1892 -
95
Everything posted by Banjo
http://www.news.com....261a7c00f959365 Point 12:
K Motor Electronic Distributor, Cap Doesn't Fit
Banjo replied to Jansku99's topic in KExx Corolla Discussion
I think Stuart might be on the right track. Have a look at this link. http://toyotapartsca...-distributor-5/ Distributor Cap P/N 19100 Rotor P/N 19102 Cheers Banjo -
I compared my 5K dizzy with built-in ignitor, with your photos, and it looks very much like yours. Maybe the aspect ratio of your photo threw me off a bit, as the ignitor "looks" fatter in your photo than mine. My 5K dizzy, still has the aluminium ID sticker on the side. It states . . . TOYOTA 19060-13100 100291-1349 5K-C Denso Japan Maybe those numbers will lead you to the correct cap & rotor for yours. My rotor button has no numbers on it at all. I'll go round up the cap later, but I don't think it has any identification numbers either. Cheers Banjo -
Does the distributor have little aluminium plate or sticker on it, with Toyota or ND (Nippon Denso) numbers on it ? Your top photo seems to show the remains of a sticker on it, that looks like it has seen better days. I looks a bit like a 5K dizzy, but differs I think. I'll go & grab a 5K one from the shed & compare with your photos. Cheers Banjo -
Hi Peter, You're welcome ! Just keep posting. Cheers Banjo
Wow ! That's probably about 3 times their original purchase price back in the early 70s. Who said early Corolla's don't appreciate. I remember, I once bought a 1978 KE55 Coupe, from a girl next door, who had had it since new. I got it at a good price, as the 3K "rubber bung" oil filler cap had popped out, and she had driven it unawares, until she lifted the bonnet. The site was so horrific, she assumed it was stuffed. A good Saturday afternoons work, and I had it looking clean as a whistle under the hood. Only problem was my girlfriend at the time, was driving it to work, and it had a fight with a truck. Truck "1", Corolla big "0". I remember cleaning out the glovebox & finding the original new purchase receipt for about AUD $ 4000. Cheers Banjo
Hi Keith, You are indeed lucky ! Members on this forum have "wet dreams" of finding & owning a rare find like yours. Well done. I'd almost sacrifice a nut to own one in that beautiful restored pristine condition. Like Parrot, I'll await your pictures on this forum. If it's not a personal question, how much did you pay, to aquire this beauty ? Cheers Banjo
Hi Keith, Welcome aboard. Wow, that is a beautiful KE20 you have there. It looks to have been lovingly looked after, & probably has low klms. Seems a shame to modify it in anyway, but a set of olde skool mag wheels, will probalby make it look even better. Love to see some more photos of it on here, and a bit of it's history, if you know it. If it hasn't got any serious cancer in it, you will be the envy of many on this site. Cheers Banjo
One tip when welding lower KE70 spring perches onto strut with a greater O/S dia. When you grind away the inside of the lower perch to fit snuggly over the 50mm dia strut, it does not leave a lot of metal on the perch at that point, where you need it to be welded to the strut. The original perches had a "turn down" at that point where, it met the strut, but you will have ground that off in this opening up hole process. I found a 2" dia. metal ring at the hardware store, that was actually part of an agricultural gate latch fitting. I careful filed all the galvanising off it, then carefully filed the inside dia. about 0.5 mm, until is was a snug slide down the 51mm strut tube. It was welded onto the strut tube, with about 4 off stitch welds, so as not to distort the tube. Then slide the lower perch down onto the ring and weld perch to ring & strut tube. Created a very strong welded joint, probably as good or better than the original. Cheers Banjo
