48 -
Everything posted by SKA80R
Child Restraint Anchor Points In Ae92/3/4 Seca
SKA80R replied to SKA80R's topic in AExx Corolla Discussion
haha. I totally agree -
Would anyone be able to provide with some picture and/or dimensions or child restraint anchor points in a AE92/3/4 SECA. I have no luck in getting the info for anchor placement for my hatchback. I can only seem to find info for mounting them in a sedan with metal parcel shelf. Any pics and or photos would be appreciated
do yo have any pics of the cross member? I am looking to buy a T18 gear box x member?
I can't seem to find any pdf's on the AE71 corolla workshop manual? Can any one steer me in the right direction
Is this diff of yours for sale???? I have not been able to get my hands on a T18 or AE86 diff? Are the diff housings the same for both large and small axles? Could a big axle centre be bolted into a small axle housing? If so, could I fit 2 billet axles to suit the centre? or are bearings going to be the problem?????
Is the small axle T series diff , A strong unit that will hold the same amount of power as the large axle????
I am out to build myself a t series diff... My KE70 van needs a diff that will last and handle the 4agze I am looking to purchase a trd lsd diff centre to suit a AE86 t series. There are two different centres, due to difference in size of the big and small axles. Since my KE70 had the smaller S series, I need to find a suitable T series diff to house the AE86 lsd centre. Celica? Sprinter? T18? Big axle Vs small axle? What can you guys tell me? Cheers
If you can get the code..It would be appreciated.I thought the townace diff would of bolted straight into my panelvan Same stud pattern too I would be happy if I could just get a T series diff with a lsd..But as you know...They are becoming rarer
Do you know what year model the KR42R is then? Would you have an axle code for the diff in your van?
Would anyone know what series of diff are used in the 92 townace(KR42R)??? S,T,G etc. I believe the track on this diff is 1445mm. Would this be suitable to bolt under a KE70 panelvan with lipped wheel arches? Can a lsd cantre with 4.3 ratio be purchased for this diff Cheers
I have since found pics of your AE82. So my questions was answered.
Yeah..I am from the Gong. What Corolla Do you drive ???? FWD or RWD ????Dave
Surely someone has a ratio or a diff code of a AE86 sprinter
Did The ADM AE86 have an axle code of T282 ????
:) That Is Simply Gold...What A Van...That Is A Collectors Dream :D Wish It Was Mine :)
I am pretty sure skyline R31 is 5 stud. The axle are 28 spline from memory The R31 pintara is 4 stud which is a good thing ( I have 15x6 rims) but If you want a LSD diff...I would have to use a VN SS LSD center
I am after a diff for my 4AGZE KE70. I am using a T-50 gearbox,Standard Rolling Diameter wheels and a speedo (637RPM=1KM). What Diff ratio Is needed to keep my speedo true ????? I originally bought a R31 Pintara Diff and have shortened one side.(4.1:1) A few people I have spoken to have told me that they are not the strongest of diffs. I would prefer to use a Toyota Banjo style diff. From what I have read/Been told....I can use a T series diff. The trouble is getting your hands on a sprinter diff :) Can I use a T series from a RA60 Celica? Will it be to wide for my Rolla? Can Anyone give me data on the Track and Ratios of Toyota Diffs Used In Australia???? What ever Diff I use....I need to be able to buy a LSD centre. Can anyone tell me what they have used? NB...I need a diff with 4x114.3
Can anyone tell me if clearance is a problem in putting a 7k into a ke70? I have put a 5K in a KE70 before and i know the sump clearance was was next to nil. Can a 4k sump be used if there is a problem? Can all of the 4K components bolt straight on ( Inlet, exhaust and box and flywheel) Cheers Dave
I am jealous....I want your car....I love my KE70 Vans 5k With K-50. Wheels...15x6 Graphics by: The One and Only (Idiot) other than that...Pretty well stock.
The Bloody thing is more than spooky...Its giving me the shits. I own 2 KE70 panelvans ( Both with Japanese Writing on the compliance plates) I am guessing your ADM KE70 has all english on the compliance plate. Your van should also be made by AMI (Australian Motor Industries?) Does your van have a low roof like the sedans? Cause mine does Is there any chance you could take a photo of the cross member under your car? Cheers
I went and found an automatic member out of a KE30, but it was still to big (long) Could you have possibly used one of an earlier model ???? Did it definately just bolt into your JDM KE70 Van ? Dave
Thanks for the info.Do the compliance plates have japanese writing on them? or are they made by AMI My car is a KE70 Panelvan made in Japan (Japanese compliance plate) I am using a T-50 from a AE86. I have tried using the following x-members AE71 and AE86 so i thought the TE72 might fit Here is a pic of some cross members Jap Ke70 Aus Ke70 Aus AE71
The bloke who sold me mine, said an offset like that would reduce the vehicle overall by about an inch an a half ( better to increase it ) He sold me 15x6 with offset +20
sorry about that.. i thought i was in the write section Can you tell me who is a TE72 expert? My car is a JDM ke70 and i need to know if the TE72 was JDM (imported to AUS). None of the KE70/AE71 gearbox crossmembers fit under JDM KE70 I thought if the TE72 was JDM...there was a good chance the x-member might fit
Have you checked to see if it hits the engine mount? looks like it will be close :D
