diegoh
    95
Contact Methods
  • Website URL
    http://
  • ICQ
  • Location
    Melb. Oz
  • Interests
    Jp classics that look like insects ;)
diegoh's Achievements
  1. Thanks for that info, I worried about the starter but the inlet manifold I'm paying someone else to make it out of a piece of billet as it ends up cheaper than tubing welds and flanges all up. Might even invest in a small billet charger than an eaton m90.
  2. For those wondering here is a pic of the 3vz vs mz bottom end green is where to seal and even oil feed matches up. Usually 3vz-e guys try just fit a 3vz-fe engine but I'm unconventional but all up the 3mz-e hybrid service weight of 3mzfe is 157kg minus 16kg for lighter 3vz-e heads, lighter flywheel/clutch and M90 eaton supercharger, compact inlet manifold & headers hopefully around 140kg
  3. Is anyone running a 3vz, mz or gr v6 in any front engined rwd pre 84 corollas celicas? Ive been looking at the torque of all the toy v6 engines are their weights designs etc. I will be happy with 230hp for a supercharged v6 as I'm interested in torque VZ-e 8v heads are very light, cheap new and very compact for engine space. The 3vz-e heads on a 3mzfe bottom end all head bolts line up and all water galleries more or less match up, oil feed is spot on and oil drain is easy. VZ-e e heads just need little opening up on water galleries after looking at the gaskets its all very possible. Some oil drain holes on MZ need sealing etc. Might seem a brain fart in a world of multivalve twin cams for everything but at 8.2kg lighter each than 4v heads thats 16kg all up top! that I like. M90 eatons are cheap from 3.8L buicks and single 2 inch SU is enough no pollution gear is required here on birthplace Islands of Toyota :) Is there a way to fit any 6 speed boxes for rwd or a way to fully manualize some sort of modern 5 or 6 speed rwd lexus or ft86 transmission?
  4. Have to start with any 2tc or 3tc block 85mm bores and go OS to 86mm pistons for it Rods would be either from the Y motors or something custom or modified from stock
  5. isnt it better to use the 3y crankshaft as its 86mm which would make a nice streeter for and 86mm bore 2tc = 1998cc the 4y is 91mm stroke and the 3tc is 78mm so I would prefer 86mm all day long and if you are to sleeve the 2tc might as well go all the way to 91mm and use mitsubishi astron pistons but 86 x 86 mm would be no sweat.
  6. Makes sense thank you
  7. thanks fully ported man
  8. It hasnt been match ported its got original cast mark inside so your match porting suggetion is bogus, as for high port, never heard of an exhaust high port manifold so its getting boring
  9. now we are getting loopy, a twin downdraft carb can be anything you want son have your dreams and sugar them with honey
  10. The inlet mani was not paired to the inlet, just asking about the inlet never asked anything about the exhaust as they are nothing to do with high port inlet manis and the inlet has a twin downdraft setup so two holes up top :) also there was another inlet with the twin but had way smaller inlet ports.
  11. No idea but was an original rolla engine was never touched until I took it as old fella rolled the rolla coming back from the pub onto his own driveway! He had his foot firm on the accelerator instead of brake, no wheels on the ground, put a leg out of bed etc. Exhaut is just ke30 I picked up elsewhere as custom headers always run worse than stock twin outlet.
  12. It has 32mm inlet ports and was told it's a highport inlet manifold? any ideas?
  13. I missed it or didnt happen but did you weight the engine complete? definitely lightweight engine and body, I remember a FRP/Carbon notch back weighed in at around 760kg in 1997 while in Japan.
  14. Senator Online was a pretty good option, have all the decisions/policies/legislation before they happen sent via smartphone or simiar Online device so it can be voted by the public and not the turds in Parliament.
