tojo2
    646
    6
Everything posted by tojo2
  1. Probably not. There`s a better chace of these fitting https://martelius.com/en/products-by-car?automerkki=98&automalli=472&cat=17
  2. Long shot but try contacting megat
  3. What appers yellow probably used to be white.. Colors according 74`ke3 diagram External regulator.: White Green - F White Black - E (ground) White Lightblue - N White (a seperate fatter one, not part of the plug) B
  4. Good to see the forum is still upp and running, helpfull as always. Worth mentioning that if fan size or position is changed, shroud should be modified accordingly for effective cooling
  5. Belive there is two different waterpump styles for T engines. Short and long nose. Needs pulley to suit
  6. https://www.esapeltonen.fi/toyota-starlet-racing-parts/
  7. Jap diffs: ke1 and early ke2 had B code. Late ke2, ke3, kp61 and ke7 had U code and kp60+ 62 are X -code 5.6" U and B axle splines interchange but not the X code splines. There was a Finnish shop selling new 6" lsd centers. Forgot the name but will probably pop upp when I least expect it ; )
  8. Media loves exaggerating Facts don't sell There has been talks of banning sale of NEW diesel and petrol cars in norway from 2025 but nothing decided yet. There`s no mention of when old ones will be prohibited Lots of New electric and hybrids being sold these days due to small or no tax, tollfee, parking expenses ++ so owners of ICE cars subsidice El cars. Not happy about it as I got six of them.
  9. Beautyful 55 you got there. Butyl sealant stays soft - does the job
  10. For a 1975 model
  11. Kentcams sell single valvesprings to suit the T125 : VS35 and adjustable pulley : S63 3F lifters and "Twin squish 4k pushrods" are the parts Toyota originally used in their solid lifter vertion of 5K so wouldnt call it mix and match. Keeping Hydro lifters would need a different cam grind and New or resurfacing of lifters
  12. The ones from the 4k twin squish. amayama had New originals in Stock 2-3 years ago
  13. Hi. Depends wich t50 you got. What year is it and out of what car?
  14. jap banjo diffs have a ID code starting with a letter followed by three digits. . Indicates Crown diameter, ratio and lsd or not E7 Corollas came with s,t and u code diffs.+ borg warner for ADM http://www.club-k.co.nz/Forums/viewthread.php?tid=10452
  15. Hi. That looks like a standard borg warner. On Jap banjo diffs (S,T,U) the bolts are facing forward
  16. Hi. kp6 hubs are straight swap. ke3 hubs need a different bearing as said. . Id look into using kp61 brake disc and caliper as theyre bigger and better. I don't know if brackets fit strut Cheers .
  17. Sorry, meant piston compression height, not pin height If you can turn engine, you can measure the stroke
  18. Do the New pistons have the same pin height as the old ones? How far below flush are they?
  19. Yes, you can measure from input flange to housing flange. S : 195mm T : 225mm http://www.club-k.co...d.php?tid=24477 Also, should be stamped on alu I.D tag on firewall Saw there`s a good S series r&p set for sale in finland at the moment . Probably wont find lsd for it tho. S : 8 stud housing flange T: 10bolt housing flange
  20. Start by checking if its a T or S series diff you got ;)
  21. rod dimentions http://www.spoolimports.com/spool-conrods/toyota (7k = 7afe)
  22. Hi Suggest you get a 1.3 4k from a ke70 instead of spending $ on the 3k, if youre planing a smal uppgrade. This might be a decent one: http://m.finn.no/bap/forsale/ad.html?finnkode=61125638
  23. early ke20s are B , later ones are U, Did some Research some years ago and found that U heads should fit in your B housing using B (original) axels U : late ke20, ke30, ke70, AL25, kp61
  24. Since Your 79 Corolla is a ke30 there wont be any location issues. Same shifter location as kp6# A wide range of corollas were made in 79` ;)
  25. I would start With bleeding brake system. Look for leaks as you go
