Rolln666KE20
Members-
25 -
3
Everything posted by Rolln666KE20
NAME: Scotty Dee CAR: 1973 KE20 Toyota corolla MOTOR AND DRIVELINE: 4K 4 speed with shortened LSD SUSPENSION AND BRAKES: Adjustable camber plates and coil over struts coil over with shortened shocks rear WHEELS AND TYRES: GENUINE B45 SIMMONS [B]Interior[/B]: [B]Body[/B]: [B]Other[/B]: I figured pictures speak 1000 words
I'll also get that resistor sorted out as well the last thing I need is more dramas with the engine bay hahaha. Wish I had a timing light that would sort it out in a jiffy
Yeah I fucked it off and just linked it together, got the current back and power again. The battery is 550CCA heaps of AMPS. Got it fired up she's running again but I'd say it needs a tune, I'll take it for a drive tomorrow to see if its still doing the same thing. I didn't put that fuse in I found it in the line hahaha
Found the problem this must have blown, I'll get one bigger then 100A its running from the battery to the starter
Hahahaha i thought it was a bit much for the old girl! I might get a Timi g light as well just to make sure the timing is 100% I'll get those pics to you this arvo mate. Thanks again
Its just a standard coil with a fanta can wrapped around it hahaha. I'll send you some pics of that area after work,if the ballast resistor. Also its running points yes
Yeah i got the engine turning over a few times it fired but didn't start then it went dead, no dash lights no horn, no stereo, no power. It couldn't see a blown fuse and still have to check the in line fuse. I'll have a fuck around over the weekend I bet its something stupid. If you wanna come have a look at her in the weekend be my guest man I'll flick you some cash for your troubles.
Morning man. Thanks for the advice. So got the valves and timing done, new battery and got a few cracks out of it and all of a sudden no dash lights no power at the ignition. I'm starting to think she might be cursed hahaha. Any thoughts
Id like to see what fallow corolla lover think but can't find any meets around here, i was just tryna get the engine bay looking a close match to the rest of the project.
Yeah mate its for the windscreen washer, I just got some 6mm and 8mm silicone hose and sleeved it over the pipes
I havent adjusted the tappets that's why I thought it might have been the issue, I'll re install the dizzy at TDC and see if that helps any. Thanks mate your a legend
Hey man. Was wondering if you might be able to help again. So I just did the head gasket on my 4k it runs and idles sweet but as soon as I put load on it/drive its struggling hard! I was thinking maybe valve clearance as I think the gasket was slightly thicker I also had the dizzy out to paint the block. Anyway here's a pic of what I've done to the engine bay
The charge light was already working sweet hahaha
Yeah man. I figured it out because the battery us located in the in the boot all I needed to do was run a cable from the battery back to the battery on the B+ line. Thanks for the help again there is a 40amp fuse running from the positive terminal. Just been de looming the engine bay. I'll keep you posted for sure when shes good to go I'll bring it over if you want to see her in real life
Hey man i got my cert plate and the road worthy on Friday, just spent the last few days getting the seals and gaskets replaced on the engine. Got a few more things on the way like braided line and some better piping but heres a look at the work ive done since yesterday.
Finding a 5 speed is definitely the best step i know exactly what you mean they hum perfectly on the motorway in 5th. Its got a shortened commador diff in it have no idea of ratio but its solid as fuck and the diff head is massive compared to a k series diff. Thanks for being so helpful mate good to see theres still people around who love these cars and want to help out. I live in Manly
Its should be getting its road worthy today (fingers crossed) she runs and drives like a dream. Running 4k with 4 speed but I'll look for a 5 speed soon as I know they both straight up. I love bayside. The only thing electrical left is the alternator. I'll see how I go but I wouldn't mind a hand my brother is helping out. Shes been in a garage since 2007 and has just had a buff and clean out its a little weapon and down the track will get a 1JZ as the diff, brakes, suspension are already upgraded
Thanks heaps man shes been snagged since 2007 ill get some more pics for you today
Anyone got a corolla owners manual they could send me a pic of a wiring diagram for a ke20 coupe?
Hey gents ive got this show room ke20 and the last thing she needs is the alternator wiring done does anyone have a wiring diagram that can help its a 1974 with a 4k. Its the only thing I can't figure out and don't want to mess it up
