tojo2
    646
    6
Everything posted by tojo2
  1. don't know Your location, but the ones on ebay from Australia suit rhd
  2. Like it :thumbsup: Looking forward to updates
  3. Does your lowering Blocks have correct size locating pins?
  4. Hi. Never seen a factory sunroof on a ke3 Some pics would be great. Cheers
  5. check center pin of the escort Blocks. From memory Corolla ones are 16mm diameter
  6. http://www.freetechnics.fi/polttoainepuoli/9-uncategorised/146-classic-car-parts.html try sending an email to them
  7. Like Pete says lugnuts are wheel dependant so first find the wheel you want, then find a nut to suit and then youll be able to work out if you need to change studs. Some wheels need shank nuts so wont need longer studs even if stock nuts only go a few turns in. Studs are 12mm x 1.5mm pitch so eight turns will give you same length of engadement as stud diameter. don't know what the rules say tho.
  8. check for 12v on wire going to ballast with ignition in run pos. If nothing, trace it to ignition Block and check there as well
  9. output spline from a k50 will be 20 spline. Should be able to find a front tailshaft yoke from a ke30 that will fit Your tailshaft. Was your ke11 auto?
  10. compression test ?
  11. it will fit if your k50 came from a A engine but not if its from a K engine- 4a-fe in RWD will cause Dizzy and manifold issues
  12. belive is 83320-19205 amayama, ebay
  13. Congrats Planing to register classic or regular?
  14. Guessing youre in US since you got a hardtop ? Rare bodyshape in most parts of the world. Wish we got them here Get part number at Your local Toyota dealer , then do a seach on a site called amayama
  15. nothing wrong in asking ;) Id start with a search for "ae92 diagnostic codes"
  16. strange but paperwork seems to state a 09` 77` with a 1290cc 4k engine?. Not that i know tailandish :no2: :hmm: Airfilterbox looks like a 4k item. Check that alu ID tag on firewall. Engine will have a serial number stamped on block starting with 3k or 4k.
  17. Hi Mitch Looks like a ke35 or te37 . Could be a 75 but dash looks like a 77. Bonnet (hood) looks 75`. Tail lights te37 Pop the hood and check the alu ID plate on firewall. Chassinr should be stamped in there as well. Take some pics of engine bay. Is it 4 or 5 speed? Flares , lip ,seats ,mirrors++ are aftermaket, Cool ride. Driving home for Christmas ?
  18. http://www.bestpartstore.co.uk/1656090 available and in UK at a fair price
  19. search for brembo 08.1661.10 as well ;)
  20. Hi Lou, yea 14 sounded a bit thirsty. 41 is respectable tho. Better than most new cars. Found some pics of Your cars. Great collection Know about the sump, but I'm short a engine mount and want to keep the efi. Would prefere fuelpump in tank.. Some small rust repair is due as well. Ive got what I need for the t50 mod so shoudnt take long to bolt that all together. Cheers
  21. Hi Lou. here is the reason I asked http://www.finn.no/f...earchQuery=ke10 Appears to be a early one. Sounds like a great cruiser you got there. Is the 7k carb or efi? 14mpg? sure its not 41? Ive got a 70 ke17 and a 7ke that I hope will go into it some day with a t50 behind it . Havent been doing any work on it for some years now but some day... Diff is a overhauled B code 4.222 with new c&p, bearings and a trd lsd in it - wont be used much on highway... or anywhere else for that matter if I don't start getting stuff done. Cheers - Tor
  22. Hi, Yes thats what I was after . Thanks Rolou
  23. Anyone know if a ke10-b 68/3 front bumper 52111-19036 will fit a ke17? Cheers
  24. doesnt look right ...
  25. Can use the ta22 gearbox with ae86 bell but need a 68x62x10mm spacer ring on the input bearing. tailshaft might need shortning .
