Kirby
    8
Kirby's Achievements
  1. Dionne's Transporter Strut Housings Zenki Axles Carina Housing Patches... the parts guardian
  2. My Dream Cage My Real Cage Cam Covers Hydraulic Handbrake Refurbished Throttle Bodies Techno Toy Tuning Camber Plates and NRCAs Techno Toy Tuning Top Hats and Shifter Rebuild Kit Wilwood Caliper Mounting BRackets
  3. Update Photos.... JDM DC5 start button (thanks Ronthug) Redman (Barefoot Rastaman) and I securing my gearbox How did that get there? All of the tar is finally gone No More gas tank lid.... I will be using a fuel cell. Here is redman dealing with that spot. The car will be going for the cage this evening. Hopefully work will start on that tonite... who knows. Up to Adrian Linton, one of the best roll cage installers in the Caribbean :kiwi:
  4. Saturday 13th of January 2007 Just an update. I got my spare Carina diff delivered. I feel the drums are seized but that isnt too much of a problem, as I will be using rear discs and calipers from the AE86 GTS. I Will also be modifying it to fit coilover sleeves, springs and adjusters in place of the stock spring setup. Took out the MSD. (luckily it has the installation instructions on the back) Rooflining is out. Naked Roof (will have to park in the shade now). Anybody knows an easy way to get off that fiberous stuff on the roof? Finally finished 'detarring' the foot wells 4 Ghetto garbage bags of tar. about 100 lbs CArpet is out now as well.
  5. SUNDAY 7th January 2007 My friend Rene removing some tar Me getting in on de action getting there Just de front footwells to do now. Nice and naked Back Shot :D
  6. Saturday 6th January 2007 Front shot Repaired Fender Engine Bay New Engine and Box TRD Old School cam Gears Fuel Pump Left Fender Dash Board Crafstman Engine Hoist MSD 6al Back (anybody know what car these lights came from?) Real men don't need an engine hoist However, Real men need to have the two gearbox plate bolts removed :D Completely disconnected now. (Me on the left, my old man center (Mappus) and my buddy Ramon on de right fender. Seems to have been properly repaired as he heavy! Almost out That poor Radiator panel. My old man trying to lift the engine alone Engine OUT (AND BAD) My buddy Ramon Hurt up
  7. Below are the things I have remaining to get. Suspension - T3 NRCAs - T3 Camber Plates and Upper Hat - Paradise Racing Coilover kits - KYB AGX short stroke adjustables - Adjustable Panhard - Poly bushings kit Full Electrical - Autometer Phantom Oil Press., Oil Temp, Fuel Level and Water Temp Gauges - HIDs Engine - Gasket kit - Piston Ring kit (possibly) - Blaster Coil for MSD - 13 Row Oil Cooler and Filter Relocation Kit - Velocity Stacks - ITG Air Filter Kit - new 4-2-1 exhaust manifold (possibly) Drive Train - T3 shifter Rebuild kit - Short shifter modification - Toyota 4.778 Crown wheel and pinion Brakes - Vented GTS Grooved discs Front and rear - Wilwood Dynalite Calipers and brackets - AE86 GTS rear discs and calipers - Braided Lines Fuelling - Braided Fuel Lines - 'Ballysport' fuel surge pot (from Power on Zhaust) - MSD high pressure fuel pump - Fuel pressure regulator
  8. Hi Guys, I am from Barbados and I am now in possession of a 4AGE equipped KE70 which I am going to completely rebuild into a rally/ track car. Before actually buying the car I started accumulating the parts with the idea in mind to find a rwd Toyota shell and install the engine and box that I bought from my friend Roger from Trinidad and set it up as a rally car. Below are a few pics of the parts that I have. MAP Sensor Throttle Body (to be tossed.. you will see why below) Water Temp Sensor MAP Sensor ECU (being sent to Malaysia for remapping and a 9000 rpm limit) Full Wiring Harness from a AE92 with MAP sensor Monster Tach and FIA cut-out switch Greddy Emanage Blue (to help out the ECU a little bit :D ) Whats this?? Techno Toy Tuning ITB adapter and Silver top ITBs