  15. What Ive always loved about Australia is the Pioneering spirit and support for the little guy. Now its just nah better support Libs or Labour and listen to the insidious wankers in mass media that are Pro-Israel/Zionist/Banks/War/Weapons/Pharma/ Chemicals and on and on. In this country peeps use to voice out when something stunk but now just happy to pretend they know it all and bleat the common in fear of looking absurd or an alarmist. There is shit happening all over the place that needs our attention and its just not happening with the lame conservative attitudes that has spread like a disease. when its clear as day that no 2 possible leaders will not change this country for the better, when our media is completely controlled by the same group of Bankers and pro-Israeli groups, when we allow big wigs to get away with all kinds of abuse and take backs, when enough is enough.... yet nothing happens anymore just the same bleats that are massaged by mass media to make you feel like you know whats really happening. This country could be even greater than what it is, amazing riches and way of life but these scumbags are sending it to the pits. Do many know about the JSF contract little Johnny signed on before he was kicked out, or the 20 billion he donated for carbon sequestration to big mining and energy entities? Thats 100 billion right there. Imagine just donating 21 billion to each of the 7 million households in Australia for 4kw PVs and hot water systems then another 20 billion to rid 40 coal fired power plants for state of the art Solar Thermal Stations with world leading molten salt storage and even Aussie designed wave energy technology that ended up in England. That would mean no one on this country would pay a cent for electricity and would have a great chunk of money to spend. How about Vertigro Algae fuel plants that cost bugger all to set up and keep all our fossil fuel tech sustainable. Glen Kertz the guy is a Genious similar to the character portrayed by Anthony Hopkins in The World's Fastest Indian We would solve our energy issues without going to war and create gazillions of jobs that are not just based on digging holes How about voting for the Aussie guy with some of the biggest balls ever....Julian Assange Wikileaks? Assange is well spoken, intelligent and extremely altruistic for someone so young, born in 1971. When most look for better ways of making money this guy puts it all on the line for nothing but his belief that the parasites should be stopped. He is trying to make us Zombies wake up and stop paying politicians to have a good corrupted life that only support corrupt criminal entities. Aussies always used to support the underdog and this guy is up against the big wigs and the majority of the brainwashed population. Its time for a change and we need to say enough of the corruption and lies. We don't want Libs or Labour they are the pits but we need a party that secures first our energy future instead of selling out to the rest of the world for peanuts. We have some of the most ingenious people in the world yet they end up overseas. We need Pioneers not Parasitic twats. The Australian and Sex party are another interesting option. I like many, spat at anyone calling themselves so stupidly thinking how ridiculous "sex" is used for attention, but when I read their policies I was astounded it wasnt just lubed dildos and prostitutes getting a leg up :) I personally don't see how taxing us little guys is the way to get out of debt for governments that spend billions on failed projects and donations to big polluters. Rudd and even Abbot will take money from our money in banks and call it a deposit Levy fee. Whats really a real disgrace also is that any child of these polies that wishes to work for their dad or family related polly is secured 65K aud tax free for the rest of their lives for only been employed for one year in parliament, 85k+ for 2 and over 100 for 3. Thats a tax free lump sum for the rest of your life how is this happening or fair? its criminal yet this is a politicians life to bleed the public and receive handouts from the big wigs for doing what they preach. Assange has my vote, the world is one big corrupt place and he would be historic sticking it to anyone that previously screwed you and I. I wished more would lay it on the line like he has instead of just play fiddle. here is the JSF doco is someone missed it which new estimates to cost over 80+ billion after they are delivered and maintained for 3 years alone.T John Howard should be tried and jailed for this nonsense which is a complete criminal abuse of our money. http://www.abc.net.au/4corners/stories/2013/02/18/3690317.htm Agent Orange in Oz everywhere? no way we are the lucky country. Its even worse with higher levels of Dioxin than in Vietnam. Its called 2,4,D and it is sprayed all over Australia and the food we put in our mouth but the majority doesnt complain or understands till they watch this mainstream piece, very powerful viewing. http://www.abc.net.au/4corners/stories/2013/07/22/3806111.htm