Possible air leak somewhere on the inlet manifold ? Second stage, take 4K carby & dismantle, & give it a good clean with carby cleaner aerosol. Third stage, give ignition system a complete check overall, & replace anything defective. Forth stage, do a compression test to see how your valves are. One of those scenarios will most likely reveal the cause of your woes. Cheers Banjo
Hi Wayne, Yes, just carefully grind the KE70 struts lower spring perches off, open the hole out to approx 50mm to be a snug fit on the strut, and weld it back on, with enough compression on the spring, so that it will still be held captive, when you have a wheel airborne. I only used the top KE70 spring cap, as I used the Techno Toy Tuning camber adjustmenter. The spacing of the 3 studs on the KE70 top strut mount are different to other KEs. They are not evenly spaced. No doubt, you could probably use the KE70 top spring perch with a normal KE30/55 top rubber mount. Cheers Banjo
Hi Parrot, Most calipers have two mounting holes where the caliper attaches to the strut axle casting. The centre to centre of these two mountings is the 100mm I was referring to. The Corona strut's, (used by many on Rollaclub) mounting, are I think, 90mm centre to centre. This picture isn't mine, I just grabbed it off the net to make it clear. Cheers Banjo
Hi Steve, Yes pretty much straight in, bolt up changeover. However, if changing over from a JAP diff, you will need the tailshaft also, as the tailshaft to diff flanges are different. Cheers Banjo
Sorry for the slow response. Wanted bigger & better brakes on my KE30 2 door, but didn't want to go to 15" wheels. Finished up with Celicia RA65 struts, but the KPI on these is about 9.0 deg, and gives slightly positive camber. Needed adjustable Techno Toy Tuning camber top adjusters, to get it slightly negative again. Wanted to keep LCAs length standard. Biggest vented disc rotors I could find at the wreckers, that would fit inside the rims, were out of a Cressida MX62. The caliper mounts on the RA65 strut had 100mm centres and were parallel to the rotor, so required no packing or adjustment. Many of the Toyota disc calipers have 90 mm mounting centres, but I did find a later model Cressida (about 1992 - 1993 model) that had giant single pot calipers with 100mm mounting centres. These fitted the RA65 strut caliper mounts perfectly. These calpiers were however designed for a slightly thicker rotor. I needed to machine just 1mm off the caliper mounting face to get the caliper to sit over the rotor with the disc pads evenly spaced either side. I also needed a 2 mm flat spacer behind each disc pad, so that with everything new the pots were fully retracted. This was easy, as I just ground the brake pad off old disc pads backing plates, & then had then the backing plates machined down about 2mm. This is a very straight forward conversion, using KE70 coils & lower sping perches, so the the camber adjusters travel can be used in full. (KE70 has the smallest dia coils of the early Corollas) The later model Cressida calipers have giant disc pads which cover a greater area of the MX62 rotor that the original MX62 pads. This provided great breaking performance, with lower pressure requirements. However, I did convert my master cylinder to the early Pajero one. The result was a front brake performance that bears no comparison, to the original KE30s brakes. Let's be frank. Early Corolla's were not reknown for there good brakes. I'm about to fit a KE55 diff assembly which had 9" brake drums, rather than the original KE30's 8.0" drums. This diff has a 4.11 ratio (manual) rather than the 4.3 original in the car, as the KE30 started life as an automatic. I'd love a 3.89 diff ratio but can't find one at present. However, with the 4.11 & the slightly larger 14 wheels & tyres, I should get a car with "longer legs" and hopefully can cruise on the open road at 110 kph at about 2600 - 2800 rpm, in 5th gear. (yes it has a KE70 5 speed box) Cheers Banjo
Toyoat Corolla 4KU engines have dished pistons. i know, I've got one in my car at present.
