fourwheeldemon
    11
fourwheeldemon's Achievements
  1. hey guys as the topic says I'm about to begin to fit a 4age 16v into a ke70 i know that ive goto use...- ae71 crossmember+ engine mounts - ae71 speed with crossmember + mounts -of course the 4age with loom, ecu, etc -ae71 pedal box but what else do i need? ive tried a search on google, toymods and here and I'm really stumped! also can someone pease tell me how i remove the ke70 pedalbox, fit the ae71 pedalbox and fit the hydraulic clutch setup? i don't understand how to do it? from pat p.s. any help would be great
  2. hey guys sorry i havent replied in a while my internet doesnt work too well lately! stupid dial-up! just a few things... *does anyone have more info on fitting the 1ggt pistons into a 4k? *does anyone know where i can source a fuel injetction? as i was goin to run a 350 holley with smaller jets and plastic floats in a blowthrough setup but apparently they have bad flat spots in them? *also I'm trying to track down a 5k dizzy (don't laugh i know they are hard to find but someone must have one!!! lol) would anyone have one? from pat
  3. hey guys yeah i was thining of running 6 psi onlow boost then bout 12 psi on high, so i was trying to find out what i shoud do for some cheap internals (i know internals arent cheap but I'm 16 and cheap is my main priority so i wouldnt mind using 2nd hand ones if u or anyone u know have any and ill just get the rings redone? from pat
  4. hey guys I'm in need of some assistance as I'm buildnig a turbo setup for my 4k ke70 the idea so far is to use... -mitsibishi turbo -blitz external gate -350 holley -3k bigport head (with a full port job on it) -turbo grind on the cam -front mount -carter fuel pump -bosh coil -5k dizzy -oringed block -plus more but i feel that the pistons wont last long so i have to choices 1. use 4k dished piston... do u have any, i can't find any? lol 2. use turbo chrade pistons... how easy is this to do? what needs to be done? will they bolt up to the stock rods, etc? thanks guys from pat p.s. any help will be usefull
  5. hey demuire, yeah that yellow ke55 in toowoomba has a ca18, bigger turbo... etc plus a huge bottle of giggle gas in the boot! we got told it will run consistant 11z on street tyres. and the other one which is orange has a worked 4k in it and it is bein forced 30+ psi into it and they have run tests on it and it is running fine. so they say. also pro_ke, do you know what is done to angela's corolla? is there a site where i can find info? from pat :doublebird:
  6. ok guys ill drop my realistic figure to bout 150 at the wheels, i was only goin by what the mech said, he said " with equiptment like that you would be looking at a bit over 200 hp atw! so obviously he has a bit of bad judgment! i was told yesterday that we have a ke55 into in toowoomba forcing 30+ psi into a mildly worked engine, he is running a t50 box and an old celica diff! it is said to run in the 11z! but thats probably a rumor, all i know is that its turboed and is a rocket!
  7. oh crap well what would be the next step! the mechanic said to go auto for strength or sum crap but i want the manual
  8. oh i forgot by "them" i mean the 5speed box! also r the ke70 5speeds a straight bolt up with the change over from the 4speed! , also to say that i need the stronger box what do i do? demuire mentioned that the k series houseing for t50 boxes are hard to come by! what should i do in this situation? also I'm no wizz in using forums so what do i do to tryn find those threads for diff conversions into a ke70? sorry for all the troubles from pat
  9. hey guys u have been good help, jus another question, so should i go for the 4 speed or the 5 speed? I'm hoping for bit over 200hp at the wheels for now...! also does anyone have the phone no. of a wrecking yard that would stock them? from pat
  10. oh sorry man i forgot that... I'm plannin a 4k with dished pistons, fully ported head, custom manifold, 350 holley , a bp 1.8l familia turbo... from pat
  11. hey guys i just got off the toymods site n there is an arrogant prick on there so i8 thort i try here! ive got a ke70with a 4k with a worn out 4 speed! I'm currently undergoing a turbo conversion for it and i want to put the five speed in it but i dnt know what box it is or where i would get one from? if you could help that would be great as I'm relativly new to corollas so I'm trying to build my knowledge of them! from pat
