LittleRedSpirit
    4772
    64
LittleRedSpirit last won the day on November 5 2024
LittleRedSpirit had the most liked content!
3 Followers
About LittleRedSpirit
Contact Methods
  • Website URL
    http://www.rollaclub.com/board/index.php?autocom=gallery&req=user&user=2885
  • ICQ
  • Location
    Brisbane
  • Interests
    MMA Fighting, Skateboarding, dirt bikes.
Recent Profile Visitors
43396047 profile views
LittleRedSpirit's Achievements
Apprentice
Apprentice (3/14)
  • Reacting Well Rare
  • Very Popular Rare
  • First Post Rare
  • Collaborator Rare
  • Posting Machine Rare
Recent Badges
144
  1. Hello Fam. I did get the AC to work, but its lost its gas in the lead up to christmas so I need to fix it again. Have just been enjoying it a lot lately. Maybe too much. Been giving it hell around the cane fields lately. Lots of fun. Have just clocked over 380000 klm on the odometer meaning its done about 57000 klm since the 2azfe conversion. I have lower klm odometers and about 6 sets of clocks for it but I like having the original one in there so I know the klm on the chassis. Have been fiddling with the tuning, have a pretty great startup now, and the plugs read brilliantly. Havent been on a dyno since 2020. I have enough parts to build a tuff motor now. Kelford cams, 286/278 duration and added lift. My CP 11 to 1 pistons, some molnar forged rods and some supertech valve springs, I have a couple full gasket kits as well. Should be a mad machine when I get around to that. Just thought Id throw in an update for the rollaclub family! peace.
  2. Time for an update because I have some work planned. Have collected everything I need to put Air conditioning in. I purchased or saved over the years; -a new oem Denso condenser - a new Spal fan for the condenser - working 2az AC pump from my 78000 k donor car and the pump ends of the AC lines. - all the OEM AC parts from the car including all the standard soft and hard lines, mounts, wiring to connect it up under the dash. - Spare AE86 heater switch block as mines a bit broken in the car. - New AC faceplate decal - New OEM heater core from Japan. I decided that its not worth just doing AC, I will fit a heater too. Things I need to re engineer to make it work; 1. Relocate oil cooler and lines. Make new brackets for it and possibly ducting. 2. Mount the AC pump and design the new belt and tensioner system to spin it. 3. Decide what kind of heater tap to use, where to mount it, and the hose path for it. I'm considering either an electric heater tap with a hidden micro switch in the AC switches to operate it, or a relocated cable setup. I think electric tap will be simpler with what I have going on in the bay already. Have treated her to a few missing parts as I've been able. I put in a rear hatch trim board which I bought new. I finally found a rear demister switch and bought it new also. Have replaced the headlight knob that had no writing left on it with new. I bought a top windscreen trim (again) as I will have to do a screen at some point maybe to re register as its got a big stone chip the size of a 10 cent piece on the passenger side. The old top trim has never fitted right as the windscreen guy didn't mount all the clips as needed so it just flies off at 100kph. Has happened twice now once on the Bruce Highway and was never seen again. I also bought a new rubber grommet for the bonnet post so it doesn't rattle, and a fuel tank pickup gasket to change next time the tank comes out. I have some folded and cut to size metal to make a new lower passenger seat rail to match the drivers and allow me to get rid of the modified ke70 rails it has. I also have the bride type seat slider to adapt to it. Basically building a copy of the drivers rail I have but reversed. Front wiper motor is pretty sad so will be swapping that to a better one. Also going to fit the rear wiper washer demister setup for the hatch as it rains a lot at the moment and Id rather have it in the car and I have all the switches finally. Car isn't currently registered but will be re registered after all that's done. Also lowered it and bought a better Jack so I can get under it at the lower height.
  3. From memory the ae86 stock pump is just an in tank HP pump, not a lift pump so it will have to hold whatever pressure the rail holds.
  4. I made new oversize fuel lines for my first ae71, was not worth it. Maybe the least enjoyable mod I've ever done. Just write down the pip sizes for feed and return, take the pump bracket with you, ditch the expensive raceworks stuff and go to an industrial gasfitting supplier like IFS and just buy what you need off the shelf. They have everything, hose to barb, taper fittings, banjos, hose adapters, push lock, metric imperial and they can make a fitting if you're really stuck.
  5. Es posible que deba publicar una foto de la caja de cambios o buscar cosas en el catálogo de piezas y confirmar lo que tiene.
  6. You have a speedo drive that suits the automatic final drive ratio.
  7. super tidy
  8. Not to mention the leather seats!
  9. Yeah make mounts to suit your chassis. Custom headers and inlet. Y starter ring gear and bellhousing. Have a bellhousing set for sale if you're keen message me. Use a W transmission. I have a w57 now but will put a w58 in soon. Fuel system, wiring, ecu, tuning etc.
  10. I've seen so many adds for sale lately priced on potential. Like a stock roughish VK executive with a HSV GTS motor, on a pallet next to it, asking 25k. With a comment like, just needs to be dropped in. lol. Car is valued at 5k, motor at 6k, how do you come up with 25k. People get in too deep, cause its easy to spend if you're an idiot with cash, but idiots cant fix or finish anything. Hows the ae86 on FB marketplace with the full ra65 engine, box and interior, with positive offset wheels asking 25k. Fucking vomit spec. Where I come from people like that get slapped.
  11. Looks like old mate lives in QLD so all that engineer stuff doesn't apply. Just get a mod plate and follow adrs when you build it, and you'll be fine. Thankfully QLD motor trades are deregulated and there's even 6 shires where you dont ever require a roadworthy. My mod plate for 2az86 was about 200 bucks, and it covered engine, suspension and diff, cage and seats.
  12. Quick update. House is half built. Roof is on. Cars been sweet as can be. No real issues to report, just wear and tear from all the roadwork between here and Brisbane. Copped some gravel and rocks from trucks coming in and out of the quarry north of Gympie. Was lucky to not experience much more serious damage. Front bar took the brunt, and ejected the paint. Gave it a wash today. Much overdue.
  13. Sounds like a fun little project. Did you dribble a couple ml of oil into each cylinder to try to lube up any stuck rings while comp testing?
