tojo2
    646
    6
Everything posted by tojo2
  1. Ke1 and Ke3 blanks are different
  2. Yes, its not a crossmember tho. (transmission mount) Goes between your crossmember and T50. Youll need to move crossmember about 10 cm Holes are probably already there. You can get them for a couple $ from rockauto
  3. yes, 4.5" rims with 155 /80/13 tires. 70 profile was considered low back then Narrow wheels are faster , get better mileage and more fun :D
  4. T-series. Axels and housings interchange but you wont find lsd for a D series Ta 22 diff will save you cost and hazzle of shortening so worth a bit more than the others mentioned in my opinion. Youll also need rear part of driveshaft to suit whatever diff youre getting
  5. Ok , thanks. Will probably be ok if I figure out stuff like home, favoritelist and G.toolbar or eqivalent
  6. Changed to chrome Linking and quote seems ok. Typing is way better as well, still getting the red underlining but doesnt matter can't say I like chrome so far tho - where is everything ? :bash: Thanks
  7. Internet Explorer 11 no, same thing from mrs and work pc so guessing its user related Clear cache.. need to Google that. :doh:: done but still the same
  8. No idea why, pretty much nothing happens. I`ve tried different kinds of linking to bucket. When I try copy/paste, I don't get the option of pasting "quote" function doesn`t work either I'm no pro on PC but usually get this stuff right Cheers (35 Words in this post was underlined in red)
  9. Havent been able to post pics or links for a long time now. Also, some kind of auto type correcting program is screwing with my typing. Might be trying to make it norwegian Underlines / changes words and leaves out letters. I have no idea where to switch it off This is the only forum where I'm having these problems Any suggestions? Cheers
  10. Got one on my ke35 but havent been able to post pics or links on this site for ages
  11. 75-76 early. Bottom pics 77-78 late. Top pics. I prefere early ke35 and high rise grills (even if low rise hood)
  12. a good service & tuneupp 98 octane fuel+ advance timing a bit will probably give you a noticeable performance boost
  13. ok, was thinking auto adjusters would do their job if serviced
  14. What grief ? fun, fun, fun! Sounds like you need slack handbrake cables, remove drums, clean free and lube rear brakeshoe adjusters Adjust them so shoes almost tuching drums and then tighten upp cables again
  15. Just notised youre from Malta You can get a "clutch bearing Assembly" for a 1980 Corolla 1.8 from rockauto Should include carrier and clips. Cheap and easy ;) . Still will need a fork tho
  16. For partnumbers look at toyodiy Use a 1980 Corolla te7 for searching Should be right Id try finding a used fork and carrier. What engine are you using it for? T series?
  17. gearbox looks like a earlier than 82` 20 spline t50. Do you know what car its off? May be different carrier and bearing to ae86 items
  18. According to Sydney Morning Herald 17.03.67 : just stab Accelerator and she`ll downshift to direct drive
  19. check out the Rollaclub wiki ;)
  20. Had one like the blue badge one - 79 KE30 Some call them Hirise
  21. Are both ke15 and ke70 manual ?
  22. Martelius is a good brand made in Finland, possably sold in NL so less freight ?
  23. yes 2t, 2tg, 3t have same ex port spacing. rhd/ lhd could be differet tho Is Your original exhaust manifold 4-1 or 4-2 ?
  24. A couple other easy things to check is for good ground cable and Connection from battery minus to chassi and chassi to engine block, and free movement of dizzy timing advance .
  25. Forwrd (ta22) and rear(ae86) shifer position T40/50s have different shifters. Belive T40 and T50 of same model share shifters
