DR1FT
Regular Member-
119 -
Everything posted by DR1FT
1987 Holden VL Berlina - with rego. Has rb25 engine number on the rego slip. RB25DET 5speed, using rb25det box. Engine has had the 100ks, not sure on exact K's of motor. Was told it would be around 110,000ks now. I have quite a receipts for the work done, including the head gasket work, 100ks service, tune and dyno runs plus a whole heap from replacment parts. ( headlights, taillights, interior peices etc ) The dash has stopped at 105 ***ks (series 2 dash) HKS Bar Boost gauge HSV Pedal set ACL Gasket kit, using 1.3 metal HG. New Belts, fresh fluids/filter Front mount intercooler. Full custom 3" Exhaust HKS Mushroom filter. VLT Ally rad Manual Boost Controller, been running at around 9psi since i bought the car. Dyno run shows 190kw, tuned by TurboTune 4.11 LSD - brand new gearset still being run in Koni rear shocks Kings super low springs, Re-set 35mm lower Pedders adjustable panhard bar Front strut assembly using pedders (short stroke) inserts, with King Ultra lows. Had a heap of bushes that needed replaceing redone with Superpros - have receipts for work AC Delco 180LPH in-tank pump Wahlbro external pump The car is not perfect, but still in great condition for its age. Was resprayed back in 07 in Passion Red, still looks great. Has a few little scratches here and there. The steering sometimes has a bit of a shutter when coming to full lock. There is also a small hole right in the top of the fuel tank, previous owner said he tryed to mount his amp through it or something, there is a screw in there from him, seems to keep pretty much most of it in there. Price is $8000 Looking for a clean KE30/KE55 + cash Feel free to PM me an offer or any other questons/Pictures you would like. Josh, 0433 627 738 - Best to MSG first as of work. Cheers
No Interest?
price neg
1987 Holden VL Berlina Turbo - fresh 3months rego. Has rb25 engine number on the rego slip. RB25det 5speed, using rb25det box. Engine has had the 100ks service done about a 4 months ago, not sure on exact K's of motor. Was told it would be around 100,000ks now. The dash has stoped at 105 ***ks (series 2 dash) The interior is in pretty good nic, has formula headrest, HKS boost guage, VX GTS Pedal set. ACL Gasket kit, using 1.3 metal HG. service, new coolant temp sensor, oil filter/oil etc done at the same time. Front mount intercooler. Full 3" Exhaust. HKS Mushroom filter. Manual Boost Controller, been running at around 9psi since i bought the car. Dyno run shows 190kw, tuned by TurboTune around 3months ago. 4.11 LSD with re-built calipers and new DBA slotted rotors - starting to whine abit. Koni adjustable rear shocks Kings super low springs, Re-set 35mm lower Pedders adjustable panhard bar Had all the bushes that needed replaceing redone with Superpros last week. front strut assembly with pedders (short stroke) inserts, with King Ultra lows. AC Delco 180LPH in-tank pump wahlbro external pump Car is rolling on 15x7 ceptors, i was told two have been profensionally winded, the rear two have a few marks on em, where just spare 7" wide that a mate had laying around. Front tires are still almost brand spankas, rear are still in good nic I'm sure theres more, if you have a quick sus at thread below you can see most of the parts from one of the previous owners. The car is not perfect, the radiator will need replacing aventully ( no overheating what so ever atm ) the core is getting abit ****ty thats all. The steering rack has a slight bit of play where it joins to the tie rod or something makes a slight knock everynow and again, only found this out when i was having the bushes done on friday. One of the fan belts make a squel on startup on cold morning, was going to do these when i done the radiator, but the radiator is still working fine. There is also a small hole right in the top of the fuel tank, previous owner said he tryed to mount his amp through it or something, there is a screw in there from him, seems to keep pretty much most of it in there. may also trade for a clean 5speed ke70 + cash, need a new daily. I'm sure il think of some other stuff to put up, if you have any questions or anything just let me know, Old thread with the build up can be found here, not exactly the same now but gives you an idea. http://www.calaisturbo.com.au/showthread.php?t=109991 Well put up a recent shot during the week, these are only about a month old, still looks the same. http://img714.imageshack.us/img714/9466/dsc0341x.jpg http://img808.imageshack.us/img808/7342/dsc0370o.jpg Price: $9000 - may swap for a clean 5 speed ke70 or a x83 cressida plus cash, need a daily. Located around Semaphore area, adelaide. Any questions or anything let me know, Cheers Josh
looks simular to my rb25 VL man, nice stuff
going from a clock tash to a tacho dash, just wondering is it just a simple swap over? Had a search couldnt find anything.
