tojo2
    646
    6
Everything posted by tojo2
  1. Theres two types of standard exhaust manifolds, 4 - 1 and 4 - 2. Recomend 4-2 style, Matching exhaustports may not be a good idea. Having larger ports in manifold than head apperantly helps avoiding exhaust gas revertion
  2. Could be worn starter brushes or solenoid contacts.. check block gound cable contact as well
  3. 7K it, and keep the auto until youre ready to spend some more $ on it?
  4. Olds cool autos can probably supply whatever`s missing if you decide to og for it
  5. Hi Donald Its clealy a 4k With dished pistons and could well be a 4ku, Most if not all austalian delivered 5k heads will suit it Just swap over valve rockergear. Type of head you want is easily recogniced by lumps under sparkplug 1 and 4 I wouldnt worry about casting numbers Cheers
  6. Have seen on forums 4k-U has become the popular term for a dished pistoned 4k . Some 4kj , regular 4k and 4ke also came with dished pistons Some 4k-U also came with flat top pistons. If you do a bit of partnumber crossreferencing on toyodiy, youll find some 4k and 5k shared heads. both flat top vertions and dished vertions.
  7. you can use a 5K head With lumps under 1 and 4 spark plug
  8. dynamic compression wont be same if 4k was worn and 5k is fresh Was head cc ever measured ?
  9. So its a hilux diff thats been narrowed to ke70 spec that your putting into a ke30 ? Sounds like youll need a coustom driveshaft as well as ke30 diff mounts
  10. Nah, not the same. ke3 is about 1365 mm and ke7 about 1410mm
  11. Liked them when they were new. Still do :2thumbs:
  12. Nice find. Tip for ID.ing it : D is 208mm front to rear head flange and T is about. 225mm
  13. 60.1mm, old Mazda Wheels need a slight grind. They`ll go on, problem is getting them off again ;)
  14. Looks like a ke50 to me but if you have doubt just make a paper template and send to seller for comparing
  15. If you prefere castrol Id use this one. Let us know how you go. Good luck : product description About: Castrol Syntrans Multivehicle 75W-90 Fully Synthetic MTF (Replaces SMX S 75w-85) Castrol Syntrans Multivehicle 75W-90 Fully Synthetic MTF (Replaces SMX S 75w-85) Castrol Syntrans Multivehicle 75W-90 Fully Synthetic MTF (replaces Castrol SMX S 75w-85) is recommended for most manual transmissions where API GL-4 lubricants are required. It has been used successfully as a problem solver in the manual transmissions of a number of manufacturers.
  16. Id use a full synthetic 75w90 GL4 oil instead. Youre using a diff oil not suited for syncros
  17. Depends what year 2tgeu it came from. They came from 78 to 85? so wont be from a ta22 originally but still could be 20 or 22 spline (smal/large input bearing) what oil are you using?
  18. Happy to help Good luck
  19. -21deg celsius? Hope you got a warm garage You could get a earlier bell and mill out hole for input bearing but better to get right parts to start with Youll need the coustom 22 spline driveshaft for the 20V swap anyways then.. what car is it in now?
  20. Advice sometimes depends on your location so good idea to put it in your profile. North America, right? Not much Ta22 around I'm guessing. As mentioned better off with a 81`or older 20 spline T50 from a TE7 corolla or even better a pre 79? t50 from a Te3 or te5 corolla. Latter have shifters in correct position Te7 boxes has the shifter 10 cm further back so bit of bodywork needed to fit. Using 20 spline t50 saves you the cost of making a coustom driveshaft You can use k40 crossmember along with t50 trns.mount to fit. Id be looking for a te3 donor car for gearbox , pedalbox, hydroclutch setupp, engine crossmember,bigger brakes++ or 4ag it instead of 2t as you already have some of the driveline Ae86 t50 are better but will either need a post 82 T bellh or some milling or lathe work done to a pre 82 bell + coustom driveshaft. rwd 4age gearboxes and bells are worth a fair bit more than 2T stuff on most markets, don't know about north America tho All about supply and demand I recon
  21. Car looks good I woudnt swap out a good 3T for a 4ag. If anything Id look into changing the steeringbox for rack and pinion from a AE and I'm not a fan of US bumpers. But if you love the way it looks and drives why change it ?
  22. guess youre thiking of a phantom grip lsd
  23. Not trying to excuse seller but could be a nice item http://www.quicksales.com.au/ad/amco-shifter-knob-emblem-60s-70s-toyota-nos/20527
  24. Its period if that helps. http://www.ebay.com/itm/1970-Ad-Amco-Car-Shift-Knob-7425-Fulton-Ave-N-Hollywood-CA-Auto-Insignia-YCD8-/371227379565?pt=LH_DefaultDomain_0&hash=item566ee0476d