Electronic Ignition, Coil And Ballast Upgrade For 5K
Banjo replied to Viterbo's topic in KExx Corolla Discussion
Good advice from Parrot there. An ignition system is as good as the weakest link in the chain. Use an olde dizzy with lots of slop, and you won't get the best results. Re RainWarriors query above. The MSD 6AL is basically a smart ignitor, but does not have the ability to setup a custom advance curve. http://www.msdigniti...on_Control.aspx It still uses the mechanical advance characteristics from the dizzy that triggers it. You need a programable ignition module, where you can set the advance curve up to suit your engine setup & your needs. I use an Australian Jaycar Programmable ignition system, which you build from a kit. It is the cheapest entry level way into a fully programable ignition. I've got an Accuspark/Powerspark Hall Effect sensor to replace the points in a 4K Denso dizzy I had rebushed. I locked up the bob weights, and the results have been very pleasing. I have the ignition wired up so that it starts up instantly, using the Accuspark as the ignitor. As soon as it starts & you let go the key, it flips back to the Jaycar system, using the Accuspark as a trigger only. I've built an external ignitor based on the Bosche ignitor component, which I brought in from DIY AutoTune in the USA. These Bosche ICs are almost indestructible. Just mount it on a heatsink & that's it. Very very pleased with the results, & highly reliable. I've played with the curve over time & the drive is now smoother, more acceleration & better top end performance. I've even put a limp mode switch in, so if in the worst case, the whole electronics & ignitor were to burn out, I can switch it back to the Accuspark and drive the coil via it's internal ignitor. I actually tried it one night, whilst 15 klms from home, and although lacking a bit of oommph, it got home safe & sound, with just static advance of about 12 deg. Cheers Banjo -
Hi Jeremy, Just a few thoughts. Have you done a health check on the engine itself ? If not, take it for a brisk run, until it is up to operating temperature. Upon return home, immediately take out all four (4) spark plugs and lay them out on a piece of cardboard & number them 1,2.3 & 4 front to rear. Then beg, borrow, or obtain a compression guage and do a full compress test, on each cylinder with the throttle wide open. You need an assistant for this. Write down the results, for each cylinder. If all the readings are very low, then squirt a tablespoon of fresh engine oil down each cylinder & do compression test again. The colour & state of the plugs & their insulators will tell you a lot about the current combustion process in your engine. The compression test will tell you a lot about the state of valve seats & valves & rings. All cylinders should be within say 5-10 PSI of each other. Consistency between cylinder compression readings is more important than the actual compression number itself. A hack Corolla engine should be somewhere in the range of 120 PSI to 160 PSI, dependent on compression ratio & state of the rings & valve & valve seat conditions. You'll be surprised how much info can be gained by this simple test, and point you in the direction to help you solve your backfiring issue. Cheers Banjo
Hi Steve, There are several varieties of the Pajero MC. The differences are the outlet position for the front brakes. The model you need is a JB1712, which can be obtained on line at ebay. Cheers Banjo
Hi Steve, Most Rollaclub guys who upgrade their front brake rotors & calipers, also increase the capacity of their master cylinder to avoid a very hard pedal. Master cylinders with 15/16" or 1.0" dia. cylinders work well. I used a Pajero MC, and it worked fine. Brand new ones on ebay were relatively cheap. You could do the conversion in two stages. Upgrade the brakes, and see how "hard" the brake pedal force required is with your existing MC. If it is too hard then upgrade the MC also. I did similar upgrade a couple of years ago. I used Cressida rotors & calipers, + the Pajero MC. The braking performance of the car was greatly improved, and it has worked perfectly. I've currently got a KE55 complete rear diff assembly & 9.0" brakes ready to go in, to finalise the complete brake upgrade. Only thing to consider, is whether you want to upgrade the booster also. However, it gets very tight in that area, if you go to a bigger booster + MC. I stuck with the KE30 one. http://www.rollaclub...page__hl__banjo http://www.rollaclub.com/board/topic/70150-problems-after-paj-master-cyl-install/page__p__686736__hl__+pajero#entry686736 Cheers Banjo O
Another Electronic Ignition Question
Banjo replied to rebuilder86's topic in KExx Corolla Discussion
Hi Jeremy, I wasn't giving you a bum steer about there being ignition coils out there with 3 terminals. I'll grant you they are not common, but they do exist. I don't know what he means either. If your existing coil has 4 ohms primary resistance, that's probably why you are getting a weak orange spark. The yellow 4K toyota bible says, you should be using a coil with a primary resistance of 1.1 - 1.3 ohms, with your reluctor dizzy with ignitor. The external ballast resistor should be somewhere bewteen 1.3 - 1.7 ohms. The ballast resistor should be shorted out effectively, by the start contacts of the ignition barrel. Let us know how you go ! Cheers Banjo -
