conscience to help humanity not just sit back and say how lucky we are. Everyone should make an effort to know more about everything and speak out. Its easier to sit back and be a cynic thats what you are conditioned to be filled with fear of how good we have it but it takes much more to speak out, learn for yourself and help those in need.
  17. That link was just a laugh probably the most pathetic effort anyones posted in a while, not unexpected from someone in denial. We live in a world where inflations a bitch, money is printed to recover jewy zionist failed bankers and Zombies just avoid reality. Just when an NSA whistleblower exposes criminal acts countless conditioned Zombies just keep on their merry life in denial taking it up the rear cause the world is fine and we don't need to worry about anything. Like it matters that we are run by Libs or Labour they are the same parasites, they will all sell anything this country has to anyone.
  18. Edward L Winston has not supplied any evidence as he said he would in his conclusion so is just another Zionist tool working for the Big wigs of the power game, a totally useless link. Yesterday Google had a link to the whitehouse just underneath saying something to the likes of "Google doesnt support the NSAs complete deceipt and crimes on the American public". I and others I know went to the link out of curiosity as most should know by now Google was sponsored by the NSA so it is bollocks that Google even cares and to top it off my computer was slowed down dramatically after going to this link but fixed that using a constant relocated ISP add on. Google, Facebook, Youtube just pretend to play fiddle or that they are on the publics side just to keep their users happy as they are the best businessess in the world and apart from defence this is the mega bucks market that they don't want to lose or damage in any way. The linked page asked for all the personal details before writing a complaint and this link is now not there from today. There are no conspiracies, just reality that just passes by everyday and most people don't question it preferring to let our Govs get away with lining their pockets by supporting big wigs and corrupt entities with wealth. Heaps of BS distractions from Zionist turds all over our idiot box. How many Zionist first names can you count on any single 7pm project episode? have a go. http://www.pcmag.com/article2/0,2817,2420552,00.asp Look up the parents of the owners that run Google, Facebook and Youtube to reveal some serious Fed positions in Arms, Genetics and other Weapons manufacturing connections. Do you really want to send a sample of your DNA to the US to see your bloodline or family migration chart? To not question anyone in power of our society is just being a total blind Zombie
  19. anti-jew is not anti-semitism its just portrayed that way for their benefit, it is a cult originated from Russia the video I posted earlier helps explain this http://trutube.tv/vi...-insulting-Jews also the research does not lie and neither does their own literature http://trutube.tv/vi...ian-Christians- how Ironic Godwin is a Zionist
  20. Actually there arent enough tin foil hats going around complaining just dead head zombies letting the destruction of our communities and freedom of rights as citizens. Cops are a joke they just work for the rich just like in the days of squatter and convicts where the squatters made the rules. The reality is every Generation has given in to the BS that our controlled media dishes. The De Sal plants will open the door to Nuclear plants to convince that electricity will get cheaper which will then pollute everything we have as now Americans are finding when they were testing for Fukushima radio Isotopes when in fact are their own running down rivers and run off from storage sites where the containers have let go and spent nuke fuel is leaching into their artesian basins. Every part of our life is run by Zionist cult Big Wigs, media, big pharma, energy, mining, weapons, processed foods, Supermarkets, dept stores and shopping centres not forgetting our defence force. There is nothing Australian left here anymore just Gentile zombies drinking USA cola, fluoridated water, protesters tasered by Israli made Tasers, Monopolised companies feeding us everything from fuel, food, energy, movies and more. 7PMproject full of Zionist Cult promoting defence encouraged by proJew comedians and personalities, koch,hamishandAndy you name it all insidious characters as found all over our world to tell us what we should and should not be doing. Their cult is insidious sneaking in everywhere by buyouts and breeding with better DNA in order to spread their monopolised BS & way of life. Hows that pathetic Offspring show with that mole labelled as Australias golden girl and winning an award total BS no1 watches that crap show, its just there to BS insidiously into getting into our minds that these Jewish faced parasites are what we should be aiming for in our women. Give me a break they are disgustingly perverted with their witchy noses and weak facial features resembling an Adam sandler with a blondge wig. watch this vid of someone who questioned or peed off some Jews in Oz http://trutube.tv/vi...ing-Of-Gentiles http://trutube.tv/vi...t-to-serve-Jews http://trutube.tv/vi...-insulting-Jews How WW1 was engineered http://trutube.tv/video/4308/Jewish-Genocide-of-Armenian-Christians-
  21. the MR10 is the stuff thats in my buddies rx3 race car 3+ years and still looks good, no condensation and no scratches Bus stop around the corner replaced the glass with it about 6 years ago and much better than the glass which always ended up broken and all over the place
  22. Ive always wanted Lexan mr10 in bronze for that retro look indestructible and scratch resistant uv resistant but $$$ yet would technically last forever http://www.professionalplastics.com/LEXANMR10
  23. The orange painted grille is 80s boy george styling but Id buy a Mango again anyday. Toyota had awesome unique cars in that era the TAs, TEs and the Starlet but I think the Starlet was the lightest, would have been crazy with an all alloy late 1.8 or 2L mill.
  24. https://www.youtube.com/watch?v=RFR01yUnstI
  25. http://datsun1000.co...Page=1#Post6578 Looking for 5.3k with RWC or 4.5k without reg for interstaters