actually worked alright, cleared some of the dirt n shit on the pads
thinkin it maybe dirt or something built up on the pad, sprayed wd40 over the disk and hand spun it round and the noise is a bit quiter bit its still there. Gonna remove the pads and have a proper look on the weekend i rekon.
Did u end up changer the window reg man? Mines pretty rooted
yeah mine just blew in my rolla bro, just give it a good yank and it will come out, most likely has a tad bit of rust/gunk holding it in there man
don't really no much about brakes man, gonna jack it up take the caliper off and remove pad again and sus around see if i can find anything.
I'm having a similar problem in my ke70, I'm using 86 struts and just changed my pads over and bleed the brakes, all clean oil was coming out etc. But now my Front left pad is still rubbing on the disk, was thinking maybe new pads still bedding them selves in? Is there anything i can have a sus at without having to pull everything apart?
Can You Run Falcon Springs With Ae86 Struts?
DR1FT replied to DR1FT's topic in KExx Corolla Discussion
So can Cut falcon springs be used with 86 struts? Been searching with no clear answer to what model falcon and if it can be done. -
pretty sure my mate is running two front and two rears in his 70 bro. you wouldnt no if el's fit into 86 struts would ya?
my front setup is pretty stiff, the rear is pretty sloppy. Nah he got the springs from a wrecker out of a EL Falcon so thinking of trying the same and just cutting them to a daily height, will still be low just not as much. don't have a project thread yet man, trying to get parts sorted out for it still. Cheers -
i maybe man, could you PM me with pictures and details? Sorry to hi-jack your thread bro
Wondering if i can run a falcon spring in the front end with my ae86 strut setup? My mate is running EL Falcons all round, but without the 86 struts. He has a nice stiff ride all round, my front setup works well for me but back is a bit sloppy. Also looking to raise it up abit so the cut VL fronts have to be changed, thinking falcons ( which model for 86 struts ) Hear is my current set up front end ae86 struts tokico short stroke shocks VL springs vented rotors braided brake lines xt-130 lower control arm t-18 steering knuckles rear end cut falcon springs - seem pretty sloppy compaired to my mates. locked standard diff short stroke shocks. bought the car with this setup already in, so not to sure on the model falcon springs or what not. Cheers, josh
so can you just run the same model falcon springs all round, IE - EL falcons all round? I'm using ae86 struts up front aswell, will this matter?
ive got a black 2inch taco i can sell and also a spare gauge cluster to mess around with you want?
i have aftermarket seats on ke55 rails, that might be an easier fit.
you should do the door trims in black vinal like mine, comes up alright and would suit this car i rekon.
yeah initial d is the shit man, awsome cartoon, the arcade game is pretty good aswel
i would like a new car with more kilowatts but no one seems to wanna buy my car.
gotta learn somewhere.
hey all, well after trying to sell my rolla, no one seemed keen so i guess i might as well keep it now, after i spent all this money on it and put a new motor in it! I'm not sure of what kind of motor yet, i just bought a reconditioned k50 with a new clutch for my 4k, so id like to be able to keep that. Does this i mean i can only use this box with a 4k, 5k and 7k?