The olde ballast resistor quandary ! What is it for ? Here's my take for what it is worth. In the very early days of the automobile, starting the engine was always an effort, particularly in cold weather. When the weather is cold, the engine is stiff & the oil thick after standing overnight. The lower the temp., the lower the battery o/c terminal voltage. The colder it is, the more current the starter motor draws, which puts a bigger load on the battery, and the voltage available in the system drops, sometimes to around about say 8-9 volts. The 12 volt coil performs well at 12 volts, but with just 8-9 volts across it, it didn't provide the optimum stored energy & therefore spark, just when it was needed at start up the engine. Ford, I believe, suggested using a 9 volt coil, which solved that problem, but introduced another. The 9 volt coil overheated & burnt out, when it was supplied 12-14 volts, once the car started. Solution was to put a resistance in series with the coil, that lowered the voltage to 9 volts, whilst the car was running, but was shorted out effectively, whilst starting the car. The resistance in series with the coil also had another beneficial result. It lowered the current passing through the points & therefore the points life was extended, from the normal pitting & burning. The ballast resistor, when used with a points system, also had the effect of regulating the current drawn. As the average current increases, at lower revs, the ballast resistor heats up, and it's resistance increases lowering the current. At higher revs, when the points have less time to put current through the coil, the ballast cools slightly, lowering it's resistance, and therefore increasing the current through the coil at higher revs. This particularly improved the performance of 6 & 8 cylinder engines at the higher revs. If an ignition coilhad an inbuilt ballast resistor, but only had two terminals, it could achieve the increase in current at higher revs, but cannot be used as a starting resistor, as you cannot get to the other end of the ballast resistor, inside the coil, to short it out during starter motor operation. There are coils out there with 3 terminals that achieve both improvements. Try a coil with a lower primarly resistance, and see if you get a blue spark, and the car performs better. You won't burn the ignitor out doing a test like this, for a short time. Be very careful when measuring the primary resistance of second hand coils you have available. Common multimeters, are not very good at reading resistance of a few ohms very accurately. Trust this assists. Cheers Banjo -
Hi Jeremy, 4K engines came with points distributors & reluctor distributors, depending on the country of origin. The reluctor distributors came with & without internal ignitors, according to the yellow Toyota bible. All came with ballast resistors, which were external to the coil. A 9 volt coil with an "internal ballast" resistor, that is shorted out on startup, is easily recognised as it has three (3) terminals. Ballast Resistor: 1.1 - 1.3 ohm with ignitor. Ballast Resistor 1.3 - 1.5 ohms without ignitor (points distributor) Coil Resistance - Primary: 1.3 - 1.7 ohms with ignitor. Coil Resistance - Primary 1.2 - 1.5 ohms without ignitor (points distributor) Coil Resistance - Secondary 10 - 15K ohms with ignitor. Coil Resistance - Secondary 8 - 12K ohms without ignitor (points distributor) Hope that helps. Cheers Banjo -
If your current distributor is the original 5K distributor, with reluctor trigger & internal ignitor, you won't achieve anything really by replacing with your options, other than possibly easier starting. The reason is that the PowerSpark replacement Hall Effect ignitor module, does not change the timing & advance/retard of the ignition, which is still a function of the centifugal bob weights in the base of the 5K distributor. The 5K engines were basically used in Toyota commercial vehicles & forklifts, where the requirement was very focused on torque, rather than outright power. As a result, a 5K dizzy in a Corolla is a bit sluggish. If you really want to get some more ooomph from your Rolla, by all means use the PowerSpark/Accuspark module, as a trigger source, rather than the existing reluctor, but then feed it into a programable ignition module with ignitor. This will however, require "locking up" the centifugal bob weights in your distributor. This is not a hard job. Simply remove the springs, tie the weights in with wire, and then a few "dollops" of Araldite to secure it. You can then produce an advance curve that will delight you with the results. Instant starts, greater acceleration, smooth cruising & very reliable. Only warning is don't go overboard with very low ohm sports coils, unless you have an an ignitor that can handle it. Lots of guys burn out ignitors, (which are not cheap) by not matching coil selection to ignitor capacity. I've been running such a system on my 4KU for several years now, and the results were very pleasing. Cheers Banjo -
Electronic Dizzy, How To Get Tacho Working
Hi Jeremy, Is your 4K distributor a reluctor type, with internal ignitor, inside the distributor, or a reluctor type with an external ignitor, or has the 4K distributor been fitted with a HotSpark modification, with Hall effect trigger & ignitor all inside the distributor ? You need to determine this before going any further. Cheers Banjo -
Hi Jeremy, Because of the shape of the combustion chamber in the head & the dished pistion, I believe the long reach plug places the spark in the middle of the compressed air/fuel mixture at the moment of firing, to provide best explosion and rapid flame front to all parts of the combustible mixture. Cheers Banjo.
